Le Fleuron by Gaetan Bordeleau - FINISHED - 1:24
That is one fantastic build you have there  :)
Just wondering, when did you start to build this ship and do you think it will be finished?
-Hans Christian
Current build
      -La Belle 1684 (Scracth build)
      -Oseberg (Billing Boats) (On hold)
      -Falmouth (Euromodel) (On hold)
Link to comment
Share on other sites
Link to comment
Thats a big project Gaetan. You need a construction crew. At the rate you are going it will be an antique before you are finished  :)  Its beautiful work BTW. Bill in Idaho
Bill, in Idaho
Completed Mamoli Halifax and Billings Viking ship in 2015
Next  Model Shipways Syren
Link to comment
That ball vise is the ticket for handling small parts and carving badges and scroll work. Are you buying or making your blocks etc. when you get to the rigging part. Will it have sails? Do you have a good plan for where all the running rigging lines belay to on deck? Bill
Bill, in Idaho
Link to comment
Bill, this model is 100% scratchbuilt. I will not install sails. The model would not pass through the doors. The model is made like admiralty style, planked on one side only and no masts. The only blocks I will do are for the cannons. I did not study plans for the running rigging.
David, I bought this vise from a jewelry tool store in Montreal, but it is coming from:
http://www.grstools.com/workholding/vises-and-blocks/standard-block.html
If you want to buy only one, buy this one, because it is not 1, 2, or 3 axis but this is a multi-axis adjustment. Also when I push a mini carving knife, the vise is adjusted so that the motion is from down to top which makes the movement more controllable. This vise was created for engraving, it does allows the knife to be pushed also in a circle motion with an adjustable tension mechanism.
Link to comment
first picture is a needle head.
Different lenses, different tasks;  question which come back regularly
1-2- precision small work, longer focal length allows to work with a straight back. Very useful for splinter
3-6- closer focal length than 1-2, the work must be closer than 1 foot. To have a comfortable working position, the table must be higher like jewelry table
4-5 lightweight version
7-8- the use of magnifier automatically means that you will need more light to see clearly. By example,7 is use when I take picture to the microscope. Also the weight of the light is held by the head strap.  A good LED headlight can also be an interesting avenue to see
1-2-  6X+ 3,5X   focal lenght > 18’’
3-6-  focal lenght < 10’’
4-5- installs on eye wear
7- 8- frontal light
9- magnifying glass
Link to comment
I am jealous.  Do you use a halogen or xenon light source for your headlight?  When I was making balusters on Victory I used to bring wood in to the office and carve them under the operating microscope.   Drove my nurse nuts.
Toni
Chairman Nautical Research Guild
Current Builds:     NRG Rigging Project
Completed Builds: Longboat - 1:48 scale       HMS Atalanta-1775 - 1:48 scale       Half Hull Planking Project      Capstan Project     Swallow 1779 - 1:48 scale               Echo Cross Section
Link to comment
Link to comment
Hi Toni,
Pilling Weck Xenon light source
Hi Grant,
Optivisor would probably  satisfy most of your needs.
The lens  number 4 is the one I use the most.
Also I like to use the Optivisor, when grinding  and polishing small metal parts, it is safer for the eyes and I can observe the part closer while working.
Link to comment
Gaetan, all you need now is a few model-building robots.  Amazing array of gadgets.
Ed
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
