L'Amarante 1749 by giampieroricci - FINISHED - 1:30 - French Corvette
Your work is not only very fine, but is also quite educational.
Bob
"Even while the storm raged at it's worst, my ship was wholesome and noble." - Captain Joshua Slocum
Current Builds:
L'Hermione 1780 - 1:89 - Artesania Latina   http://modelshipworld.com/index.php/topic/10261-hermione-la-fayette-1780-by-bobstrake-artesania-latina-scale-189/#entry305929<p>
Louise - 1:26 - Constructo  http://modelshipworld.com/index.php/topic/11855-louise-by-bobstrake-constructo-scale-126/?p=360370
Completed Builds:
Carmen 1850 - 1:80 - Constructo - First Build   http://modelshipworld.com/index.php/topic/10398-carmen-1850-by-bobstrake-constructo-scale-180/#entry31137
Link to comment
Share on other sites
 Inspirational work, Giampieroricci.  I didn't realize how tiny that was until I saw on your finger.
Link to comment
Beautiful work, Giampiero.  I noticed the wonderful touch of the ropes securing the chimney hood over the fireplace.  That's a detail I don't think I've seen before in any build.
Link to comment
good job giampieroricci!
your french fan's wait for  lot of foto's like that....
Of the bank I look at an ocean of pleasure, or the tumult attracts you, this global movement will be your tipcart!
current build:   royal caroline
buid finished:  la recouvrancehttp://modelshipworld.com/index.php/topic/3025-la-recouvrance-by-ofencer29350/page-2?hl=recouvrance
Link to comment
For the coating of the smaller circular scuppers, after having pierced with much trepidation and caution, to avoid spoiling the model, I used a thin lead foil beaten anvil wrapped around a rod of the right size that I used as a guide 'insertion into the hole:
Link to comment
Very nicely done on the scuppers, Giampiero.
Link to comment
If you've used actual lead, Giampiero, might I suggest sealing it with either acrylic medium or lacquer? It will prevent the lead turning to white lead salts in a few years' time. You've done a great job on a difficult part of the build.
Link to comment
You are right!
I give a coat of clear lacquer matte finish to fix all the small scratches that inevitably are created while working on the model!
Thank you for your suggestion!
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
