Prinz Eugen 1942 by CDW - FINISHED - Trumpeter - 1:700 Scale - PLASTIC
31 minutes ago, Old Collingwood said:
Whats your work ethic  with the painting  -  assemble the sub assmblies  including the PE, then  spray primer then colour  then if  you are fitting them the wood decks?    just getting a flow for when I start my Hood.
OC.
First thing I do is wash the plastic and photo etch parts in a mild solution of water and dish washing liquid. Spray the photo etch parts with a metal primer.
Modify the plastic parts as required then apply the photo etch. Dry fit the superstructure components for painting. After painting, disassemble then add the wood deck stickers.
Link to comment
Share on other sites
Does the metal primer stay put  when you start bending it into shape, or does it crack?    I have never used it.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
Link to comment
15 minutes ago, CDW said:
I have not found any primer or paint that does not crack when bending the photo etch. If you do, let me know. I just touch up as needed with a brush after it's all done.
Thats why I wonder if its best to attach it first  before priming and painting.
OC.
Current builds
Completed works.
Link to comment
OC.
There is no one good answer to that question. Sometimes it's best to prime and paint first. Other times, it's best to paint in place. However, that primer I showed you is the least prone to crack of anything else I have used. But it's not crack-proof. You're going to find that sometimes painting after it's all bent and assembled is not practical for a number of reasons.
As an example...the outer railings I will paint first before installing on the model. Why? Because I will have already placed the wood deck and the rest of the model will be painted before installing those railings. If I tried to paint them after installing, I would get paint in places where I don't want paint to be.
Link to comment
My PE prep process is slightly different.  I usually soak the frets in water with dish soap, though sometimes I've forgotten and I'm not sure I've seen any different results.  I've had success using Mr. Surfacer and Vallejo primers in the past, but Vallejo can flake off with masking which can be annoying.  I did try that Mr. Metal Primer once, but forget what I was using it on.
For most subassemblies, I'll first attach the PE and then prime and paint.  I figure that the primer can help fill in minor gaps left from the PE not fully sitting on the plastic, PE folds that aren't perfect, etc.  For things like railings, I've primed and painted right on the fret and then attached it to the model.  Since railings are just about the last thing to go on, it's just easier that way and like Craig said, you don't want to paint the railings if you have a wood or linoleum deck or other colors on the model that differ from the railings color.  And again like Craig said, you can touch up any parts where the brass shows, glue spots, etc.
I was watching someone on YouTube yesterday who was working with PE on a ship model.  He prepped the PE fret by rubbing it with an Infini 400 sanding stick.  I think the idea is that primer has more surface area to stick to, and maybe to remove and residue from the PE process.  But like I said, I haven't really had issues painting primer directly to PE.  I'd also be a little nervous using a sanding stick on 1/700 PE frets or PE frets in general with very fine details as I'd be worried that the stick would catch some of the free floating details and ruin the part.  But, the guy yesterday didn't seem to have that problem.
Edited by Landlubber Mike
Mike
Current Wooden builds:  Amati/Victory Pegasus  MS Charles W. Morgan  Euromodel La Renommèe
Plastic builds:    SB2U-1 Vindicator 1/48  Five Star Yaeyama 1/700  Pit Road Asashio and Akashi 1/700 diorama  Walrus 1/48 and Albatross 1/700  Special Hobby Buffalo 1/32  Eduard Sikorsky JRS-1 1/72  IJN Notoro 1/700  Akitsu Maru 1/700
Completed builds :  Caldercraft Brig Badger   Amati Hannah - Ship in Bottle  Pit Road Hatsuzakura 1/700   Hasegawa Shimakaze 1:350
F4B-4 and P-6E 1/72  Accurate Miniatures F3F-1/F3F-2 1/48  Tamiya F4F-4 Wildcat built as FM-1 1/48  Special Hobby Buffalo 1/48
Citroen 2CV 1/24 - Airfix and Tamiya  Entex Morgan 3-wheeler 1/16
Terminated build:  HMS Lyme (based on Corel Unicorn)
On the shelf:  Euromodel Friedrich Wilhelm zu Pferde; Caldercraft Victory; too many plastic ship, plane and car kits
Future potential scratch builds:  HMS Lyme (from NMM plans); Le Gros Ventre (from Ancre monographs), Dutch ship from Ab Hoving book, HMS Sussex from McCardle book, Philadelphia gunboat (Smithsonian plans)
Link to comment
The Flyhawk photo etch is so thin, trying to sand it would end in disaster. It literally breaks apart sometimes before it’s bent. I think they need to go a gauge higher on their brass thickness. Way too thin. Makes it almost impossible for some modelers. I have lost parts right off the frets without ever cutting them.
Link to comment
I saw that in my FiveStar set for the 1/700 destroyer I built.  Hair-thin PE that bends from just breathing on it.
Mike
Link to comment
Yep, no second chances of you find you bent the part in the wrong direction. Just straightening it is often enough to break it. Likewise I've had parts break in the fret.
Alan
Link to comment
OC.
Like I have said in previous thread the most durable and sticky primer for shiny metal parts is epoxy primer like those used in car industry. I always prime my PE parts them work with them with no issues.
Link to comment
Thank you for explaining that Craig,   I guess  for some sub assemblies where there is a uniform colour  - assembling them priming/painting would be ok,  but I can see the need to prime/paint railings first before attaching  especially if a wood deck has gone down  or other areas with different colours/shades of pant.
OC.
Current builds
Completed works.
Link to comment
OC.
I broadly follow Craig. I paint railings, ships boats and rafts, and gun turrets off the model. I suspect other than these which are fairly fixed in my process I think it depends on the model, the access when installed and the ability to paint without getting overspray where you don't want it.
Alan
Link to comment
Indeed. With the Hood, the upper deck is in one piece and has 4 different colours/surfaces. There is the linoleum -deck brown, the steel-deck grey (which I believe is different to 507A), the superstructure grey (Admiralty 507A) and then a section of wood deck, all on the one part. Even with the full masking set I will need to be very careful as to what sequence I adopt for painting and wood deck fitting.
Link to comment
While building these 1:700 scale ship models, you need good precision tweezers to hold small parts. I had accidentally dropped mine several times and damaged the points. I couldn’t recall where I had bought the damaged set and tried several times to buy replacements, but struck out on finding a suitable pair. The photo of these two sets came from Amazon and are good replacements for the ones I damaged. Of the two, the ones labeled TS-12 are the most comfortable to hold and use in my opinion. Best part is, they’re only $5 each from Amazon with free Prime shipping.
AA707A87-01F9-4564-84B8-A0AE7988701B.thumb.jpeg.95248df80344d777a36de625f1aebd59.jpegDA88D35A-5920-4E2E-862F-564F288A7633.thumb.jpeg.65571169890cd9e09d9a863f7e3cd706.jpeg5BBF2F78-EFDB-4E95-9A2C-02708FC987B9.thumb.jpeg.060344aec78151cf2e57361bb43ddd5e.jpeg
Link to comment
They aren’t cheap, but after trying out many tweezers, I tried Dumont tweezers which are very good.  I believe I first heard about them when reading a book on miniature ship model building.
Here is a picture of the tips of two that I use the most.  Very sharp points!
Mike
Link to comment
Whenever I drop mine they always land points down - in my leg or on the tile floor. I think the points are getting beyond filing and straightening so these might be a good option.
Thanks
Alan
Link to comment
Thanks
Alan
That’s what happened to mine. Dropped, bent, and filed them down too many times. For 5.99, buy a few. 😀
They will eventually be used and needed.
Link to comment
Excellent!    needs no other words Craig.
OC.
Current builds
Completed works.
Link to comment
46 minutes ago, CDW said:
Thanks OC. But it does need more photo etch. I'm not even half-way through all the photo etch that came with the update set.
Its looking Stunning already  even at this stage mate.
OC.
Current builds
Completed works.
Link to comment
I got a set used for micro electronic repairs.
I also got a few of cheaper ones which I sharpened with dremel tool and turned equally good to the pro set
Frequently sharpening of twizzers, pliers and other tools  removes glue, paint and keeps them very effective no matter how they cost.
Link to comment
Link to comment
Laid some paint on the superstructure then a little post shading for modulation. Will disassemble the superstructure pieces then work next on the wood deck pieces, before final assembly of the deck component parts. There are additional sections of railing that will go down after the decks are completed.
66F9CFCB-29C0-4628-8F66-6E94F8A1170F.thumb.jpeg.746797937d23fa42f6f51a618401d085.jpegB2417F68-7718-46B0-9311-1A10DA7D3527.thumb.jpeg.475243773c7965e2d6b408d3512446b8.jpegE5E8E989-9396-4DDC-B423-49965713278F.thumb.jpeg.e8009b69177b9d27d962e55c82feaee8.jpeg8CA7E789-5C9B-410B-BC82-2F5ACE5558C2.thumb.jpeg.a486cbf58d0f55640e5d69a5f2cac75f.jpegEBE36F80-194C-43A2-8391-21956720DC17.thumb.jpeg.bca605d8af16e1f91550efb477a8410f.jpeg
Looking good Craig   - always looks better with some colour down.
OC.
Current builds
Completed works.
Link to comment
Link to comment
That looks better  - the camera was over exposing   in the first shots.
OC.
Current builds
Completed works.
Link to comment
Taking in all the details of your's  Alans  and Rogers builds  (even though I am not building - doesn't stop the grey matter from turning)
Kind of formulating a build plan for my Hood, will explain on my build as I dont want to de-rail you  build Craig.
OC.
Current builds
Completed works.
Link to comment
This ship has more tiny wood deck pieces than any other model I have built to date, but it all comes together in the end in a way that’s visually pleasing.
I knew it would probably happen, but managed to inadvertently crush a few pieces of railing here and there while disassembling and reassembling the superstructure pieces. Straightened them as best I could.
9861F2A1-20D6-4FC5-98D1-2A85CFC1A78B.thumb.jpeg.a099d9bb38091d60c9b2f0b8650c92be.jpeg0A2D79EE-E935-43A1-B552-928FD16B4A37.thumb.jpeg.f45bc852c56d7fddcb12ade931f508c6.jpeg
Link to comment
Nice progress Craig. I bet that you are happy to finally get the main superstructure painted and attached. Can't see anything hanging or bent in your pictures so it all must have turned out OK.
The way they established the plank pattern on the main deck looks a little odd, at least to me. Hopefully it won't be as pronounced when you add the remaining superstructure and other decks.
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
