Winchelsea Nef 1274 A.D. by Louie da fly - FINISHED - 1:75
And a bit more progress on the steersman:
20210727_170953.thumb.jpg.4de68f818a58f4560aa186f57b71f728.jpg       20210727_171007.thumb.jpg.2e8f0856846df337cfa648d30ee7de6d.jpg
20210727_171114.thumb.jpg.c0e21d466e4339e011238fa519e5c993.jpg       20210727_171257.thumb.jpg.d23ac96afe39a4784971849bf8a175fe.jpg
20210727_171259.thumb.jpg.72e8a829f29e99336d0f82b3ae64f8ca.jpg      20210727_171429.thumb.jpg.826379d5fa518baab916f36371c7230b.jpg
I've yet to do his face and a few finer details - but I'm going to leave the arms as they are until I have the ship built and the side rudder installed, so I can get them just right.
And the next two figures (the guys in the aftercastle
playing the mediaeval trumpet, or buisine)
1598640458_trumpetbuisineAafiles_en_las_Cantigas_de_Alfonso_X_theWise.jpg.7cd3dc7ab7abb5bd759d3f130a9bba8e.jpg    164305179_trumpet1.jpg.6bcfae6e88ef7899c2bda6b39e49a518.jpg
Steven
Edited by Louie da fly
Link to comment
Share on other sites
    My copy of the Zimmerman book and plans has arrived.  :36:The plans are slightly different than the model depicted by Christian.  Not sure why.  The plans include a crow's nest castle (mast castle?) whereas the model does not.
    I don't speak or read German, but I was able to follow the jist of the book.  In one chapter he traces the development of the ship from the Viking longboat and knarr thru the cog.  He makes references to various maritime archeological finds.  I concur that you are on the right track.
On 7/23/2021 at 6:20 PM, Louie da fly said:
Zimmerman's reconstruction looks most like the ships on the seals of Hythe and Haverford West
    I believe the Zimmerman model/plan is a composite of various nefs.  He features many sigels/seals from the Cinque Ports area and even has 'reconstructions' (diagrams) of them.  The Hythe seal is featured but the Haverford West is not.  For me, the Sandwich seal appears to be closest...but again, I believe his aim is a generic nef.
Chuck Seiler
San Diego Ship Modelers Guild
Current Build:: Colonial Schooner SULTANA (scratch from Model Expo Plans), Hanseatic Cog Wutender Hund, John Smith Shallop
Completed:  Missouri Riverboat FAR WEST (1876) Scratch, 1776 Gunboat PHILADELPHIA (Scratch 1/4 scale-Model Shipways plans)
Link to comment
Chuck I didn't read the book for a long time, as far as I remember right, the drawings are showing a prototype for a nef. For a specific model you have to refer to the seals. If you need help by understanding a sentence ask me. For reading the book you can use deepl.com. It's a really good translation program.
Regards Christian
Link to comment
Yes, I think you're right. I did consider that myself, merging several nefs that incorporated my favourite features, then I decided it would be better to portray one specific nef rather than a "conglomerate".
Steven
Link to comment
Christian,
    On pages 23-27 he has 14 different seals; Santander, La Rochelle, Dunwich, Romney, Southampton, San  Sebastian, Pevesey, Hastings, Rye, Hythe, Yarmouth, Dover, Nieuport and Faversham.  He has Winchelsea and Sandwich prominently displayed elsewhere.  On pages 105 thru 111 he has the diagrams I mentioned of all but the first 2.
Steven,
    I think you made a good choice.  As you mentioned previously, Winnie is one of the more artistic seals and it is very clearly rendered.
Chuck Seiler
Link to comment
Link to comment
I've drawn the lines of the planks on the plug, basically using the technique outlined in the planking tutorials. And at the top you can see the wood I'm going to be using for the planking. Walnut from the dead tree of the guy next door, cut into sheets by the guy across the road. It's nice having good neighbours.
And covered it in cling-wrap so the planks don't get glued to the plug.
I used packing tape to hold the clingwrap close to the plug, and to keep the keel and stem and sternposts in place.
And I've started carving the first trumpeter.
Steven
Link to comment
Let me fill up the popcorn bowl before we get started.   ...okay, we are ready!!!!!
Chuck Seiler
Link to comment
Crazy work  - so good.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
Steven,
    How long will your model be?  I know you said 1:75, but I saw no specific dimensions.
Chuck Seiler
Link to comment
Sounds like a nice manageable size.  If I make the Zimmerman model I would want to go 1:72 like my cog.  It pencils out t a little over 12 inches.
Chuck Seiler
Link to comment
Yes, it seems to work quite well. So full size yours would be somewhat smaller than mine, but well within the "permitted variation" for ships of that type. Mine's at a slightly smaller scale, but of a bigger ship - its dimensions are taken from Hedeby 3.
Steven
Link to comment
I discovered a small problem. Due to the shape of the hull, I've had to include stop planks, but I was "stopping" them as though they were carvel planks - with both the plank above and below the stopped plank taking its place. But that doesn't work with a clinker built vessel. The overlapping of the planks means that only the plank above the stopped plank overlaps. So instead of this:
I had to change the overlap to this:
Which means I had to take off the clingwrap and start again.
The first buisine player is complete except for removing him from his bit of wood.
And I experimented with the buisine. I first thought of making it out of wood, but wood painted to look like brass doesn't look like brass. So I decided to try making one out of brass. Found an old piece of brass welding rod and put it in my "poor man's lathe".
And worked it up, bit by bit. To keep the thing from bending uncontrollably I kept my working surface close to the drill chuck, only letting it out bit by bit as I needed to.
Pretty happy with the way it turned out. The only problem is that I seem to have made it too thick - more like a bazooka than a trumpet.
And now it's been cut off I can't fix it. So I think I'll have another try and see if I can make a thinner one. I hope I can make it work this way - otherwise I'll have to go back to wood, which I'd rather not do, for the reason above.
Steven
Link to comment
    Huh?  I have never seen clinker with drop/stop planks.  Is this viable?  The other option would be to slightly increase the rise at bow and stern.
     Your lathe looks like mine.  :cheers: Good thing they didn't have tubas.
Chuck Seiler
Link to comment
My 'take' on clinker planking is with Chuck. I suspect Chuck's suggestion of a higher rise of sheer is the answer, which explains the height of the ends of these early vessels.
Nice first go at a real brass instrument!
Link to comment
Thanks for the likes and comments, people.
I'm now in two minds about the drop planks. What I was working off was this drawing of a knarr -
unfortunately, I didn't make a note at the time where I got it from and now I can't find the original again.
But the Winchelsea seal does show considerably more sheer than this knarr
(though of course it may be due to artistic license).
Now I have to decide which way to go - if I increase the sheer it might mean that I have to make new stem and sternposts so they come up high enough above the top of the planking at the ends of the vessel.
Time to do a bit of thinking . . .
Steven
Link to comment
Quote
I think I can give you some information about this drawing,. This is a reconstruction drawing of Skuldelev I from 1971.
It was as far as I know the base for the presentation of the ship in the musuem. I own a copy of this but there are in the meantime some newer reconstructions which are giving a slightly different hull. But you can build a very nice model with this information.
I am searching a reconstruction of the Haithabu knarr and longship. I hoppe to find someday one good drawing. of the find
Regards Christian
Link to comment
Well, I've been offline for awhile but I haven't been idle.
I've made a new buisine (trumpetty thing) with a finer shaft, so it looks more like a trumpet than a bazooka. And a second one. Terribly worried I was going to cut the shafts so thin they would break, but they turned out ok.
And I've carved the second buisinier, so now I have both.
20210808_165549.thumb.jpg.248f0d76d9c1508bf91331b967ef0e6b.jpg     20210809_120626.thumb.jpg.1fdb5969767ccc6b8b9955920a630ec3.jpg
20210809_120638.thumb.jpg.7f067a2c5df4470380902f1d353d9614.jpg   20210812_093800.thumb.jpg.19a5f701f6dcbe4fc01130abc0144bd4.jpg
20210812_093743.thumb.jpg.2113f2e4f511e53135cb2a5835c0d27e.jpg    20210812_093816.thumb.jpg.3947bc856c6d9de25952baa87b5e157a.jpg
So here's the three figures so far - A and B on the seal below - (the helmsman isn't finished - I won't finalise his arms till I have the steering oar made and in position)
20210815_103029.thumb.jpg.6f92359b426cb60b7a5beddf20815af4.jpg     20210815_103055.thumb.jpg.f955a3c402337cf6ffef4a64355f78c2.jpg
The next people to carve will be the guys amidships (C on the seal). And looking carefully at them for the first time I realise they are working a windlass!
1335798719_SealofthecityofWinchelsea(1274)withcircles.thumb.jpg.44182fb98650a9cc3a9722029307715b.jpg
It turns out this seal is not just a picture of a ship - it's captured a moment in time!
This ship is getting ready to set sail: The helmsman (A) is in place to steer the vessel, and two buisiniers (B) are announcing the ship's departure. The windlass (C) is raising the yard , two crewmen at the bow are weighing in the anchor (D), another crewman (E) is climbing a backstay to unfurl the sail when the yard is fully hoisted.
Steven
Link to comment
Having decided to "drop" the drop planks the planking came up higher and I found I had to make higher stem and stern posts. I was fortunate that I had some wood with a curved grain to make them stronger.
I needed to keep them the same orientation as the old ones, but I only had a scarph joint to keep them aligned. So before I pulled the stempost/keel/sternpost asembly apart I traced over the old set-up and used it as a pattern for the new one.
New planking layout marked out on the plug, with the plank shift also marked.
And picked out in red to make it easier to see. Cling-wrap on the plug again, to stop the planks adhering to the plug.
The planks of the garboard strake.
Dry fitted
Glued in place. I was fortunate to find a set of tiny clothes pegs made out of plastic instead of wood, so the glue didn't stick them to the ship.
The scarph joining two planks didn't quite work, so I glued in a bit of wood to fill the gap; to be sanded off later.
And here's the sequence of planking so far:
I used push pins to hold the planks down - the plug was made of pine, but it was rather tougher than I'd been expecting, so I needed to drill pilot holes in the plug so they'd go in far enough. And I used scraps of wood to spread the load, or concentrate it as needed.
20210813_133417.thumb.jpg.ff6277c3761610186aabed7a95c31c80.jpg     20210813_133422.thumb.jpg.a6cc7e66989e60833f2be8fd6fa5bb35.jpg
20210814_092918.thumb.jpg.12b97f1a8ea0197dd630727763c578bf.jpg    20210814_092949.thumb.jpg.c312094e2937106c5a37af75413d7911.jpg
20210814_151219.thumb.jpg.d0f83fe9e3ffc92eaafe9ceca645d09a.jpg    20210815_102747.thumb.jpg.8a71fc81e114739d16884c9a14676aa6.jpg
That's it so far . . .
Steven
Link to comment
Really nice progress
Regards Christian
Link to comment
How is the walnut working out?  I assume you are spiling and not edge bending.
Chuck Seiler
Link to comment
Thanks for the likes and the comments.
Chuck, yes I'm spiling. I've only had one plank break so far, but note that the planks are only about 0.8 mm (0.03 inch or 30 thou) thick, and there are no particularly tight curves. The broken plank broke when I was trying to induce a curve in it - I think I tried too hard too fast.
Steven
Link to comment
Nice work with the 'plug', look forward to seeing all the planking in-situ Steven.  What you have done looks great.
Pat
Link to comment
Lovely and interesting work, Steven
tiny suggestionette in relation to your pushpins holding the planks in position.  A circle of rubber about the diameter of the head of your pin would exert more grip with less precision of driving required.
My first thought was to slice a good draughstmans rubber into sat 3 mm slices, then make circles with a wet sharpened tube ( I use Readily-available-wetting-agent ( saliva) which is also a perfect accelerator for cyano)
Love your crew, and the remade and delicate instruments
andrew
Andrew
"Pas d’elle yeux Rhone que nous”
Kits under the bench: Le Hussard (Started in the 1980s)
Scratch builds:               Volante, Brig (R/C): Footy Drakkar "Rodolm" (R/C).  Longship Osberg (R/C)
Link to comment
Your idea is great, but is there any reason they need to be circles? Squares would be much easier to make and seem like they'd grip just as well since the essential point is the surface, not the shape of the edge.
Link to comment
Is there evidence for the layout of the planking  butts as you've drawn them? I'm just curious. The new shape of the hull with higher rise fore and aft looks very convincing now.
Link to comment
I suggested circles only because the base of Steven's map pins is circular - depending on the clamping force required and the stiffness of the rubber , squares could well be a better shape
andrew
Andrew
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
