HMS Sophie by TBlack - kit-bashing Jack Aubrey's first command from the Vanguard Models HMS Speedy
 Tom, this is great to see, you've managed to get over that hurdle! Do you see things being pretty normal going forward?
Link to comment
Share on other sites
Hi Keith,
Yes, getting the hull shape was the biggest hurdle. Adding the captain's cabin, and the quarterdeck should be straightforward. Otherwise, it's just build out the kit (maybe I'll see some places where I can augment or improve). For now it's a question of sanding down those first planks. Unaltered, the first planks and the finish planks together are 1/8" thick; too much for my eye, so lots of sanding.
Thanks to all of you who are following along and adding "likes". Most humbling!
Tom
Link to comment
Hi Tom
As a great fan of O'Brian's books I admire your project.
Perhaps you could find some additional information on your subject when checking wikipedia for HMS Vincejo (1799). As I understand the adventure was based on Speedy's capture of El Gamo. However HMS Sophie was supposed to be the former spanish Vincejo (or Vencejo) which could be this one. I think that at least the general description would fit.
Keep up the good work
Peter
Link to comment
  • 5 weeks later...
Small up-date, but life sometimes interferes with ship building:
Having built the hull to its new configuration, I'm now trying to follow Chris Watton's excellent instructions on building out the model. One deviation is the placement of the wale, which I think I've figured out to my satisfaction:
I only, belatetdly, realized that I don't need to make the wale out of the very nice pear wood supplied, inasmuch as it gets painted black in the end. Next layer will be something less grand. Next step is the garboard and then figure out the plank spacing in between.
Tom
Link to comment
Tom
I've just returned to your build log after a few months when I read the interesting discussion at the very beginning about Geoff Hunt's imaginative depiction of Sophie's stern.  You've done a brilliant job of modifying Speedy, and I appreciate how satisfying it must be to be so creative.  And for sticking to your guns when some members hinted that perhaps this project was not doable.
It was O'Brian's books that got me into ship modelling (way back in the 70s for me), only it's only since lockdown that I've been able to find the time to focus on the hobby.  My ambition way back then was to build Surprise, as did so many lovers of the novels, and maybe one day I'll follow your example to do just that.
Keep up the good work and the fascinating log!
Nipper
Current build:  HMS Sphinx 1775 - 1/64 - Vanguard Models
Completed build:  HM Cutter Alert 1777 - 1/64 - Vanguard Models
Link to comment
On 11/22/2021 at 8:54 PM, TBlack said:
In my volume of Master And Commander, page 32, Aubrey states that there are 7 windows in his cabin.
Just a thought considering the limited space on the transom.  Is it possible the seven windows included quarter badges?  Five on the transom and one on each quarter.
Luck is just another word for good preparation.
—MICHAEL ROSE
Current builds:    Rattlesnake (Scratch From MS Plans
On Hold:  HMS Resolution ( AKA Ferrett )
Link to comment
Nipper!
Thanks so much for your kind words. I guess I've shown that one doesn't need fancy CAD programs to get a smooth result. Also, my last project (Scud) was greeted with
some derision (why bother? Waste of time and talent) until the end (see log). Moral of the story? Don't rush to judgment. Anyway, you and the other 18 people who are following this keep me going and trying my best. Thanks for that.
Gregory,
I intend to do just what you suggest: 5 real windows and 2 fake. That arrangement will agree with the picture of the stern of the cover of the book. We had some discussion here on the impossibility of having 7 windows in the cabin given what the picture shows of the hull shape (please see post #84), and certainly there are no quarter galleries.
Thanks, also, to the others for the "likes", especially my brother, Keith, whose talents and encouragement keep me going!
Tom
Link to comment
Before I can place the garboard, I have to thin down the back end of the profile former (false keel to some). With the addition of the primary planking, that area is now
7 mm thick and needs reducing to 1.5 mm which also means more feathering of the hull to produce a smooth flow. Having done that, I notice that Chris doesn't expect
me to install a garboard stake. I suspect it's because all the planks in the kit are of a uniform width. Nevertheless, I will press on:
Looks the same on the other side. I'm using 24 foot planks. It also occurs to me that because the planks are all the same width that there will be stealers aft.
Tom
Link to comment
  • 2 months later...
Great cabin deck planked. The crazy arrangement of sticks in the picture is verifying that everything is square and that there is about 5'7'' headroom between quarterdeck
beams. We know from the book that Aubrey could only stand fully up between the beams. Also the sticks are telling me that the quarterdeck will, in fact, hit the transom
just as I had designed it. This is all working out much better that I could have expected.
I thought about what kind of treatment for the cabin deck, and was inspired by Greg Herbert's treatment of the deck in Speedwell which, with its multiple carvings, is a much snappier craft than humble Sophie.
Tom
Link to comment
At this point in construction the instructions have you placing the lazer etched deck in place. I can't use it because the deck is wider aft than the Speedy. So I'm laying the deck with individual planks. Chris suggests putting in the bottom spirketting plank (painted) first which necessitates my adding the margin plank.
margin4.JPG.027e161c9d1b2feaae8b4b2967464a29.JPGmargin5.JPG.d4946ff3392706f2559e2db9bef952fc.JPG
Now I can either finish up the spirket planks, or do the deck, depending on my mood. I'm using yellow cedar for the deck. Chris wants me to use the pear planking for the spirketting, but, being the cheap Yankee that I am, and that it gets painted anyway, I'm using basswood for that planking.
Link to comment
Thanks for all the likes and devoted followers. Try not to disappoint. Started planking the quarterdeck. Remember the adage, "measure twice; cut once"? I forgot. So started planking with 1/16" planks:
The planks looked very thin to me. Back to the plan; there're supposed to be 1/8" wide (8''). So, scrape it all off and start again:
Better this time, but I sure went through a lot of Alaskan Cedar. Thankfully, Joe Volpe is right beside me.
Tom
Link to comment
Starting the transom, which needs 7 windows. The picture shows the base over which will go the pear planking. The two strips are for mullions and side trim on windows.
The wood is African Boxwood. A slightly more yellow cast than Costello and with the same grain characteristics, and should go well with the pear.
The strips measure 1/64"X 1/16" cut on the milling machine.
Edited by TBlack
Link to comment
Tom-  I'm facing a similar issue with the windows in my AVS.  The kit supplied window frames are very heavy and i was planning to scratch build mine.  How are you making your stiles and rails?  It looks to me like you have full-height stiles and are placing short horizontal mullions in between (hope i got those terms right).
thanks Cisco
Link to comment
I've been searching through the build logs to see if there are any clues as to how to put windows together. I've discovered that, for the most part, stern windows are in a straight line (see Naiad, Essex, etc.) which are much easier to construct as they are all the same. The only arched stern windows I can find are Speedwell and Sphynx. Greg doesn't really tell how he reaches perfection, and Sphynx comes with laser cut windows provided. Anyway, I have attached the mica and have a template (sphynx plan) to help with placement:
Link to comment
 You've got this, Tom. I'm sure your template will work out splendidly.
Link to comment
46 minutes ago, TBlack said:
Keith,
Does everybody following this thread know that you're my brother and almost obligated to say nice, encouraging things?
Yes!  We are wondering if you only ever communicate with each other via MSW, or whether you ever chat on the phone!
Nipper
Link to comment
 As a matter of fact we have.
 I wouldn't say nothing wouldn't true even though Mom liked you best.
Edited by Keith Black
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
