HMS Speedy by Dave B - Vanguard Models - 1:64
I have started to build my Speedy kit and so far it's been a joy to work on. I have not had any difficulties so far that I couldn't figure out from looking at other build logs or more carefully reviewing the instructions.
It's my first kit from Vanguard Models and I can see why they have quickly become so popular. I'm hoping that once I complete Speedy I will have gained enough skill to finish my Niagara kit that has been at a standstill for many years.
I'm sure I will have questions as I progress further.
Thank you to all who have posted the previous build logs. I have read all of them!
Dave Barnard
Edited by Dave B
updated signature block
Dave Barnard
Current build: HMS Speedy (Vanguard Models)
On hold: Niagara (Model Shipways), Constitution (Mamoli)
Completed:
Marseille (Mamoli)
Duke William (Kammerlander)
Halifax (Lauck Street Shipyard)
Link to comment
Share on other sites
Thanks for the likes!
Added a couple photos of progress from last month showing the first layer of planking.
I found the utility knive method Chris uses to be quite effective with always having a sharp blade and taking multiple light cuts and firmly holding a steel ruler to guide the cuts. It seemed to work even without soaking the planks or just very brief soaking.
I'm not onto the second layer of planking and will add more of those photos soon too and be all caught up to where I'm at currently.
Dave Barnard
Completed:
Marseille (Mamoli)
Link to comment
Thanks everyone for the nice thumbs ups.
Latest update:
I've been working on the second layer of planking and it seems to be going well so far.
Following the instructions, I use a utility knife with a nice sharp blade to make the tape after marking where to start it.
Then I slide the edge back and forth on some self-adhesive 180 grit sandpaper stuck to a flat table top. I use two hands to do this in reality, not one, so that I can apply some slight downward pressure as I do that while holding it perpendicular. This makes a nice smooth transition from where I made the taper cut to the rest of the strip.
Then I use the little iron method to edge bend as demonstrated in other build logs. I made a little jig to make this easy to do with one hand on the iron. Then I use my standard plank bender iron to make the bend the other way and get it to match the shape of the bow area.
I've been using stick fast brand thick ca glue mostly, and medium worked just as well, as stated in the instructions. I use those little plastic micro tips to apply it. I do about 1/4 of the strip at a time. I hold it for 5-10 seconds then move to the next section. I find that I have only about 2-3 seconds to adjust it if it isn't in the exact spot I want it. (I don't have any debonder...need to get some)
By the way, that foam cushion works great to allow me to apply a fair amount of pressure without damaging anything.
Thanks again to all the other build log submitters, very helpful to have those to refer to as I proceed.
Dave
Dave Barnard
Completed:
Marseille (Mamoli)
Link to comment
Thanks CiscoH and everyone!
Here's the second layer of planking completed. I had just rubbed mineral spirits on it to catch any glue splotches which is why it appears a little shiny in the photo but that's evaporated now.
Now I'm finishing the painting the inner bulwarks area. I'm using the recommended Humbrol red paint and it's taking quite a few coats. Maybe I should have used a primer first. It's my first time using this Humbrol enamel paint, which does look really nice and is easy to brush on but seems to needs multiple coats to look even on the wood.
Since it's coming up soon, I do have a question about the copper plates. There is discoloration of some of them as seen in the photo below and I assume this is nothing to worry about. But I'm not sure how to make them all look the same, or at least close, and if I should do that now or after they are installed?
Thanks,
Dave
Dave Barnard
Completed:
Marseille (Mamoli)
Link to comment
Link to comment
Keel and other parts added and I've marked out the waterline which was a bit challenging to get correct but I think I've got it (not shown in photo)
Will soon be starting on the copper plates!
I have been reviewing the previous build logs for tips on that process. I considered leaving them off but I think I will proceed with coppering since I've never done that before.
By the way, I was able to clean the copper plates easily (from my prior post).
Dave
Dave Barnard
Completed:
Marseille (Mamoli)
Link to comment
Starting on the copper plates! These little plates are really nice. They are easy to work with due to being so thin.
CA glue seems to hold them really well but if needed I can pop one off and re-attach.
It looks like you just add one row on top of the other with no tapering of the plates until the top is reached.
With each row I get faster too. It's kind of fun actually.
One thing I probably should fix is that I didn't realize until I took a closer look at the on-line manual that the plates at the bow should be bent to fit and not cut there. I didn't notice that in the paper manual. Or is it OK how I'm doing it?
Dave
Dave Barnard
Completed:
Marseille (Mamoli)
Link to comment
You can always come back and put in the plates that cover the small portion of the bow you haven't done
Current Build: Fair American - Model Shipways
Awaiting Parts - Rattlesnake
On the Shelf - English Pinnace
                        18Th Century Longboat
I stand firmly against piracy!
Link to comment
I've completed the copper plates on both sides of the hull!
After taking a long time to do the first side, the second side went much more quickly. I got much better at cutting the plates where needed with my Xuron cutters which sliced right through them. Definitely some tricky parts but overall I'm happy with it.
I see that some people put a clear coat of some kind over the copper and I'm open to suggestions on that if anyone has any.
Just have to copper the rudder parts and then on to something new!
Dave
Dave Barnard
Completed:
Marseille (Mamoli)
Link to comment
Thanks everyone.
Working on the rudder. I found getting the hinges lined up to be a little tricky. Temporarily attached for now.
Dave Barnard
Completed:
Marseille (Mamoli)
Link to comment
Thank you James! And for the likes too!
Here's my latest photo of some progress after painting the wales. I can see that I didn't quite do enough "filling and sanding" that was supposed to remove any gap between the two strips and there's still a visible groove in areas. But I'm happy with it overall.
I'm using the Humbrol paints recommended in the instructions and they are really easy to use, it's my first time trying that brand.
Dave
Dave Barnard
Completed:
Marseille (Mamoli)
Link to comment
Very nice and clean work. If the gap keep worrying you and it isn‘t too deep you may try to fill it with paint. Apply several layers (let them dry between each layer) and then sand after each layer with 600er grit or smoother until the gap has disappered. This method is suitable for smooth painting jobs as well. For deeper gaps a wood filler might be the better choice.
HM Brig Badger 1/48 from Caldercraft plans
Le Coureur 1/48 by CAF
Completed Build:
Armed Virginia Sloop 1/48 by Model Shipways / Gallery
HM Cutter Sherbourne 1/64 by Caldercraft / Gallery
Link to comment
Thanks Captain. That sounds like great advice. It was already becoming less noticeable with each coat (I have 3 coats of the black paint on there now).
On the other hand I'm ready to move on to the next step. I'm just glad my taping job worked to keep paint off the other areas.
I will definitely remember your suggestion for future builds though!
Dave Barnard
Completed:
Marseille (Mamoli)
Link to comment
Attaching the railing parts. Went smoothly, parts fit really well.
Dave Barnard
Completed:
Marseille (Mamoli)
Link to comment
  • 3 months later...
Well I've been making some progress but realized it's been over 3 months since I posted any updates!
I finished up the details on the outer part of the hull which added a nice look to it, I'm happy with how this turned out. Some parts up there at the bow were a little tricky to get in place and all attached to each other but I think it's close enough. Had to adjust a few of those parts a bit but nothing major.
Thanks for looking!
Dave
Dave Barnard
Completed:
Marseille (Mamoli)
Link to comment
Next I moved on to the cannons and anchors and other small items for the deck.
This may be a silly question, but why are there 4 anchors rather than two? I only see two on the box photo unless I'm just missing something. I made 4 as instructed though. They were fun to make and I like the look of the black paper the kit provides, which is definitely a lot easier than bending little bits of metal!
Dave
Dave Barnard
Completed:
Marseille (Mamoli)
Link to comment
Thanks for the positive feedback everyone!
Making this little boat was more challenging than I expected.
I worked on it over the course of several weeks while doing other things. I forgot to taper the planks early enough and ran into some difficulty with that, should have followed the instructions better.
I did find it easier to glue bulkhead pieces to the base which kept everything steady and aligned while working on it and was easy to remove.
Dave
Dave Barnard
Completed:
Marseille (Mamoli)
Link to comment
Hi all,
I've completed all the channels, attached with glue and little pins as instructed and they feel nice and secure. Also did the little interior rails and I've been working on the cannons lately and will update those soon.... Have had a little more time in the shop lately so making some progress.
Dave
Dave Barnard
Completed:
Marseille (Mamoli)
Link to comment
Thanks for all the thumbs ups!
Quick question...I just noticed on the plans these little holes that must be for rigging lines later on that I had missed. I think I see on the rigging plan where some will go through these holes. There are 4 on each side of the ship that I can see.
To get the right size for the holes, I assume I just measure directly off the plans? I'm glad I noticed these before I did too much more because they would be harder to get to with more stuff in the way. I'll have to be careful not to have any splintering while drilling them too.
Dave Barnard
Completed:
Marseille (Mamoli)
Link to comment
Hi all,
I'm working on the chainplates with deadeyes now. I have seen others use this method with a piece of string to get them lined up correctly for the point of attachment, hopefully it is close anyways.
Usingmy miniature hammer gently on the nails into pre-drilled 0.45 mm holes.
Dave
Dave Barnard
Completed:
Marseille (Mamoli)
Link to comment
Well I finished up the chainplates recently which I enjoyed working on.
I thought I'd show how I dealt with the problem I was going to have of how the bottom of them was going to end up slightly below the wales as a couple others have experienced.
I just put a little curve into them as needed and it seems to look OK to me, better anyways than extending too far down.  One more thing to remember to try to avoid having to deal with on future builds.
Dave
Dave Barnard
Completed:
Marseille (Mamoli)
Link to comment
Exceptionally good work on Speedy all round. Very crisp and clean. I'm impressed by the kit too and glad I chose Vanguard for my next build.
Cheers,
Alistair
Cheers
Alistair
Current Build - HMS Fly by aliluke - Victory Models - 1/64
https://modelshipworld.com/topic/34180-hms-fly-by-aliluke-victory-models-164/
Link to comment
Thank you Alistair! I don't think you can go wrong with a Vanguard kit that's for sure.
Just a couple photos as I'm moving onto the masting and rigging.
I've been studying some of the other logs especially Derek and David L. and James and others and these are so helpful in getting started. I've only completed one kit in the past that had full masting and rigging and that was many years ago so I have a feeling this will be a long process but looking forward to it. I really like the crisp details of the plans that are included with this model. I thought about getting a mini-lathe as I see that's popular for making the masts and spars but I'm going to attempt it with my drill press and/or hand drill. Wish me luck!
Dave
Dave Barnard
Completed:
Marseille (Mamoli)
Link to comment
Dave, I just stumbled across your log, which shows wonderful workmanship. I can't wait to see how the masts and rigging progress. I'm also sending you a PM since we appear to live very close to one another!
Link to comment
Hi all,
I've been working on the masts and yards for the past couple months and it's been slow going. It's been a long time since I last did this kind of thing, and many of these parts are very small (I spend a lot of time on the floor looking for things I've dropped).
I tried some different methods and what seemed to work best for the yards was to do rough tapering with my mini plane and then used my drill press for the rest of the tapering using files and then sandpaper, and with a little fine tuning by hand after that.
For the masts I also used a plane razor blade for the square areas along with files of various types.
I can't recall who I borrowed this tip from, but leaving the mast parts a little longer at first and drilling holes through it with a toothpick inserted allowed me to keep everything nice and square along the length.
Now I'm beginning to do the blocks and I've referred to the many other build logs for advice which has been very helpful.
I am finally getting a little faster after installing the blocks onto one of the lower yards as seen in the photo. Many more to go!
I also bought the Quad Hands I saw on Derek's log and this is a great help to me so thanks for sharing that.
Dave
Dave Barnard
Completed:
Marseille (Mamoli)
Link to comment
Thanks for the likes as always!
Well it's been almost a month since my last update and I have made progress on attaching all these little blocks and lines. Many trial and error episodes to get things to look reasonably close to my references (other Speedy logs) and instructions. Quad Hands that were recommended have been extremely useful.
I see I probably should make a few adjustments yet but overall I'm happy with the results!
Dave
Dave Barnard
Completed:
Marseille (Mamoli)
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
