Renault Ft17 tank by King Derelict - FINISHED - Flyhawk 1/72
With the Penelope diorama on hold while the Sculptamold dries and the Kujawiak waiting for primer to dry I thought I would investigate the contents of the Flyhawk Renault FT17 box a little more closely. Somehow a few hours passed and progress is being made. The hull was straightforward to build up with everything fitting well. The detail is very crisp and impressive. Some nice PR parts complete the details.
The track and drive wheel assembly had me reading the instructions and playing with the parts several times to ensure the assembly was correct. Its not obvious in the photo but the little chain drive in the top left is a folded PE part and is going to be invisible in the final assembly. The sprocket wheel and the front wheel are specific to the variant being built.
The hull needs some more PE adding which will make it quite delicate. I may wait until painting of the major assemblies is complete and the tracks are added. The turret and tracks are completed as far as being ready for priming
Thanks for looking
Alan
Link to comment
Share on other sites
Yep the early wooden front idler wheel.... Later they were made of welded steel....
An interesting way they did the tracks.... I had the priviledge of doing individual track links with individual rollers on mine.... (RPM 1/35th scale)
Nice crisp detail for a 1/72nd scale model....
Tempted, but I do like my 1/35th scale....
Edited by Egilman
Quote:
Link to comment
Just started and almost ready 😉
Nice work
Regards, Patrick
Finished :  Soleil Royal Heller 1/100   Wasa Billing Boats   Bounty Revell 1/110 plastic (semi scratch)   Pelican / Golden Hind  1/45 scratch
Current build :  Mary Rose 1/50 scratch
Gallery Revell Bounty  Pelican/Golden hind 1/45 scratch
To do Prins Willem Corel, Le Tonnant Corel, Yacht d'Oro Corel, Thermopylae Sergal
Shore leave,  non ship models build logs :
ADGZ M35 funkwagen 1/72    Einhets Pkw. Kfz.2 and 4 1/72   Autoblinda AB40 1/72   122mm A-19 & 152mm ML-20 & 12.8cm Pak.44 {K8 1/2} 1/72   10.5cm Howitzer 16 on Mark. VI(e)  Centurion Mk.1 conversion   M29 Weasel 1/72     SAM6 1/72    T26 Finland  T26 TN 1/72  Autoprotetto S37 1/72     Opel Blitz buses 1/72  Boxer and MAN trucks 1/72   Hetzer38(t) Starr 1/72
Si vis pacem, para bellum
Link to comment
I finished adding the last elements of the PE to the hull. One of the drivers hatch handles disappeared while I was cutting it from the fret and I can't find it so a scratch one was made from 0.2 mm brass wire.
I have sprayed grey primer onto the assemblies and will now wait twenty-four hours before starting the paint scheme.
1770189622_RIMG0198(1280x720).jpg.07b15157a715c58782f03d9af503ad0b.jpg1198748605_RIMG0199(1280x720).jpg.fef7a94fb186c40d0fa73238ea430418.jpg
Thanks
Alan
Link to comment
Sutch a sharp little thing  with all that detail.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
that's what happens when I decide to tinker with something.......before I know it,  it's too late to turn back  ;)   nice start on this one........look'in to be a fast finish {guess that sculpy stuff dries faster than we thought :blink: }  look'in forward to the camo paint. :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
I sprayed the white paint onto the hull as the start of the Spanish Moroccan paint scheme. I had just cleaned the air brush and the Post arrived with this
The colour illustrations show the paint scheme for the Spanish Moroccan Rif Wars but it is described as grey and olive drab. That maybe makes more sense than white as i think I recall the Rif being limestone. So I sprayed a coat of light grey over the white and we will move forward with that. I sprayed a brown base onto the tracks which I am assuming are steel and take on a rust brown colour in service.
The masking of the hull and turret will be next. Interesting!
Thanks
Alan
Link to comment
A very good book 👍
Regards, Patrick
Link to comment
17 hours ago, Backer said:
A very good book 👍
It packs a lot of information into a thin volume. Its very useful and will helpo a lot with the three other FT17s I have. The colours in their illustrations are a bit more subdued than teh Flyhawk schemes so I will try to follow their examples.
Thanks
Alan
Link to comment
Alan,
For the French/American WWI versions the colors in real life were bright and vivid, very colorful.... Patton commented on it in his reports when he received them....
The Flyhawk illustrations are close to spot on in presentation.... The others I'm not sure about as they don't hold the interest for me as the American tanks do....
One more thing, they were not allowed to stay dirty neither the French nor the American ones Renault gave specific instructions that keeping them clean would just about double their mechanical lifespan so they were kept washed and clean when not actually in battle....
Edited by Egilman
Quote:
Link to comment
Thank you for the help with the colour schemes Egilman. That is really useful information. I'll stay with the Flyhawk colours for the US and French variants. Its also good information about the condition of the tanks in the field. I'll keep weathering and dirt down to a realistic minimum.
I studied the Rif War scheme a bit further and decided on the olive drab with the grey rather than brown. The Rif is limestone with dusty green vegetation so I think this ends up being a compatible camouflage.
Many thanks again; you are an invaluable source of detailed information.
Alan
Link to comment
I masked up the hull, turret and running gear for the olive drab paint. I used the same method as I have on the small destroyers to get a starting point. I scaled the Flyhawk illustration up to the same size as the model and printed it along with a reverse image (I only have one side illustrated)  The relevant parts were then glued to masking tape and cut out. That gave me some idea of the layout on the sides and then I filled in across the  turret and upper hull. Some of it is simplified because it will be hidden by the tracks. It looks a bit untidy but it seemed functional
Then the olive drab
And the big moment; pulling the masks off. It came out quite well and captures the intent of the paint scheme even though it might be a bit out on the details
The tracks can now be fitted to the running gear and these assemblies will go onto the hull. Some detailed painting and restrained weathering and I think that is all it needs. Fun little build.
Thanks for looking
Alan
Link to comment
That is looking So good Alan  - and considering it minute size.
OC.
Current builds
Completed works.
Link to comment
My pleasure Alan, I did the research for mine several years ago....
Tank #1, 2nd Platoon, C Company, 427th Tank Battalion, 1st Tank Brigade, AEF, 1918 Meuse-Argonne Campaign...
DCP_2086.JPG.6190241108e15e9388537bd11a37a49f.JPGDCP_2087.JPG.fa59f53c2d206c9f2dfc885665553e53.JPGDCP_2089.JPG.f36810c535050af8f1e98210a750c3cd.JPGDCP_2090.JPG.d0700de1356effce419c259203102118.JPG
1/35th scale, yours being in 1/72nd scale is much more impressive....
Quote:
Link to comment
After a pause at the weekend I made some progress. I fitted teh running gear into the tracks and added the assemblies to the hull which completes the build. I touched up paint; added detail painting and a light wash to bring up some of the panels and track details. I added a small amount of rust on the lower part of the hull and the trail.  I didn't want to really overdo the weathering. I'll look at it again tomorrow but I'm inclined to add the decals and leave it as shown here.
Thqanks
Alan1552324228_RIMG0291(1275x1280).thumb.jpg.e373a8887cf507cd6fd2de9fb1491f47.jpg1818250524_RIMG0293(1280x720).jpg.9ab6ff44dea5c5aaddf120573205c787.jpg426052934_RIMG0290(1280x720).jpg.1ddf66af465aec6f240d6b96a20a24a8.jpg
Link to comment
That is looking excellent Alan  - really nice paitwork.
OC.
Current builds
Completed works.
Link to comment
I went back and added a small amount more rust on teh trail and some Oilbrushers bare metal on the raised sections of the tracks. This may have been too much but the contact area of teh tracks would be bare metal I suspect.
I added the decals and I think that is this one done.
Thanks for the comments and likes,
Link to comment
I think it looks the part of a SCW tank very very well.... Yes in constant usage the tracks would basically be bare steel on the contact surfaces, but this wasn't a tank in constant usage, it had long periods of sitting out in the semi humid spanish countryside environment... in essence everything not painted would have surface rust over it in a very short time, so I little shiny where the rust was knocked off would fit it perfectly... A little rust around the lower parts would also fit as I'm sure they didn't exactly receive the maintenance they would have when in the French army...
I think you understood the subject well and interpreted it appropriately....
Looks very very good..
Well done...
Quote:
Link to comment
I agree with Egilman  - It looks the part   spot on with the weathering.
OC.
Current builds
Completed works.
Link to comment
OC.
I fully agree with these 2 comments.
Very nice work
Regards, Patrick
Link to comment
Well done...
Thank you so much for the compliments Egilman. Your guidance and reference material helped me immensely.
Alan
Link to comment
great job on the camo..........it looks amazing :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
