HMS Victory Cross Section by Antony - FINISHED - Scale 1:36,
Hello Shipmates.
Thank YOU all for your very kind words ...I really do appreciate all the posts you people have made :)
I do not think that I would have made it this far without my Proxxon mill and my Bryons saw.
A stride to catch up with the skills that other modellers have on this forum :) .. A long. .Long way to go yet .
Will post later on today with progress on the lower gun deck.
Many thanks for looking in..
Regards Antony.
Best advice ever given to me."If you don't know ..Just ask.
Completed Mayflower
Completed Fun build Tail boat Tailboat
Completed Build Chinese Junk Chinese Pirate Junk
Completed scratch built Korean Turtle ship 1/32 Turtle ship
Completed Santa Lucia Sicilian Cargo Boat 1/30 scale Santa Lucia
On hold. Bounty Occre 1/45
Completed HMS Victory by DeAgostini modelspace. DeAgostini Victory Cross Section
Completed H.M.S. Victory X section by Coral. HMS Victory cross section
Completed The Black Pearl fun build Black Queen
Completed A large scale Victory cross section 1/36 Victory Cross Section
Link to comment
Share on other sites
Hello Shipmates.
Another update on the Lower gundeck.
Basic assembly done just the Deck carlings to machine and fit into place.
No Gluing done at this stage.. Just good old tight joints.
Sides being treenailed.
And the other side.
View from the underside of the deck.
View from the Top side.
Close up of a joint.
No Glue or pins in this yet :) .
Thanks for looking in.
Regards Antony.
Edited by AntonyUK
Completed Mayflower
Link to comment
Amazing build...thanks.
Rob
Current build:
Finished build:
Current build(On hold):
Link to comment
Hello shipmates.
 Another long update :-
Spent a little time making a ropewalk. but this one is a little larger than the Philips shaver on I have used before.
The shaver would not stand twisting the heaver ropes that I wanted for this model.
The parts are from Ebay. Approx  2 hours to build.
A simple servo tester, A cheep brushless speed controller, And a brushless motor.
Gears used ..1 off 60mm dia 58 teeth, 3 off 20mm dia 18 teeth, 1 off 14mm Dia 12 teeth.
Yes I have used miniature thrust bearings as I has them in my storage box.
That’s about it for the Ropewalk.
Now for the Build :)
A test of the Tulip wood and the different types of caulking that I am using for the deck planking
little loop on the wire ends for the Led lanterns to hang from.
Wire hidden in the wood. Cut a line with the razor saw then push the brass wire into the slot.
Main Gundeck in place But not glued. Bits missing are left out to enable deck to fit between the frames.
View from the bottom.
Completed Deck with out planking.(bottom view)
Completed Deck with out planking.(top view)
some of the furniture ready for assembly.
close up of Joinery.
Odd photo
Completed Deck with out glue
That’s it for now :)
Enjoy.
Thanks for looking in Antony.
Edited by AntonyUK
Completed Mayflower
Link to comment
Antony, your skill is evident with the fact that you can hold up that deck and it is just good joints that are holding it together.
Beautiful workmanship.
Michael
Link to comment
You are just flying along. very nice!
Current Builds - 18th Century Longboat, MS Syren
Completed Builds - MS Bluenose, Panart BatteStation Cross section, Endevour J Boat Half Hull, Windego Half Hull, R/C T37 Breezing Along, R/C Victoria 32, SolCat 18
On the shelf - Panart San Felipe, Euromodel Ajax, C.Mamoli America,
Its a sailor's Life for me! :10_1_10:
Link to comment
Hi Antony, I just got caught up with your log and you are doing some
outstanding work. Very well done and the look is so clean. I love it. B)
Rusty
"So Long For Now" B)
Current Builds: HMS Winchelsea 1/48  Duchess of Kingston
Completed Build Logs: USF Confederacy , US Brig Syren , Triton Cross Section , Bomb Vessel Cross SectionCutter CheerfulQueen Anne Barge, Medway Longboat
Link to comment
Hi Antony,
I like your rope walk machine very nice, have you tried it out yet? I am currently trying to get some gears to make a serving machine, never thought of good old EBay. :huh:
Your workmanship is superb as always the chain pump housings look fantastic. Have you figured out a way to make them operational yet?
Cheers :cheers:
Jeff
Current Builds;
 HMS Supply
Completed Builds;
AL Swift 1805; Colonial Sloop NorfolkHMS Victory Bow SectionHM Schooner Pickle
Link to comment
Hello Shipmates.
Thank you all for your kind words :)
Jeff :- No I will not be making the chain pumps operational .. The model area will not be visible when in its display case.
Just made the deck support piller's for the Orlop deck. Will fit then with the deck tomorow and post a update of the main gun deck in place.
Then it's the planking of the main gun deck. Looking forward to using the Tulip wood planks.
Regards Antony.
Completed Mayflower
Link to comment
Hello Shipmates.
Another update on my progress.
Main Gun Deck is now fixed into place with no errors
Started to plank the Deck with Tulip wood. Very nice looking wood.
Deck now fixed onto the bulwarks with knees fitted.
Photo looking up at the deck from the underside.
All the planks cut to length and drilled at ends only for treenails.
Waterways in and now ready to plank..
First planks laid.
Will post another update when Gun Deck is complete.
Regards Antony.
Edited by AntonyUK
Completed Mayflower
Link to comment
Hello Shipmates.
  Thank you for all the very nice comments and likes. :)
Yves. .. Its a possibility I will have one gun crew of figures. I will use Warhammer Empire Gun crew Figures.
Another Update.
Test the tree nails in the Tulipwood.
The Deck drilled and ready to Tree nail.
Tree nails in and cut but not yet cleaned up :)
Very close up of the Holes ready to treenail.
Another close up.
Quite happy with the result :)
Will finish the other side and sand the deck then I will post the completed Deck.
Regards Antony.
Edited by AntonyUK
Completed Mayflower
Link to comment
I think you got the scale just perfect! Not too large but still noticeable.
Link to comment
Hello shipmates.
Thank you all for your kind words of encouragement :)
Jeff -: I used the dark stained ones as they look as if they were more predominant to see.
Half the deck is done just got to do the other end.
Remade the pumps as I was not happy with the look.
Regards Antony.
Completed Mayflower
Link to comment
Great work on the treenailing Antony, The tulip wood deck looks very nice.
Michael
Link to comment
Hello shipmates.
No update on this post ...
I have decided to have a go at carving the Captain's entrance to the victory.
I have watched numerous video's on Utube on how to do wood carvings.
Janos's page of carvings are a real inspiration to me. http://modelshipworld.com/index.php?/topic/501-carved-figure-heads-and-decorations/
I just need to find some close up photos of the entrance to start.
Basswood is my choice of timber being a novice.
May I wish you all a very happy Christmas and a very good new year.
Regards Antony.
Completed Mayflower
Link to comment
A Merry Christmas to you too Antony and good luck with the carving too.
Rusty
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
