Speedwell by dvm27 (Greg Herbert) - FINISHED - Ketch Rigged Sloop, 1752
That sure looks great Greg. Do you have a picture of the finished stove, it would be a pity if we couldn't admire the result.
Happy Thanksgiving.
Remco
Treat each part as if it is a model on its own, you will finish more models in a day than others do in a lifetime.
Current build HMS Kingfisher
MSW 1.0 log click here
Link to comment
Share on other sites
Link to comment
beautiful work Greg,
very clean and accurate build, Looks great.
Just a question : I noticed that on your plan (earlier Posts) the forecastle companionway opens to the aft side, also shown on your last pics, how is the Access to this side ?
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Beautiful.  More inspiration!!!
Maury
Link to comment
Small and relatively tidy ships often turn out to be the subject of the most beautiful models.  You are proving that with your build.
Allan
Link to comment
Thanks or the many comments and likes.
Nils - The forecastle ventilation scoop on the starboard side is the access to the fore platform. There is a small ladder in place. I imagine the scoop was removable for easier access to the platform. The forecastle also has a small access grating to load coal. Note that on the port side of the fore platform has a small scuttle or "coal hole" in load it into the hold.
Remco - shockingly, I seem to have forgotten to photograph the completed galley stove prior to installation. I didn't overdo it as it will only be visible through some omitted planks on the forecastle.
Greg
website
Admiralty Models
Finished build
Pegasus, 1776, cross-section
Current build
Speedwell, 1752
Link to comment
Thanks Greg,
aha, is understood, removeable Ventilation Scoop, that`s good, makes sense, as shown is for exhaust, turn opening to front for fresh air, thanks for explaining
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Really nice and precise progress
Regards Christian
Link to comment
Nice, neat modelling -as your usual standard. What size are the loops to control the valves of the faucets on your stove? Fantastic scale!! Nice shot locker in the background, also!
Great job. Happy Thanksgiving!
Model(s) under construction: RATTLESNAKE. 1:48
Next on the launch : ECHO 1781 1:48
Link to comment
Beautiful workmanship Greg, great to see the progress.
Michael
Link to comment
Fantastic to see you back at Speedwell.  Do you know if that twisted iron is typical for the class or specific to Speedwell?
Toni
Chairman Nautical Research Guild
Current Builds:     NRG Rigging Project
Completed Builds: Longboat - 1:48 scale       HMS Atalanta-1775 - 1:48 scale       Half Hull Planking Project      Capstan Project     Swallow 1779 - 1:48 scale               Echo Cross Section
Link to comment
I've not seen it before on any model, Tony. The width and shape of the belfry match the Navy Board plans but one can't discern if it is twisted iron or not. The model is contemporary so I would assume the detail is accurate.
I form very small loops with a jewelers round nosed pliers such as this http://www.all-spec.com/products/RX7590/image.viewer. You can form loops less than 1mm with these.
Greg
website
Admiralty Models
Finished build
Current build
Speedwell, 1752
Link to comment
  • 2 months later...
I see that it has been awhile since my last Speedwell update. Here are some current photos. David Antscherl (of Greenwich barge fame) and I are currently working with SeaWatch books on a book featuring her construction in both plank on frame and plank on bulkhead versions. She's a sweet little vessel and will be fully rigged. At 1:48 scale she won't take up a lot of space in my study.
The fore platform with the boatswain's cabin and sail room. There is a properly tagged and stowed sail on the lower sail rack but it is no longer visible.
The well sitting beneath the main mast partner with it's two octagonal pump openings. there is a small cleanout door at the bottom of the well.
I made a jig to shape the round-ups of the various deck elements. Basically, I have connected several properly shaped deck beams (laser cut by Chuck) with planks on the convex and concave surfaces. I then affixed 150 grit garnet paper with rubber cement. Adding the round-up is then a simple matter of moving the piece up and down the paper. i use a small plank to keep the pull straight. You know when you are done as the dust spreads entirely across the paper above and below and the bottom of your thumb is raw.
post-505-0-57638700-1461466778_thumb.jpgpost-505-0-10728800-1461466779_thumb.jpgpost-505-0-58411900-1461466779_thumb.jpg
The upper deck back to the aft platform has been framed. It is a fairly tedious job adding each new beam with it's lodging knees, hanging knees, carlings, ledges and bolts. Depending on the amount of deck planking one plans to add, some of these elements could be omitted. I plan on adding very little deck planking so most of it will be visible.
In the final photo, the capstan upper and lower partners have been added. Speedwell's capstan is a bit curious as it is designed to be raised and lowered. It seats on a removable spindle cup on the lower partner. Neither David and I have any idea why it was designed this way.
That's it for now. Next will be the framing of the aft platform and quarterdeck.
Greg
website
Admiralty Models
Finished build
Current build
Speedwell, 1752
Link to comment
Beautiful work, Greg.   That capstan is an interesting detail.  Another one of life's mysteries....
Link to comment
love that ship Greg,
a beautiful built vessel
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Beautiful detail and great craftsmanship Greg.
cheers
Pat
Link to comment
Really clever little jig. Thanks for sharing
Regards Christian
Link to comment
It's looking fantastic Greg...You have been making a lot of progress.   Good to see updates again.   How about an overall shot of the hull. I would love to see her lines and sheer?
Chuck
Link to comment
Great news, looking forward for the book! Hope it will come with the plans? ;)
Yes, Mike, we plan to include both plank on frame and plank on bulkhead plans for Speedwell. In addition, we are working on supplying the figurehead and carvings for this vessel as well as the three pounder cannons.
Thanks for all the likes!
Greg
website
Admiralty Models
Finished build
Current build
Speedwell, 1752
Link to comment
hi Greg
Sorry I only just found this log and have just read up to date, lovely work you are doing
The clerk of the cheque's yacht of sheerness
Current build HMS Sirius (1797) 1:48 scratch POF from NMM plans
HMS Winchelsea by chuck 1:48
Cutter cheerful by chuck 1:48
Previous builds-
Elidir - Thames steam barge
Cutty Sark-Billings boats
Wasa - billings boats
Among others 😁
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
