Viking Longboat by Koerant - FINISHED - Artesania Latina
Ok, so I am a complete beginner. I have little to no woodworking or modeling skills. This is my first build.
I purchased this model a few years ago and was eager to start. I completed it up to the first half of the planking and then stopped for some reason. I have since moved 4 times and every time moved this unfinished model with me. About two weeks ago I decided to finally put in some time to get this model done.
I only recently found out about this forum so did not keep a log from the start. I am starting this log with an almost finished longboat.
This is my starting point fort this log. Longboat is ready for staining and varnish.
I learned that I should not be trusted with wood stain. I stained quite a bit more than just the wood. My hands are still a shade of medium oak. I should probably have used a lighter color for the wood wood stain but it does not look too bad. I could not get a clean finish but I kinda like the uneven coat. It gives it more character. When staining the outside, the color started to bleed through the planking so I had to stain the inside as well. Boy was that a mission...
My next task was to glue and finish the shields that will be added to the sides.
I did not like the way the shields looked after following the instructions, so I worked on them a little bit. I sanded down the blocky look of the planks glued on them. I wanted to stain them as well, but the only color I had was the medium oak that I stained the hull with. I did not think it would look great and I was too lazy to go to the store to get another color so I left them the way they were. I want to add a bit of contrast.
Next up, I need to assemble the oars. Will do that in the next couple of days.
Link to comment
Share on other sites
  Allan, the model looks great, the staining is a bit uneven but as you said, it adds character.
Edited by Keith Black
Link to comment
It's a nice job for a first build, something you'll be proud to display. Thanks for starting the log and it'll be fun to see how you finish!
Link to comment
Oars are assembled now.
I also started work on getting the sail up:
I had two missing dowel sticks in my kit so had to get some at the local hardware store. A little disappointed about that.
Added the shields and barrels.
I am basically done. All that is needed is to figure out how I am going to match the paddle color to the shaft. Easiest might be to just paint it all the same. Either way I do not have the correct colors to do that now so will hopefully get that next week and finish this one off.
Link to comment
 Allan, the model turned out really great, congratulations. Now that the first one's done, what one is next?
Link to comment
Link to comment
  • 3 months later...
Congratulations!  Well done!
Building: 1:64 HMS Revenge (Victory Models plans)
On the building slip: 1:72 French Ironclad Magenta (original shipyard plans)
On hold: 1:98 Mantua HMS Victory (kit bash), 1:96 Shipyard HMS Mercury
Favorite finished builds:  1:60 Sampang Good Fortune (Amati plans), 1:200 Orel Ironclad Solferino, 1:72 Schooner Hannah (Hahn plans), 1:72 Privateer Prince de Neufchatel (Chapelle plans), Model Shipways Sultana, Heller La Reale, Encore USS Olympia
Goal: Become better than I was yesterday
"The hardest part is deciding to try." - me
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
