Duchess of Kingston by ECK - FINISHED - Vanguard Models - 1:64
Outer hull done. Next will be the deck fittings.
IMG_6063.thumb.jpeg.5dce3cff56c8cecacb2564dd170faf2d.jpegIMG_6058.thumb.jpeg.035845cb6fa6672698fca2e0254dee80.jpegIMG_6061.thumb.jpeg.dcee928030cf32bd80c0359720612e2b.jpegIMG_6062.thumb.jpeg.24d152321156fa6b579c15d28eac5a22.jpegIMG_6064.thumb.jpeg.5d69ebcfb8dda7d5aef295014a2e9b7d.jpeg
One issue that came up is that the 3D printed dome for the main entry to the stern cabins was way to small for the hole it had to cover so I had to make one out of balsa wood.
You can see the side by side size difference.
Link to comment
Share on other sites
Most of deck done.
IMG_6076.thumb.jpeg.ffb3fca8a94a3b31a4bba31c4bd81047.jpegIMG_6077.thumb.jpeg.d41bec0832753b80951140aa9f55f863.jpegIMG_6077.thumb.jpeg.d41bec0832753b80951140aa9f55f863.jpeg
Now for the problem that vexed me .  The stern rails pillars are extremely fragile. The are much smaller than on the Sphinx. The grain also goes across so easily brocken, which of course I did. Multiple times and as a result I had to remove them all and fashion new ones from 3x2 mahogany strip. I drilled holes on top and bottom to pin them in. With paint and all worked ok. Not perfect and clean as the original but much sturdier. Otherwise I would have to have an entire sheet sent from across the pond.  Unless you are very close, I think it looks ok. I think the rails and pillars would be best 3-D printed.
IMG_6078.thumb.jpeg.73f0180e777ecb99613b1252e0345c3b.jpegIMG_6080.thumb.jpeg.fe2ce68332d4cb1ef3f4d1bd42620b3e.jpegIMG_6081.thumb.jpeg.83a8602d008c483c85cfb582703a7f62.jpegIMG_6082.thumb.jpeg.d61b48bebfa68fa1be24d907e2ff3d38.jpeg
Another issue is that the pictured cannon assembly in the manual is not the same as the parts with the kit in that the the holders of the cannan are integral to the piece and not something you add later. Assembly is as seen in the HMS Sphinx instructions.
Link to comment
Yards done and mounted. I prefer doing some of their rigging now for easier access. Next will start the shrouds this weekend. In the background you can see a future product, another Chris Watton project designed in an earlier life. Likely will do the Indy first as I ordered it immediately when it became available.IMG_6153.thumb.jpeg.47463f14918c577619f721b76b73ab11.jpegIMG_6155.thumb.jpeg.f1d3bf4e137e1671a9291326fcf2d343.jpegIMG_6156.thumb.jpeg.5795dd18684f31e5334412df5156ff29.jpegIMG_6154.thumb.jpeg.e5dd8141b1714904155e25809e242b4d.jpeg
Link to comment
I usually spend a couple of hours on week days and 4-5 on weekend days. As we have an empty nest it gives me something to do after walking the dog. I find it very stress relieving after work to decompress although occasional profanity when something messes up during the build. For example, I accidentally used 0.25 mm thread on the upper shrouds instead of 0.1 so had to redo although easy as the ratlines were already in and glued. The kit instructions are also very well easy to follow especially after doing some others which were not
Link to comment
Well, it looks like the hours you spend at the work bench are very productive.  I find there are two kinds of mistakes.  The "best" are those that you can correct; the "worse" are those that cannot be corrected and must be lived with,  worked around or hidden.
Completed Builds:  USS Cairo by BlueJacket;  Nave Egizia by Amati;  Harriet Lane by Model Shipways
Link to comment
Well, finally finished her. Nice little project. Don't know what to do until I get my Indy . I have HMS Swan you can see in the background but hate to start because I would have to put her aside when Indy arrives.IMG_6200.thumb.jpeg.02a3011d784a0cfbb3f455d10c2ecf1e.jpeg
IMG_6202.thumb.jpeg.1d42ab0a60b35189ee55839518872b16.jpegIMG_6203.thumb.jpeg.59cd4351eb30822a62062947199fe5e2.jpegIMG_6204.thumb.jpeg.c49a947a11b7c7340446b989b7628b2f.jpegIMG_6205.thumb.jpeg.b5fa57681d51d4237563acb320895dae.jpegIMG_6207.thumb.jpeg.50a6886e77ef3feb498cbc077052e22c.jpegIMG_6208.thumb.jpeg.8ccf79e9c7a2552f753ff380447479e4.jpegIMG_6210.thumb.jpeg.1102cafb81f7f85feee6df0cfcc9512f.jpegIMG_6211.thumb.jpeg.39d1ac56ceb15aff7f26948008cfe13f.jpeg
Few shots Of Admiral Cochrane visiting for scale
IMG_6212.thumb.jpeg.00b65ac016a2243ee82516e90a37b45d.jpegIMG_6213.thumb.jpeg.910a799cff7091641f67cf81a7395ea7.jpeg
Anchored next to HMS Sphinx, HMS Agamemnon in backgrond
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
