First Class Sloop of War Constellation by Jerry Todd - 1:36 scale - Radio
So, I stuck some pins in the aft hatch cover, and that seems like it'll do the job...
and the forward hatch is framed out.   This is a bit more complicated than it appears because of the blocking I installed for the through-deck fairleads that the hatches cut into to some degree and though incorporated into the hatch framing, still leave odd-shapes places that I need to fill in.  What's interesting is, in the case of Constellation at least, I really could have waited to have the deck on and planked before installing the fairleads - there's none of them I can't get at through all these hatches.
While the deck has some camber in it at the hatches, the framework underneath is flat, as is the ledge around it's opening.  I could have framed this all out before laying the subdeck and it would have been more structurally sound and looked a lot less like Frankenstien's monster.  I started down that road a long time ago when I intended to use PVC pipe caps for access hatches (these pics from 2009):
post-961-0-89530300-1418220391_thumb.jpg  post-961-0-32115900-1418220392_thumb.jpg  post-961-0-74434400-1418220392_thumb.jpg
I didn't got with that because the opening was too small for me to get at anything through it.
Macedonian will benefit from this experience at least  :)
Edited by JerryTodd
Jerry Todd
Click to go to that build log
Constellation ~ RC sloop of war c.1856 in 1:36 scale
Macedonian ~ RC British frigate c.1812 in 1:36 scale
Pride of Baltimore ~ RC Baltimore Clipper c.1981 in 1:20 scale
Gazela Primeiro ~ RC Barkentine c.1979 in 1:36 scale
Naval Guns 1850s~1870s ~ 3D Modeling & Printing
My Web Site
My Thingiverse stuff
Link to comment
Share on other sites
I'm going to use some soft closed-cell foam on the ledge for the hatch to sit on.  It should conform to any imperfections in my workmanship.
The fellow in the RC club I was in just put petroleum jelly on the two surfaces.  It kept out the water just fine.
Bob
Current build:  SS_ Mariefred
Link to comment
  • 2 months later...
"Janniary was some cold hon!" said someone from Baltimore back when February started - I'll wager they've forgotten January now.  It didn't get above freezing for more than 3 days this month past, and they weren't three days together.  The average high for the month was 26° f and the average low was 19° - the coldest February for this region in recorded history.  Today it's 26° f with rain, snow, and sleet, with more coming and a forecast low of 19° f - ie: an average day.
My garage workshop doesn't have heat, so I've brought things I'd rather not have freezing into the house; glue, paint, batteries, etc.  Hopefully it'll be warmer sooner than later and I can get back to work laying Constellation's deck - along with making a Civil War field desk, a folding table for the desk, a Rev War folding cot and stool, another sea chest, and three hanging shelves to go in the loo.  I'm also extending a duct from an upstairs bath into the garage ceiling to blow in heat and AC so I can bear the summer and not be froze-out next winter.
The real ship is back in the water hoping the ice will clear enough for her to be moved to where her rig will be set back up, and she'll go home.
post-961-0-84164200-1425231646_thumb.jpg Feb 28, 2015 at Coast Guard Station Curtis Bay, Maryland.
Jerry Todd
My Web Site
Link to comment
Hi Jerry, just been enjoying both your constellation and Macedonian builds. They are great builds and very informative. I'd love to do something similar one day.
What are your ballasting/keel plans?
Link to comment
Here at the end of March and it's still cold.  We got one day that peeked at 70°f but it rained and rained and the next day it dropped to the 30's again.  I gotta get some heat (and AC) into that garage.   They say it's supposed to get into the 60's during the week, so maybe I can finally get back to work.
Timmo;
Constellation's ballasted with a 2" id PVC pipe filled with lead bird shot and weighing about 42 pounds.  This is attached to the hull via two ss threaded rods through aluminum tubes in the hull.  The tops of these rods are hidden by the stove-pipe forward and the cabin skylight aft.  She'll also get about 15 pounds in lead-shot "bean-bags" inside the hull to bring her down to her lines and trim her.  My drawing of the model at the beginning of this log shows the pipe at the bottom of the hull.  This gets the weight as low as possible and being detachable, makes the model lighter and a bit easier to handle out of the water.
Macedonian will be getting the same basic treatment though I might use a steel pipe instead of PVC to get the same weight in a shorter pipe.
Edited by JerryTodd
Jerry Todd
My Web Site
Link to comment
Finally Spring has arrived and I got into the shop to get some work done - most of it Civil War stuff for an upcoming event, but I at least got started on Constellation's deck!
I'm using CA to glue the planks down to the fiberglass over plywood subdeck, and permanent marker for the plank seams.  Once I get the area around this hatch done, it'll go pretty quick until I get to the forward such hatch.
The aft pivot gun will be mounted on this hatch, and I'm thinking I'll make it so that twisting the gun carriage latches the hatch shut.
Jerry Todd
My Web Site
Link to comment
Making some progress.  The aft access hatch requires fitting nearly every piece and makes it a bit tedious, but it's going along...
post-961-0-41891100-1428448576_thumb.jpg  Monday
post-961-0-00533900-1428448577_thumb.jpg  Tuesday
Jerry Todd
My Web Site
Link to comment
Gerry, great that you are able to get back to the garage to continue your work on the model. I had to do the same thing and move anything that would freeze when we went away for a week in February.
michael
Link to comment
About 60 pieces laid down so far.  Painted the hatches and hatch wells...
post-961-0-86866400-1428689036_thumb.jpg  post-961-0-54276800-1428689036_thumb.jpg
post-961-0-13951400-1428689036_thumb.jpg  post-961-0-23174300-1428689037_thumb.jpg
Jerry Todd
My Web Site
Link to comment
Hi Jerry
Nice job! I must admit that I didn't realise how thick the deck planking was until I saw your first photo above. Is the thickness to allow for the sanding, or just for overall structural rigidty?
Either way, I'm just curious, because the deck's shaping up to be a beauty.
Cheers
Patrick
Link to comment
Sometime during the Cretaceous period (2009 to be precise), when I designed and installed the deck beams, I got it into my head to make it all this thick.  The plywood was what I had on hand, so that's easy, but I can't for the life of me recall why I opted to make the deck planking this thick.  Not just the deck, but the deck beams as well, there's no need for them to be as large as I've made them.  Pride is done the same way, but set up to use 1/16" (1mm?) planking.  In her case the planking, while thinner, is about twice as wide, and using CA to glue it down may be an issue.  Macedonian is going to use 1/8" luan plywood (door-skin) for a sub-deck and 1/16" thick planking over that.  A 4' x 8' sheet of door-skin sells for about the same as a 1' x 2' sheet of 1/16" aircraft ply, so I'll get thicker decks, but I get fo'c's'le, quarter deck, and gundeck with a good bit of ply left over for a whole lot cheaper.
Edited by JerryTodd
Jerry Todd
My Web Site
Link to comment
I was on a roll until I ran out of glue...
post-961-0-70441300-1428873363_thumb.jpg  post-961-0-68342600-1428876056_thumb.jpg
Edited by JerryTodd
Jerry Todd
My Web Site
Link to comment
Got TWO bottles of gel CA and continued with a few more strakes up the port side, and got down a lot of the foredeck area.
post-961-0-70242900-1428976974_thumb.jpg  post-961-0-30403800-1428976975_thumb.jpg
Jerry Todd
My Web Site
Link to comment
Since this is on operational model I did not see what you used as a water tight seal with the deck and the hatches.
David B
Link to comment
There will be a bit of gasket material in there - there's some card stuck there now to take up the space while I fit the decking.  I'm not going for "water-tight" more like "water-resistant."
Today I hope to get the aft end planked and work up the port side.  I'm thinking it'll all be down by Wednesday.  There's a cap that goes all around the edge of the deck, it's more like a log.  I have to piece that together around the bow and stern, the sides are simply a nice long piece that springs on.  I got a bag of bamboo skewers I'm going to use as tren'ls to anchor that down.  While she won't be "finished" at that point, she'll look more like she is.  :)
I need to turn the spokes for the wheel and those bowling pin stanchions, but none of the wood I have handy is working out for that.  I had a little boxwood which I think will do great, but I haven't been able to find it.
Jerry Todd
My Web Site
Link to comment
She's looking good.  I like the layout.  We used to smear the gaskets with petroleum jelly to help with the water resistance.
Bob
Link to comment
I ain't touching that till there's a sealant of some sort on the deck  ;)
Jerry Todd
My Web Site
Link to comment
I got a bit more done.  The forward access hatch is nearly covered and that will finish all those fiddly bits dealing with it's seams.  The aft hatch is done and there's decking from stem to stern, now it's filling in the bow quarters.
post-961-0-41465200-1429068854_thumb.jpg  post-961-0-78932200-1429068854_thumb.jpg
If the glue and the wood hold out, I should have it done tomorrow.
Jerry Todd
My Web Site
Link to comment
Got the port side planked up except for some "corners" to fill in.  Didn't get to finish the whole deck - such are the best laid plans of mice and men.  But then, there's tomorrow.
post-961-0-12551200-1429154702_thumb.jpg  post-961-0-56698500-1429154702_thumb.jpg
Jerry Todd
My Web Site
Link to comment
Looks like you're still having fun...  at least I hope you are.  I find the RC ships fascinating for some reason even though I'd never build one myself.  Bad memories from my aircraft days, I guess.
Link to comment
I'm not too concerned with it falling a hundred feet and shattering.  To me it's sailing a boat with a really long invisible tiller.  ;)
Jerry Todd
My Web Site
Link to comment
The ex RC flyers in the RC boat club used to say they switched because when/if it crashed it was a lot cheaper to fix.
Bob
Link to comment
The deck is down, even scraped, sanded, and given a wipe of satin poly...
post-961-0-18534300-1429219386_thumb.jpg  post-961-0-65838400-1429219386_thumb.jpg  post-961-0-08461900-1429219387_thumb.jpg
post-961-0-50892000-1429219387_thumb.jpg  post-961-0-89000700-1429219387_thumb.jpg
Jerry Todd
My Web Site
Link to comment
Link to comment
I installed the cap rail, or cap log as I call it.  It covers the perimeter of the whole deck.  An angled piece will go inside of it as the waterway, but we're not that far along yet.
Here a fellow's setting a hammock iron on the real cap rail.
I got 4 3/8" x 1/4" x 48" bass strips and two of them were simply spring into place port and starboard.  Tren'led every 6" with round toothpicks, and since I couldn't clamp it down very well, I put in copper nails between each tren'l.
I wiped a little cherry stain on the strips before fastening them down.
I cut one of the remaining 2 strips into 3-1/2" lengths and glued them up side-by-side to make 6 1/4" x 3/4" x 3-1/2" blocks
A made a card stock template of the stern and used that to shape the blocks and piece together the cap rail around the stern.
post-961-0-99193400-1429303599_thumb.jpg  post-961-0-43026600-1429303600_thumb.jpg
Jerry Todd
My Web Site
Link to comment
Started on the hatch coamings before finally calling it a day
post-961-0-10247000-1429370424_thumb.jpg  post-961-0-57805700-1429370424_thumb.jpg
Jerry Todd
My Web Site
Link to comment
Ah spring time.  The air is full of fumes from glue, paint, and mineral spirits.... not to mention the neighbor's lovely smelling fertilizer.
Today I continued on the hatch coamings; trimming, fitting, and building the battery hatch cover.  Everything, and the hull got some paint to spiff things up a bit.  I really need to figure out making hatch gratings with what I have.
post-961-0-10540500-1429402888_thumb.jpg  post-961-0-58806400-1429402888_thumb.jpg  post-961-0-97001800-1429402888_thumb.jpg
Jerry Todd
My Web Site
Link to comment
Only got a couple of hours in the shop today and managed to turn out this little item:
post-961-0-95941500-1429501094_thumb.jpg  post-961-0-28427800-1429501095_thumb.jpg
Jerry Todd
My Web Site
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
