Le Fleuron by Gaetan Bordeleau- 1:24 - Finished
Hi Druxey,
Darker white will be last. With this stove,  I want brick and mortar but there are  many difficulties. First the colors, could be right by painting as I tried earlier with the bakery oven for the bricks but no mortar. With this stove lines are straight and it should be easier to introduce mortar. Again it would be too soon to paint the mortar because at the end of assembly, sanding will be needed and it would sand a lot of paint. So to retain the color I choose a full color in the wood. The mortar is surely too white, I realize it is also too thick when I look at the pictures, even if I taught the thickness proportion was fine when I cut it. I did it by eye but I should have done calculate some proportions.  The most difficult width to obtain is the top panel with the curve. Ideally I should have done the panel and then do sides and bottom, but I did the contrary and the width does not fit exactly so I had 2 layers of mortar at 2 places. Assembly is not so easy also. horizontal mortar lines are easy but not the vertical lines are difficult because it is difficult to cut to the good lenght and to install. In fact this is exactly for this kind of reasons that I prefer to build at a bigger scale, to have a bigger ease to hold parts and enjoy the construction instead of worrying how to hold the small parts.
I do not know what would be the best method yet but it is surely fun to try few ones.
Link to comment
Share on other sites
Here are the ''targettes"".
    first 3 pictures with different lighting :
Off camera flash
Speedlight
Ambient light
No flash, no details
Without flash, it is difficult and sometimes impossible  to see small parts details.
For these pictures, scale is 1/24, which is big, so imagine  at 1/100 without flash!
Edited by Gaetan Bordeleau
Link to comment
What surprised me, Geatan, is the difference between the images, not as much the colour - for that I expected, but for the red glow - however, the focus on the first seems much better than on the other two, which are with lighting oddly enough ...
Carl
Link to comment
Carl,
-no attention or correction was given to the color, the red  could be  corrected  before and/or after the picture
-attention was given only to  sharpness
-the difficulty is this image is to see the 2 black straps on a black plate
Is the focus in the first image? May be.
Would it have been possible to do as well with the 3 images? probably with more time, it was just a fast comparison
The idea was just to demonstrate:
the importance of lighting which is neglected as much in model building as in photography
and the possibility to see more with a good lighting
Link to comment
Seeing your reference, Gaetan, have you tried melting the end of the brass rod to form the 'bouton'? I've found that by holding the rod or wire vertically (not with my fingers!) and holding the torch at about 45 degrees, the tip of the metal will melt and form a round ball. You could then flatten it if you want.
Link to comment
Adding some  little details.
Here are some ideas about the 2 doors aft the second deck to go to the bathrooms.
Door knobs are always installed to the right because most of the peoples are right handed.
The port one open from front to aft.
The starboard one opens from aft to front.
Knowing that  deck is  higher aft than fore;
It is easy to open the starboard one and there would be some space under when open.
The port one was a bit more complicated because the door opening from fore to aft would want to enter in the deck which is impossible.
The easy way to solve this is to cut the door from the bottom so that the bottom  does not get stopped by the deck.
In addition reinforcement wood angles are installed in each corner.  The height of these pieces  passes just in front of these doors.
May be all of this is false. If We compare with a picture already shown in this forum, there are 2 doors.
On one the door knob is to the right and on the other the door knob is to the left.
But at least we agree on 1 thing the bottom of the door had to be lift  so that the door could be opened.
Link to comment
Hi Gaetan,
I'm interested in the third hand I saw in one of the above pictures, because I'm not very keen in the usual alligator clamps.
Could you tell me where you acquired them and at what price ?
I live in Europe (Belgium).
TIA,
Marc
Keep on modelling,
Marc
Link to comment
The table on the first photo looks very good, like a fullsize slab table :)
Hi Marc
http://www.grstools.com/for-jewelry-work/third-hands-and-soldering-stations/third-hand-with-soldering-station.html
This tool was acquired from a jewelry tool seller and it is not comparable to the usual alligator clips.
Link to comment
fantastic work and stunning photos gaetan
The clerk of the cheque's yacht of sheerness
Current build HMS Sirius (1797) 1:48 scratch POF from NMM plans
HMS Winchelsea by chuck 1:48
Cutter cheerful by chuck 1:48
Previous builds-
Elidir - Thames steam barge
Cutty Sark-Billings boats
Wasa - billings boats
Among others 😁
Link to comment
No words, Gaetan.  The pictures have stunned my brain cells.
Link to comment
Hi Gaetan,
I've been following your build from the earliest posts. The combination of your build and photographs can only be described as model ship building porn!
Best,
John
Member:
Connecticut Marine Model Society
Model Ship World
"So we beat on, boats against the current, bourne back ceaselessly into the past" F. Scott Fitzgerald - The Great Gatsby
"If at first you don’t succeed.......skydiving is probably not for you”
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
