This is going to be a POB model, so i think legos will do for ensuring the straightness of the frames. I will, in fact, need something larger than a soldering iron to bend planks, this is a 1/24th scale model (yes, i changed the scale to more closely fit my desired length).
Can I suggest you ask a moderator to shift this thread from where it is to "Build Logs for Scratch Projects - Up to and Including 1500 AD"?
Basically what you're doing at the moment seems more appropriate to an actual build log than to  "discussions for ships plans and project research" - it's more to do with a specific model (your own) than to the more general field that this section usually deals with.
And it means all this preliminary research and development information will be available for viewing when you actually begin to make sawdust, rather than being in a thread that then needs to be looked for separately.
Best wishes,
Steven
I just edited the name to what i wanted the log to be called. Well, this does make it more efficient so that when wood does eventually get cut, i do not have to make another log or transfer all the research over. After all, Woodrat started cutting wood on page 2 of his own log. Personally, i think the point at which building actually commences is more of a page 3 or 4 thing for this one.
Каррака корабль (42 фото) - красивые картинки и HD фото
Here, we get a good look at the interior of the Mataro Carrack. I would like to bring your eyes to two points on the ship: The interior bulwarks and the exterior planking. First, the interior bulwarks. The interior walls of the ship are, in fact, fully planked. However, the exterior top rails on the sterncastle are long gone. However, this damage to the ship may be a good thing, as it allows us to see into the walls to have a look at the framing. The frames on the Senora Fielden, at the point where they rise from the main deck level, are to be a quarter inch thick by the half-inch thickness of the frames. I may or may not fair the thickness of the frames down as they go up toward the top, to increase stability and reduce weight. I chose the half-inch thickness for two reasons. 1: to increase the sturdiness and stability of the relatively large model. 2: to provide a large area on which to glue the ends of the strakes.
The other issue of concern is how the exterior of the ship comes together. As you can see, as opposed to Woodrat's Venetian Carrack, the spaces between the deck beams are planks. Also, the scuppers are not hidden within the deck beams, but rather adjacent and slightly raised, to slightly above the deck level. The raising of the deck will be, once again, a quarter inch at the deck's widest point. This will decrease proportionally as the deck narrows.
Edited by Ferrus Manus
One other thing to note is the futtock riders. In the almost 600 years of this ship's existence, most of them have likely fallen off. (the Amati kit is ridiculously inaccurate, even to the current Mataro model) and a real carrack from around that time should look like this:
There are artist errors in this ship as well. Many depictions of carracks omit the futtock riders, but that is likely in the interest of simplicity. There would probably be three midships futtock riders, and three for the sterncastle.
are you talking of length of keel or length between perpendiculars? It makes a difference. Let us assume it is length of keel. For venetian galleon 16th century Pre Theodoro gives keel length to breadth ratio as about 2.6:1. This would be higher if you use length between perpendiculars. For an english galleon of 16th century length to breadth about 3:1. BUt thise is not likely for a 15th century nao. I imagine spanish would be similar to venetian in most regards.
As far as 15th century practice, have a guess but I would say 3:1 is a tad high and would tend to go for the ratio of 2.5:1 (I base this on the figures given for venetian naves in F C Lanes Venetian Shipbuilders of the Renaissance. There were no set rules and shibbuilders varied.
Dick
Edited by woodrat
Current build:
 Le Gros Ventre 1:48 POF   http://modelshipworld.com/index.php?/topic/564-le-gros-ventre-by-woodrat-scale-1-48-pof-1767-french-exploration-vessel/
Past builds:
Mycenaean War Galley by Woodrat - 1:48 - Shell first Plank on Frame:https://modelshipworld.com/topic/33384-mycenaean-war-galley-by-woodrat-148-shell-first-plank-on-frame
Venetian round ship 14th century by Woodrat fully framed - 1:40 scalCompleted
https://modelshipworld.com/index.php?/topic/17991-venetian-round-ship-14th-century-by-woodrat-fully-framed-140-scale
Venetian Carrack or Cocha 1/64 by woodrat   https://modelshipworld.com/index.php?/topic/4915-venetian-carrack-or-cocha-164-by-woodrat        completed
United States Frigate Essex 1:64 POF   http://modelshipworld.com/index.php?/topic/4496-usf-essex-by-woodrat-scale-1-64-fully-framed-from-takakjian-plans/ - completed
Yenikapi12 by Woodrat - 1/16 scale - a small Byzantine merchant vessel of the 9th century
https://modelshipworld.com/topic/23815-yenikapi12-by-woodrat-116-scale-a-small-byzantine-merchant-vessel-of-the-9th-century-finished/
The Incredible Hulc by Woodrat - an experimental reconstruction of a mediaeval transport
https://modelshipworld.com/topic/25641-the-elusive-hulc-by-woodrat-finished-a-speculative-reconstruction-of-a-mediaeval-merchantman-132-plank-on-frame/
That response gives a great deal of insight into my build. As for the l/b, i would say it would have to be length between perpendiculars, that is, including the stempost and sternpost. If the l/b in relation to the keel only were 2/1, then the total l/b would be about 3/1. Let's assume the lbp/b is 2/1. This would give us a total l/b of approaching 2.5/1.
With Woodrat's assistance, i am weaning myself off the Mataro Model when it comes to exact measurements.
From the wreck of the Geonoan carrack La Lomellina (sunk 1513, probably built 1503), the estimated proportions were Length of keel 33.38 metres, width at master frame 14 metres, overall length 46.45 metres. IIRC they recovered the whole length of the keel and over half of the ship amidships, (she sank on her side, like the Mary Rose) so these estimates should be pretty reliable.
That gives the ratios
length of keel to width = 2.38
overall length to width = 3.32
You could also check out the Newport ship, though much less of the upper hull has been preserved because she sank upright, so you may not be able to determine the full width of the ship.
Steven
Chisels:  I have a set of Stanley “yellow handle” chisels that were new (to my father) in the 1950’s.  They seem to hold an edge well.  I also have a 1/8in and a 1/16in chisel bought new from a specialty woodworking tool distributor.  The most often used tool of the group is the 3/8in chisel from the Stanley set.  I find the larger blade to be easier to control than the smaller sized tools.
One “tool” that does not appear on your list is an effective sharpening system for your chisels and plane.
What material do you plan to use for building your model?  If you will need to reduce lumberyard or other bulk lumber into special sized strips then you will need access to a table saw or bandsaw.
Roger
The larger carracks might have been slimmer than smaller ones like the Mataro ship. Also, different eras and places would certainly produce different designs. The Lomellina Nave was built over 50 years after the Mataro carrack, and was likely almost twice the length. What type of wood would be ideal for working on the frames and central assembly? Remember, these structures will be relatively bulky due to their large scale and increased thickness.
I would suggest only using length of keel/breadth of midship frame and forget I ever mentioned length between perpendiculars. I still suggest 2.5 as a starting point.
If you are planning POB at large scale, you are going to need at least a jigsaw or a fretsaw and elbow grease and I would suggest good quality plywood. Dont rush in. I spent years collecting and making tools before I cut the first wood for my first scratch build the USF Essex. Use the collective hive mind of the MSW tribe to its full extent.
Dick
Current build:
Past builds:
It seems as though 2.5 would be more appropriate as a total l/b. None of the proto-carracks i have seen in Steven's collection had a l/b slimmer than about 3, and most of them were about 2.5, or thereabouts. The Venetian carracks, particularly the larger ones, may have been slimmer.
13 hours ago, Ferrus Manus said:
So the total l/b would be about 3/1?
I dont know what total l/b means! Please use length of keel/breadth of midship frame. It is explicitly documented that fifteenth century carracks or cocha were around 2.5. This I would regard as a logical starting point.
Dick
Current build:
Past builds:
Total length to total beam. Can we start there? Would a total length/total beam ratio of about 2.5 be appropriate? The keel is about 1/2 to 2/3 the entire length of the ship, depending.
If you like but this would give a length of keel /breadth of midship frame of about three. You decide.
Dick
Current build:
Past builds:
Now that i've thouroughly pissed off Woodrat, we can continue.
Woodrats are slow to anger.
Here are the effects on the hull shape by varying the l/b/ratio. This may help you decide.
lb2.1.png.647f9b02a3d3856a109fd4d10ba3ab57.pngL/B = 2.1
lb2.5.png.fbbf6352d44a7f18e0f5f7542cdbdff0.pngL/b =2.5
lb3.png.b899bfa000897adc16ce5d3ea23e8007.pngl/b = 3
Cheers
Dick
Current build:
Past builds:
