Fune by Alexandru - FINISHED - Japanese ship of 1868 - scale 1:50
The ruder and the mast are now in place - I can finish the upper deck. Here are some pictures of the progress.
Thank you,
Alexandru
For all my builds please visit my site at: http://www.AlexShipModels.com
Previous builds
Link to comment
Share on other sites
Thank you guys, I am happy that you find this build interesting.
Here are some more progress pictures.
There are two simple capstans under the quarterdeck which I turned from ebony. They are set between a beam of the main deck below and one of the quarterdeck above. In the middle between them there is a part of the deck that is a bit lower than the rest and is filled with sand to make fire on it for food cooking.
The quarter deck is planked with some planks running longitudinally and others athwartship - those in the middle (behind the mast) being mobile the rest were nailed and caulked.
Alexandru
Previous builds
Link to comment
What an extremely interesting build. So different and your skills are just great! Just going to pop over and make sure I haven't miised anything on your Vic build too.
I am most envious of all the skilled builders on here who make it look so easy (especially what they can do with power tools!!!!!!!)
Current builds:
MS Syren
HM Suppy
Dos Amigos
Completed:
Schooner for Port Jackson
MS 18th Century Longboat
Bounty Launch
Link to comment
Link to comment
Nicely made ladder - I assume you have a jig for assembling it.
John
John,
I don't have any jig to assemble the ladders. Once the notches are cut in the two sides on the mill in the same time as you can see in the first picture the assembly is manual. The only thing a bit "special" I do is to glue in place the first and last steps first then press it in a vise for a while so the glue sets making sure to preserve the rectangular shape. After that the rest of the steps are glued by sliding them in place. Nothing fancier than this.
Alexandru
Previous builds
Link to comment
Started to work on the rigging.
First thing I'we looked at is the main stay which in this case is covered with wood balls for some reason. Maybe because the smaller two masts in the front are attached to it and to protect the stay from their wind and wave induced movements.
The wood beads in my case were done on the lathe one by one from round stock. Problem with them is that they are not quite identical and they are to big for the scale of the model. When on the stay and in the final position as can be seen it the last two pictures - I didn't liked them at all.
I tried to do some of smaller size from 1/8in stock but it will take many more and forever to do. Biggest problem I have with this thiner stock is to properly centre the hole in the middle of the piece of wood. Wood bends sideways when spinning drill bit bends too as is smaller diameter and if the hole is off centre the beads on the string look bad. You can see some in the bigger size to in the pictures.
I will go see a beading store later today to check if I can find some ready made in proper size - at least all will look the same.
Previous builds
Link to comment
You are right John, it is quite different.
Here is the version 2 of the stay with bought wooden beads. They are a bit smaller and more uniform than those I made on the lathe.
In the second picture is the bigger of the two fore small masts being turned. Is not installed yet.
Alexandru
Previous builds
Link to comment
  • 5 months later...
The rigging is now complete. I liked this model as it has quite simple rigging - this being a part I don't particularly like to do.
Regards,
Alexandru
Previous builds
Link to comment
  • 5 years later...
super special
current build- Swan ,scratch
on shelf,Rattlesnake, Alert semi scratch,Le Coureur,, Fubbs scratch
completed: nostrum mare,victory(Corel), san felipe, sovereign of the seas, sicilian  cargo boat ,royal yacht caroline, armed pinnace, charles morgan whaler, galilee boat, wappen von hamburg, la reale (Dusek), amerigo vespucci, oneida (semi scratch) diane, great harry-elizabethan galleon (semi scratch), agammemnon, hanna (scratch).19th cent. shipyard diorama (Constructo), picket boat, victory bow section
Link to comment
Well done!
Building: 1:64 HMS Revenge (Victory Models plans)
On the building slip: 1:72 French Ironclad Magenta (original shipyard plans)
On hold: 1:98 Mantua HMS Victory (kit bash), 1:96 Shipyard HMS Mercury
Favorite finished builds:  1:60 Sampang Good Fortune (Amati plans), 1:200 Orel Ironclad Solferino, 1:72 Schooner Hannah (Hahn plans), 1:72 Privateer Prince de Neufchatel (Chapelle plans), Model Shipways Sultana, Heller La Reale, Encore USS Olympia
Goal: Become better than I was yesterday
"The hardest part is deciding to try." - me
Link to comment
Hello Alexandru,
Thank you for updating your blog. I'd forgotten all about this lovely project.
You've done a beautiful job with the model and you've given me quite a lot to think about here regarding the sails. I have been working on my own model based on a Wood Joe kit. Same basic type of ship, which is generally referred to interchangeably as a bezaisen or sengokubune.
I am particularly impressed that you were able to do so well using the Paris drawings, since they don't really explain how the planks fit the structure.
A wonderful build. I hope I'll be taking on a similar scratch build in the near future. I will certainly come back here for inspiration.
Clare Hess
He's a -> "HE"
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
