Blackburn Shark Mk.II by modeller_masa - IMA Frog Penguin - 1/72 FINISHED
I'm building the world's first plastic model made by British company IMA. Here are some interesting stories regarding the International Model Aircraft.
https://frogpenguin.com/
http://archivesite.jetex.org/history/path_to_jetex.html
Actually, this kit is a new tool launched in 1968, and the first kit was produced in 1936. I decided to build this kit to pay respect to the pioneers. Also, this kit is 'genuine kit' by original company unlike many russian kits on the Ebay.
The good thing of this original kit is that molding line is very clear and sharp.
https://www.britmodeller.com/forums/index.php?/topic/235047566-blackburn-shark-mkii-eastern-express-172/
This is an ambitious work by russian modeller and my reference page.
https://karopka.ru/forum/forum259/topic23364/?PAGEN_1=10
While I was researching his walkthrough pages, I found that his russian kit after several decades is fairly damaged. Of course, it is not important if you sand and fix all of them.
The downside of too old kit is that some parts were missing when I bought. I bought the cheapest Frog kit on the Ebay. ;) I designed and printed the missing parts using 3D printer.
Unlike the Russian' guy's master work, my goal is immitating the original 1936 work using the 1968 kit without heavy modification. I want to celebrate the first plastic model company in the world in my own way. :D
https://www.vectis.co.uk/lot/frog-penguin-series-blackburn_563155
The painting and decals will be like this. In addition, I'll add some gimmicks such as 1930's neon sign like LED advertising on the top of case.
Edited by modeller_masa
Link to comment
Share on other sites
I might be concerned about the decals,  even though they're transfers.  I've never dealt with transfers,  but I would think that age and other factors  could render them useless.  micro cracking is the most common.......some can be seen and some can't........not until you go to use them.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
this is the same kit you have.   early models didn't have rivets or much in the way of panel lines........the retooling you speak of,  they must have added them then.
FROG 1/72 Blackburn Shark (Out Of Box) | The Sprue Lagoon
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Popeye // I didn't know about the water slide decal issue because of the frequent use on plastic kits. This kit also have a decal sheet and it looks fine, and I'll build my own water slide decal to emulate the 1936 original model plane. I want to finish it quick and simple, so I won't use stencil technique.
This kit has embossed rivets and panel lines unlike modern engraved panel lines. It is one of reasons I don't retouch this kit heavily unlike the Russian modeller.  If someone want to retool the kit, sanding is very quick and simple. This kit has some errors and mistakes due to hand made mold, but it doesn't harm joy of assembly, and imaging how they designed it in 1960s is funny. 😄
Link to comment
I'm building one that that was made with 1956 molds...reissue of a very early Revell kit.  we both seem to find enjoyment from older kits ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Most parts are fine or bit annoying, but not a real big problem. This was really huge issue.
It almost killed me... I would have given up if this last approach was failed.
str3.jpg.5347cdb3906963deddbd76a2de88b209.jpgstr4.jpg.a2764ba537befce6501740d2211073fa.jpg
NOT BAD. NOT BAD.
The main issue is that length of the rods are not correct. I would say that they are designed to folding position. I had to cut them a lot.
Link to comment
9 hours ago, modeller_masa said:
I just finished an airplane.
There is nothing in the world that compares to a fabric covered airplane in a fresh coat of silver dope.....
It has that shimmery quality that makes them look like a piece of jewelry....
Well done....
Quote:
Link to comment
Roger // Thanks for the comment. I'll pay attention to the case more.
Egilman // I've never seen any real fabric wing with silver dope in South Korea just like middle age sailing boat. I hope to see the old biplanes if I have a chance. I applied one coat of Holbein acrylic ink - pearl silver color with vallejo gloss varnish.
Link to comment
Hope we see more of your projects.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
I'm making a LED case.
https://www.vectis.co.uk/lot/frog-penguin-series-the-blackburn-shark_563129
Its color theme is based on the original box design,
https://www.pamono.eu/20th-century-english-shop-display-cabinet-promoting-selected-sponges-1920s
and cabinet design is based on the 1920s display cabinet.
I wanted a curved cabinet design like a jukebox, but it should have taken time more than this.
Link to comment
really nice job on the plane.........even more impressive is the lighting  ;)   shaping up for a very nice display!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
I printed out new catchphrases.
Masking and painting was hard lesson. I may need different approach in the next time.
Looks not bad. 😎
I decided to add some focussers.
It is not like a spotlight, but better than nothing.
For the side panels, all the LEDs are too straight and strong. I need diffuser, but distance is not enough. I made some reflector + diffuser.
Better than past, but not great. It has single mirror, and two mirrors should have had better result. I may upgrade them in the next time.
All light is white!
The resistances are cheat support. 🤪
The bottom layer of cabinet is combination of 1.5T mirror acrylic and MDF. I put stand from Airfix which is still compatible with original FROG airplanes.
Ouch, I placed the stand in wrong place... I'll change it someday. ;)
The last part is top cover and back door. I won't bond them because of maintenance issue and potential of future upgrade. I'll paint them tonight and finish everything tomorrow. 😄
Link to comment
wfpm01.thumb.jpg.552123058bd6c208aa8d02f8ccf962b2.jpgwfpm02.thumb.jpg.81dfebe0b9e28800491d01f652eff05d.jpgwfpm03.thumb.jpg.483c5a7361c5a3d3a26bc1b353a8063a.jpgwfpm04.thumb.jpg.049b2c0140a0ad9f62e8a2e8ee82fdbb.jpgwfpm05.jpg.0334370d67feb0e6336610cb50103b0a.jpgwfpm06.thumb.jpg.abde3897d3f6727c1a07f8068b2ea0b6.jpgwfpm07.jpg.6a64ef24e6ce7da050268329659f4dda.jpgwfpm08.jpg.2d40291d78e1449a4550c62536e6d213.jpgwfpm09.thumb.jpg.be317616167ee81c3d0359cfead3aa23.jpgwfpm10.thumb.jpg.592b885d5b4f74db9d3a4623ff7c7024.jpg
It's done. It looks like a temple of modeller when turns off the light, or modern museum when turns on.
Details are not outstanding, but I'm satisfied with overall visual. Thank you for following my rough work. ;)
On 8/20/2021 at 1:29 AM, Roger Pellett said:
The model is begging for a case to protect it.
Secured, contained, protected.
Link to comment
A stunning display my friend... What it does for the aircraft is over the top as to visual effect....
Museum quality display.....
Gorgeous presentation, Beautiful job....
Very, Very well done.....
Quote:
Link to comment
4 hours ago, modeller_masa said:
Thanks, Egilman! I was so happy when I was taking a picture. 📷
Only happy?  I'd be jumping up and down and shouting.   Beautiful display.
Link to comment
I love it  - so complimants the fine build.
OC.
Current builds
Completed works.
Link to comment
Please show us more of your fine work.
OC.
Current builds
Completed works.
Link to comment
I bought each kit for specific themes. I'm not sure all the results will satisfy Old Collingwood's favour, but you can believe that they will be slightly unique models. ;) I'm going to concentrate on late homeworks such as La Recouvrance, stone house, and train models for the rest of year. I need to clear my dirty workshop before adding new project. 😂
Link to comment
train models are always a pleaser  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
