Muscongus Bay Lobster Smack by pete48 - FINISHED - Midwest Products - SMALL
Thank you Ollie and Wayne , for your wonderful compliments
Best Regards,
Pete
"may your sails be full of wind and the sun on your back"
Current Builds :
 Future Builds :
N.G Herreshoff 12 1/2 Scratch Build 3/4" = 1' - 0" Scale
Completed Builds :
Volvo 65 Farr Yacht Design
Herreshoff Alerion
Herreshoff Buzzards Bay 14
Volvo Open 70
 Member :
The Herreshoff Registry                                  Montgomery Sailboat Owners Group       Peter Kunst Sailboat Models
http://www.herreshoffregistry.org/                       http://www.msog.org/                      http://www.facebook.com/Peter-Kunst-Sailboat-Models-1524464774524480/
Link to comment
Share on other sites
Here is an update on the kit build and the scratch build, The kit build now has 3 brushed on coats of minwax polyurethane. The reason I use a minwax clear as my primer, is that I scribe the waterline on the bare wood . I will let it cure for a day then wet sand with 1500 grit then any shiny spots will be low spots and need to be filled. On the scatch build I decided to plank to right around to the water line I used 1/4" X 1/16" basswood strips left them full size at the bow and faired them aft, it will then look right for finishing later.( gloss white.) Next I am going to finish the top side on the Kit build and start masting and rigging . Here are the current photo's
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Link to comment
Thanks Tom, you got to have a set of saw horses when you are boat building.( I made them in between coats of minwax)oh there's a ladder too
Edited by pete48
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Link to comment
I’m late to the party as usual, but it looks like you’re having fun anyway.  That’s an interesting difference between the two boats, and both are correct.  If five different builders built thier lobster smacks in the 1800’s you would have five slightly different boats, because each builder has his own idea of what is best.  That’s part of the joy of building the small boats.
Bob
Current build:  SS_ Mariefred
Link to comment
 got back to work on the kit build and decided to replace the stock cabin/cockpit coaming with a birch plywood  . I also thought to enclose the bench seat base .I also have the masting near complete ( the gaff jaw took a while ) I also decided to take the time to make a decent cradle, here are the results from today
Edited by pete48
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Link to comment
Hi Bob, You're not late to the Party at all , and it has been alot of fun building these
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Link to comment
It's been a few days since I updated the Kit Build , The Hull has been wet sanded up to 1500 grit and the cabin top has been installed. With some good weather I will be ready to paint the hull. On the scatch build its been mostly sanding and fairing.  wich has me thinking about a real scratch build, then the boat will fair more properly(giving correct shape) So I think I am going to Buil one next with a log in the scatch builds. Any way here are the results from today
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Link to comment
Thanks Richard , We have not had the greatest weather around here latley, So made the  saw horses and then I made a clamp vice . I took an old 1 3/4 " c clamp  and made a bench around it here is what it looks like
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Link to comment
Looks like you're having as much fun building the model tools as building the model.  Good work.
Bob
Link to comment
Hi Bob, as a matter of fact making the tools has been more fun in some aspects. ( no plans) and the clamp vise has been so useful that I have not had time to stain and varnish it.
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Link to comment
The Kit build has Its first of 4 coats of paint (gloss white) I may have a few pics later today. On the scratch build I cut out the cockpit/cabin coaming and have installed them. next will be alot of sanding to get the hull faired out
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Link to comment
Thank you Bob (hexnut) . I have been having alot of fun with this build
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Link to comment
Here is where I am at on the Builds, The kit build has 4 coats of Gloss White , and is ready to have the top side finished . The scratch build is being faired (allot of sanding) almost ready for a sealer. here are some photos of the two boats
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Link to comment
What a fine pair.  They are really coming along.
Bob
Link to comment
Now for the fun part , The finish work. I started with the work on the cabin. I got the work on the Companion way hatch done and then restained. The scratch build is still being faired and is comming out nicely. Here are the results
Edited by pete48
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Link to comment
Nice job. Question, what was the white gloss you mentioned? Is it sealer, white paint, then gloss polyurethane? Or white poly? I would like to get a finish like that for a future build. I'm still trying to figure the paint thing out. Both boats are looking cool and different, like from two different time periods?
Casey
"I drank what?" - Socrates
Current Builds:
Finished Builds:
Future Builds:
  • Mamoli Golden Hind
  • Mamoli Black Prince
  • AL Swift
Link to comment
I am starting to get things finished up top side,The hatch boards and rails have been fitted, then the cabin top was painted a gloss white . Here are the results
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Link to comment
Thanks Casey and Tom, What I used was 3 coats of minwax polyurathane then I wet sanded starting with 800 grit working my way up to 1500 grit. Then I used testors gloss white 4 coats then left it alone for a few days. I have to say that I was impressed with the minwax it was nice to work with . The key is giving at least 8 hours inbetween coats, and letting the boat sit a few days after primer and paint so that it gets a full cure ( I put my boat in the closet where the furnace is, so thatI had consitent heat)
Pete in Portland, I bought a can of gesso before I got started on this project, then decided to try the minwax, ( I like it) so I have not tried the gesso yet
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Link to comment
Thank's Richard , I am just getting set to do the bottom paint (gloss grey) then get back to the scratch build
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Link to comment
Here is where I am at: on the kit build, I made a new cockpit seat then I stained it to give it a teak look. I then masked off the water line and painted the bottom a Gloss Grey. On the scratch build alot of sanding and fairing . here are the results.
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Link to comment
The Kit Build is just about ready to paint the deck, and install the bowsprit, The scratch build is on a first coat of grey bottom paint ( I like how it turned out on the kit build) With all the time waiting  between sanding and painting I had started a third (2nd scratch) Lobster smack, its more of a prototype before I do the Chapelle version that way I can try things out . The Chapelle version will have a working centerboard (wich should be challenging) here is the results from today
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Link to comment
Pete:
Very nice work on both of them. The paint work looks great so far.
Russ
Link to comment
looks great Pete!  I like the open hatch!
Casey
Current Builds:
Finished Builds:
Future Builds:
  • AL Swift
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
