Le Fleuron by Gaetan Bordeleau - FINISHED - 1:24
Thank you Peter even if you have some exaggerated words.
Here is an idea of the outside representation with the black still wet.
Asphalt powder diluted in turpentine plus tung oïl
Black water  tint Samona
Edited by Gaetan Bordeleau
Link to comment
Share on other sites
Here is what  happened since the last update,
Building a ship is fun, but building it in good conditions is even more fun. Building this size means that standing for long periods of time is a common thing. For this reason, I searched an ergonomic mat to work on and ended with some kind of rubber mat. Standard ergonomic mat are made to stand on. They are not made for compression meaning that a heavy trolley would sink in this kind of carpet. This is exactly what I saw with the version of the working desk 1.0 and also for a rubber mat a hard plastic caster wheels are needed.
To correct this problem, the working desk will be cut in 2 parts a multidrawer unit to store all the small tools and a desk. The 16 drawers unit is made from cherry and as all the big tools, 4 caster wheels to move it easily. As I realised with the electric table that working at the good height makes working easier, we usually have a height adjustable chair with an oil chuck. If we look the problem from the other side a height adjustable working desk can make the life easier.
I bought the electric mechanism, built the top of the table and kept some old parts from version 1.0 table and now here is version 2.0 of the working desk. To keep the table as low as possible in the lowest possible, double caster wheel are used.
Link to comment
You have been busy, Gaetan.  Nicely done on the desk and work area.  I'm flat envious.
Link to comment
Having some cherry wood a second table is done to be use as a base for the 74 guns.
Here is the kind of finish I used this time. I had an unfinished bottle of teak oil. In it I added about 1 table spoon of natural bitumen which is a black organic pigment used to age wood. On this forum, Russians showed good examples. 1 coat applied. For the low luster finish I like the effect of bee wax. I did a rolling top desk about 30 years ago and used bee wax as a finish and still today, it is as nice. Shavings of bee wax block are put in a jar with turpentine, again to accelerate the aging process some bitumen is added. Very easy to apply with a rag let dry  and luster with and electric buffer.
Sorry Karl I just saw your question. I use standard belt sander  for fast removal and 1 orbital sander,  5 inch disk for finishing.
Link to comment
Here are few notes about the construction a part which is a very good example for the use of the milling of the holes for the sheaves which is done in 3 steps:
The length of the milling cutter being about the half of the thickness, grooves are milled half way
A drill bit is use  to break through the part. These holes bored at one end only will serve as references to mill the other half of the thickness
The part is then turned 180 degrees and the other half is milled
Then the scroll saw which has to cut some angles which are about 1 inch thick needs the appropriate blade. Mainly I use 2 kinds of blades from Olson; one for thin and one for thick cuts. I am not sure about the name but it is about skip-tooth or reverse tooth  . No sanding is required after the cut. The combination of the Hegner scroll saw and the blade allows to cut in straight line with precision and even to cut as thin as paper if required and with 0 vibrations.
I tried to work at different heights on the table and I continue to believe that working at the ‘’good’’ height makes the difference at least it makes the job easier. As an example, here is a picture in Junghans German watch office.  Another advantage for the Jewelers to work on a high table allows them to see their work closely.
Link to comment
Here is an update on the first deck. Many parts are fixed in relation with the beams of the second deck, so they are also needed. Many parts are still not glued yet. Planking is mostly completed. 2 areas are needed, in the middle and on port side but just enough to supports guns. The idea is the more planking is done the less we can see inside and in fact it is just the opposite effect which is wanted.  Animal park can be seen on the last 2 pictures.
Link to comment
I stopped working inside and did some work fore and plane the fore mast made from 7 parts.  Actually, it is easier to plane round than what we could think. To be able to install the rudder upper metal fitting, it needed 1 layer of plank before.
Link to comment
superb modelling Gaetan,
you sure are pushing the degree of skill skywards....
would love to see more of your fabulous woodwork and Fitting out as you go on
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Yes Nils I will!
Also here is an old tool but a new tool for me which could have some interest for our hobby.
 This tool is use to locate a point on a sculpture which is done on a new sculpture in work.
May be I could use it when I want to build something on both sides of the ship?
Link to comment
Is there any more complex part of the ship to model than the transom and quarter galleries with all those compound angles? Keep those wonderful photos coming Gaetan.
Greg
website
Admiralty Models
Finished build
Pegasus, 1776, cross-section
Current build
Speedwell, 1752
Link to comment
Image 1 parts are done with white cardboard which
-Lines are copied on a transparent paper from plans then glued with Pritt paper glue on a white cardboard
-Copied directly from the model
Image 5 made from 2 planks with a groove for assembly
Image 7
  1. actually working on the balcony ramp made from 3 parts: 2 sides and 1 back
  2. same kind of assembly for the lower rail for the balcony. Alignment of sides is done with a plank resting on side planking thus giving exact parallelism between each one
  3. template made from 2 parts to give parallelism between the 2 rails
  4. the assembly of the side balcony ramp on the vertical post is done exactly as when assembling  a cross
Link to comment
Thank you John,
Up to now, all the pictures presented were in automatic mode. Circumstances made that next week will be the last part of Photography for the beginner. As for each week, we must try few pictures, so I develop a subject already tried but this time in manual mode!
On the second picture, by changing the camera angle the distance between the figures changed.
On the third picture, different tries by adding a white transparent curtain to soften the neon lighting coming from the ceiling.
Link to comment
Love the photography.  They, alone, are works of art.  You're taking build logs to a whole new level, Gaetan.
Link to comment
Gaetan,
Beautiful work. The French stern has many more flowing and intersecting curves than an English stern, causing not only extra challenges for the original draftsmen, but also for a contemporary model builder!
Best wishes,
Link to comment
Glued evrything except the 2 back ramps for further easy  access
Planking over side structures
Box framing each side dry fitting
At this stage dry fitting is essemtial because I could not arrive and fix parts at the first throw; I have to think calmly  and slowly progress with each part to his shape and position in relation with the rest. Slow process but interesting!
Link to comment
Gaetan,
The process may be slow but the results are stunning.
Link to comment
The use of the original drawings are necessary to understand the scluptures composition because there are too many differences  with the other provided drawings.
Actually, I am working on the upper moldings and trying to evaluate their composition.
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
