Kevin
HMS VICTORY by Kevin - Caldercraft/Jotika - 1/72
Hello everyone
Are we re-posting everything from start of the project, or from where we are at present
contents
http://modelshipworld.com/index.php?/topic/403-hms-victory-by-kevin-caldercraftjotika-172/
workshop makeover
http://modelshipworld.com/index.php?/topic/403-hms-victory-by-kevin-caldercraftjotika-172/page-2#entry7118
beakhead chase cannons
http://modelshipworld.com/index.php?/topic/403-hms-victory-by-kevin-caldercraftjotika-172/page-5
Edited by Kevin
Share this post
Link to post
Share on other sites
Hello Kevin
It appears that most builders are posting a summary of there work from the beginning up to present stage. If you have the time and patience you could put up blocks of photos and dialogue stage by stage, the hull build , the planking , the lower deck the middle deck etc. Its all up to. Look forward to see you up and running soon. DAVID
Share this post
Link to post
Hi Kevin,
Good to have you back.  This is sort of like a parachute company re-grouping after a dispersed jump, everybody showing up at the marshalling area in dribs and drabs!  As for re-posting your pictures, it's up to you how you do it.  I put up blocks of pictures of my build - basic hull construction, gun ports, stern galleries.  Of course I had it much easier than you folks who are much further along in your builds since I'm still at the early stages.  Looking forward to seeing your build again and your progress going forward.
Patrick
Share this post
Link to post
Me too, looking foreward for your reposting and everything coming will be welcomed with interest and gratitude :-)
Daniel
PS: The more the better ;-)
Share this post
Link to post
Hi Kevin
Great to have you back here too - looking forward to the first pictures.
Cheers,
Rosmarie
Share this post
Link to post
Hi Kevin,
There you are…...
Welcome home.
I was lucky that i had my build log on another forum.
So I can put a lot back.
Not all the comment but that is stored in my head  :)
I'll be waiting for you upgrades.
Sjors
Share this post
Link to post
sept 2011-280 hours into build, all gun ports middle and lower have been lined.
This was achieved using a simple built jig that allowed the linings to be put into the cut-out at a depth of 1mm from the outside of the hull, without constantly loosing then into the hull
Share this post
Link to post
the copper tiles took me 140+ hours - to be in a position where i was happy with them, I made lots of mistakes and found ways to correct them
few things i learnt
i used superglue,, but there are different formula's - i found the medium jel worked for me in the end,
ensure you have a good waterline
from the waterline i worked down about 14 rows and found from there i had a continual run of tiles which hit the waterline forward and aft, then worked from the keel up this ensured that that the gore line was hidden under the belly of the build
the stern up to the rudder post was a pain to get - so that it looked the same when viewed from there looking forward, this was because both side were not exactly the same
i used a thin strip of plastic on the waterline to tidy the tiles up
copper tape always was an option - i decided against this
i required to purchase more tiles
i would change the glue type next time to something light something like evostick - something that gives you time to move the tile around, and easier to get any residue off
hope this makes sense
Share this post
Link to post
480 hours into build
the 1/4 galleries were perhaps the easiest bit so far for me anyway i got it right 1st time. I can only presume that is because i managed to get everything where it needed to be, ie i would rip it off and do again if not so
there was quite a debate about this at the time, i had a PM through stating they are in the wrong place/position, this is in fact an optical illusion
Share this post
Link to post
Good to see your log back and up to date Kevin.  I'm looking forward to seeing your new workshop once the refit is complete.  Haven't seen any pictures of the wabbits this time around........
Share this post
Link to post
Hello Kevin,
Another Victory! Going to wacth this one.
Your copper plating is different compared to Rosmarie's. But it looks fantastic.
You're doing a great job. I will follow your progress.
And your fluffy animals make a great audience. Love them!
Take care,
Anja
Share this post
Link to post
Post loft conversion and with the extra room, the opportunity has come to move into the garage, up sizing from the 10x8 shed, which does not have the height room to complete the Victory, so i am at present lagging it to make it a habitable environment
Edited by Kevin
Share this post
Link to post
Thanks for the pictures of the Wabbits Kevin, your build log would be incomplete without them!  :P
Can't wait to see the new workspace ready for action.
Cheers,
Share this post
Link to post
Take your time Kevin,
We are not going anywhere.
The new site is to much fun!
Sjors
Share this post
Link to post
My new workshop continues to grow, all surfaces are/have been lagged, and slowly it is being brought to life with power
the lit area is 4'x8' where i can do messy bits, - but it is taking oh so slow,
I need my weekends to be longer than the working week
Share this post
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
    No registered users viewing this page.
Our Emblem
