Speedwell by dvm27 (Greg Herbert) - FINISHED - Ketch Rigged Sloop, 1752
Greg your work is so sharp and clean, the stove looks great.
Michael
Link to comment
Share on other sites
Very nice, Greg. It is a clever idea to stain the wale before installation, because that shoe dye does like to flow into places you don't want it if you don't score enough of a line at the junction. But how did it work with fasteners? Did you re-stain once the trennails were in place and trimmed?
Link to comment
Looking good!
Maury
Link to comment
Hi Greg,
Oh that is soooooo nice. I can appreciate your not wanting to cover those timbers.
That is some fine workmanship. :)
Rusty
"So Long For Now" B)
Current Builds: Speedwell
Link to comment
Thanks for all your comments!
Remco - There's no need to fix Fiebing's dye. It covers and penetrates beautifully and buffs to a nice finish. As a matter of fact, they recommend applying it to  wet leather.
Learner - I adapted my stove from Lavery's Arming and Fitting... It depicts an iron firehearth contemporary to Speedwell. Brodie stoves appeared decades later, c.1780. Here are a couple photos of the strove during construction. All brass parts were constructed over shaped plugs of holly and glued with J&B Weldbond. This creates a very strong bond and fills the joints which can then be sanded. The finish is automotive gray primer followed by automotive black.
Mark - trunnels are drilled and applied after the wales are in place. They are easily touched up using the dye on a q-tip. Kind of a wasted exercise though as they become invisible.
Speedwell is a nice little project at 1:48. She'll fit easily on my one remaining shelf.
Edited by dvm27
Greg
website
Admiralty Models
Finished build
Pegasus, 1776, cross-section
Current build
Speedwell, 1752
Link to comment
Greg,
I hope the plan is still to offer a full set of plans.  She's lovely.
Maury
Link to comment
Hmm thanks Greg, I checked the container I'm using, its Fiebings edge enamel  :blush: I think I should have paid better attention when I picked that up from the equestrian shop. This stuff does a poor job penetrating the wood and after it dries its still soluble in water. I'm not sure what part of the horse ('s equipement) this is any good for... Or it's over bbe date... Anyway I'll look for the leather dye version next time.
Remco
Treat each part as if it is a model on its own, you will finish more models in a day than others do in a lifetime.
Current build HMS Kingfisher
MSW 1.0 log click here
Link to comment
Gary and Greg,
You both might want to check your message storage.  It's possible that your inboxes are full.
Link to comment
  • 4 months later...
Thanks for your interest Ben. As you'll find out, building a fully framed model is very intense and I found myself needing a bit of a break after finishing her framing. Workshops, Echo cross-section and mentoring have kept me pretty busy though and I'll surely get back to her in the near future.
Greg
website
Admiralty Models
Finished build
Current build
Speedwell, 1752
Link to comment
Thanks Greg,
I will have to look up and put in my notes, I do have the book in my Library.
On the Brodie stove there is a good drawing of it in AOS Brian White's "The Frigate Diana" with an internal drawing. whats missing is the top view.
Guy
Cheers, Guy
The Learner
Current Member NRG,SMA
Current Build: HMS Triton 1:48 on line
Link to comment
Hi Greg, Amazing work, very clean the framing looks fantastic
Best Regards,
Pete
"may your sails be full of wind and the sun on your back"
Current Builds :
 Future Builds :
N.G Herreshoff 12 1/2 Scratch Build 3/4" = 1' - 0" Scale
Completed Builds :
Volvo 65 Farr Yacht Design
Herreshoff Alerion
Volvo Open 70
 Member :
The Herreshoff Registry                                  Montgomery Sailboat Owners Group       Peter Kunst Sailboat Models
http://www.herreshoffregistry.org/                       http://www.msog.org/                      http://www.facebook.com/Peter-Kunst-Sailboat-Models-1524464774524480/
Link to comment
  • 5 months later...
Greg,
After seeing this ship close up at your recent sail-making workshop with David Antscherl, it was fun to re-read the build log and see it underway. It is even more impressive in real life than the photos, which are already fantastic!
Link to comment
  • 11 months later...
Been awhile since my last Speedwell update. Work on the forecastle has finished, for the most part. Caulking is black paper. It's a bit more work but a little cleaner than when I use a pencil. The wrought iron belfry is unusual but present on the contemporary model. I twisted 1/32" square brass bar stock with one end in a stationary vice and the other end in a pin vice. Consistent upward pressure while twisting insures an even result.
Greg
website
Admiralty Models
Finished build
Current build
Speedwell, 1752
Link to comment
Nicely done...You have been busy!!!   Great to see an update.   Have a great Thanksgiving Greg  :)
Link to comment
Fantastic work Greg, I wish I could attend your workshops.  If and when I get mine back in order I would love to use your techniques.
David B
Link to comment
Fantastic belfry, Greg.  The rest is just as wonderful.
Link to comment
Fantastic work Greg, very fine detail well executed.
cheers
Pat
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
