HMS Victory Cross Section by Antony - FINISHED - Scale 1:36,
Hello Shipmates.
  Finished making the main beams for the Orlop Deck.
The beams were made up by laminating 2mm thick pieces of timber and assembled on the plan which is curved for the camber.
Close up of the joint (not yet cleaned up )
 And before anyone with a sharp eye spots it I am building the Deck upside down. (It’s my method)
Regards Antony.
Best advice ever given to me."If you don't know ..Just ask.
Completed Mayflower
Completed Fun build Tail boat Tailboat
Completed Build Chinese Junk Chinese Pirate Junk
Completed scratch built Korean Turtle ship 1/32 Turtle ship
Completed Santa Lucia Sicilian Cargo Boat 1/30 scale Santa Lucia
On hold. Bounty Occre 1/45
Completed HMS Victory by DeAgostini modelspace. DeAgostini Victory Cross Section
Completed H.M.S. Victory X section by Coral. HMS Victory cross section
Completed The Black Pearl fun build Black Queen
Completed A large scale Victory cross section 1/36 Victory Cross Section
Link to comment
Share on other sites
Hello Daniel.
I had a old piece of kitchen work surface which had MDF on the bottom.
I turned this over to show the MDF which I can drive screws into.
Then I have a sheet of Poleycarbonate 10mm thick. This is pulled into the camber by putting the correct packaging at the edges and using countersunk screws to pull the centre down.
Plans can be held in place tith the edge packing.
As each deck has a different camber all I need to do is reduce or increase the edge packing for less or more camber.
And of course if you lammanate timber it will hold its shape with little or no spring back.
I hope this is the information you wanted :)
Regards Antony.
Completed Mayflower
Link to comment
Hello Shipmates.
Another update.
The photos says it all :)
Not yet finished yet Now have the thin Deck timbers to add.
View fron the top.
Close up.
This is a view from the underside. The Wires are for the LED lighting.
The last set on the Orlop Deck.
Regards Antony
Completed Mayflower
Link to comment
Hello Shipmates.
 Thanks for your kind words Jeff
Another few photos with the Orlop deck fitted into its position. Not yet glued as I have the top surface to sand and clean up.
Approx 5mm to trim off the pump house.
Temporary spacer plank to mark the amount I need to remove from pump house height.
View looking down onto deck.
Thanks for looking in :)
Regards Antony.
Completed Mayflower
Link to comment
Nice work just doesn't do this justice.  Great work, either.  I'm headed to the Thesaurus....
Link to comment
I'm with Mark. Have to come up with new words.
Current Builds - 18th Century Longboat, MS Syren
Completed Builds - MS Bluenose, Panart BatteStation Cross section, Endevour J Boat Half Hull, Windego Half Hull, R/C T37 Breezing Along, R/C Victoria 32, SolCat 18
On the shelf - Panart San Felipe, Euromodel Ajax, C.Mamoli America,
Its a sailor's Life for me! :10_1_10:
Link to comment
Antony, very clean joinery and the overall effect shows. Very nice to follow along.
Michael
Link to comment
Hello shipmates.
Thank you for your kind words Mark, Floyd and Michael.
Starting to plank the Orlop deck But I have a question.. For the victory buffs.
Are the decks in the Orlop deck removable ??.
The drawings in both books look as if they are and any photographs I have found do not show any treenails.
Also the planks are short and held in position by the deck beams.
Also have turned the 36 pounders out of Acetel / Delrin. Will cast enough for the cross section when I get the casting kit.
Thanks for looking in.
Regards Antony.
Completed Mayflower
Link to comment
Hello Antony,
As far as I know they were removable in the part of the ship you are building. The planks were short and let down in the beams except on the sides where the carpenter walk is.
Alexandru
For all my builds please visit my site at: http://www.AlexShipModels.com
Previous builds
Link to comment
Anthony,
Yes, you're right, the central section has removable boards, to make it easier to get to the stores anywhere below in the hold. The forward and after sections both have decked platforms, for various cabins and storerooms.
As Alexandru implies, the the orlop was surrounded by the carpenter's walk, a passageway to enable the carpenter and his mates access to plug any leaks on the waterline during battle.
Btw, you're making a splendid job on your cross section.
Edited by Stockholm tar
Kester
Current builds: Sherbourne (Caldercraft) scale – 1/64th;
Statsraad Lehmkuhl (half model) 1/8th" – 1'.
Victory Bow Section (Panart/Mantua) scale – 1/78th  (on hold).
Previous build: Bluenose ll (Billings) scale – 1/100th.
Link to comment
Hello Alexandru and Kester.
Thanks for the feed back. That's was my thinking.
Thanks again Antony.
Completed Mayflower
Link to comment
Hello Shipmates.
Thanks for your comments... Na ..  I just make things look good :) .
Another update :-
 Filling in all the planking on the Orlop deck at the moment and built the enclosure on the Orlop deck.
Not yet cleaned up to remove the dust and lose fibers.
Not sure that the walls are ventilated but they look nice.
Door is built up with planks and the lock is a bolt through. No idea what’s on the real one :)
The plank's are rounded as they are removable.
The row at the back are as yet not stained or fixed. Need to stain before fixing.
Three rows done.
Progress is good and the Grating is made. But not cut to size yet.
First row of the Planking.
That’s it for Now.
Regards Antony.
Completed Mayflower
Link to comment
Very nice Antony. I admire your abiltity to build the deck off the model. Great workmanship. :)
Rusty
"So Long For Now" B)
Current Builds: Speedwell
Link to comment
Hello Shipmates.
Thanks Rusty and Bob for you comments.
Orlop is now complete and ready for final adjustments before fixing into place in the void.
Gratings and planks that adjoin the Headers are not glued as they will be cut to fit after fixing the deck.
View from top.
Another angle of the Deck.
A different angle.
View of the underside of the Orlop deck.
Another angle
From the other side.
That’s it for now. Will take a few photos when deck is fixed into place.
Regards Antony.
Completed Mayflower
Link to comment
Anthony,
Absolutely beautiful workmanship! This is going to be one tremendous cross section. :)
Kester
Link to comment
Are you as excited as I am to see the deck installed?
Link to comment
Hi Floyd.
  Would not call it excited ... Relief that it fits perfectly would be my statement.
Yes Kester this is growing into one very big cross section.
Regards Antony.
Completed Mayflower
Link to comment
Hello Shipmates.
   Thanks Paddy. I have to say your Cross section is one of the reasons I went into the cross section building. :)
The Orlop Deck is now in place :)
Very happy with the fit and the look.
The deck planks on the Top Right look as if they are not stained... Yes they are :)
The Housing and the Sail store walls are not fixed as they will need to be cut to size.
Now I can start to Cut the timber for the bulwark of the Orlop deck.
And so the Lower gun deck starts :) next week.
Regards Antony.
Completed Mayflower
Link to comment
Anthony,
Well done on the orlop.  It boggles mind that you build the deck off ship.
Link to comment
Antony your skill and workmanship are exemplary.
Michael
Link to comment
Hi Antony,
You have made some wonderful progress since i last looked in, the orlop deck turned out really well and looks fantastic in place.
Superb work :D
Cheers :cheers:
Jeff
Current Builds;
 HMS Supply
Completed Builds;
AL Swift 1805; Colonial Sloop NorfolkHMS Victory Bow SectionHM Schooner Pickle
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
