Muscongus Bay Sloop by pete48 - SMALL - Finished
Thank you Richard, I am Happy with the way Keel # 4 is turning out. How is the Endeavour comming along ?
Best Regards,
Pete
"may your sails be full of wind and the sun on your back"
Current Builds :
 Future Builds :
N.G Herreshoff 12 1/2 Scratch Build 3/4" = 1' - 0" Scale
Completed Builds :
Volvo 65 Farr Yacht Design
Herreshoff Alerion
Herreshoff Buzzards Bay 14
Volvo Open 70
 Member :
The Herreshoff Registry                                  Montgomery Sailboat Owners Group       Peter Kunst Sailboat Models
http://www.herreshoffregistry.org/                       http://www.msog.org/                      http://www.facebook.com/Peter-Kunst-Sailboat-Models-1524464774524480/
Link to comment
Share on other sites
This morning I awoke and started wet sanding Keel # 3, in that process, I dropped the boat and broke off the bow of the cutwater, I decided to just round it off .once I fixed it so that it would look halfway decent, I spayed 2 coats of gloss white.  next I will wet sand again and sprat 2 more coats. ( I wanted to capture the tumblehome and the transom in 2 of the photos )Here are the results
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Link to comment
Very sweet looking curves, and a smart finish.
Michael
Link to comment
Thank you Russ and Michael, on Keel # 3, I spent alot of time fairing the hull to obtain the tumblehome, wich gave me this transom shape. I am pleased with the way this boat is turning out.  I would like to end up with a high gloss finish that gives it a fiberglass look. ( I should get that look after 2 more coats )
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Link to comment
Today I finally got the final coats of paint on Keel # 3 for a total of 9 including 2 coats of primer, I got that fiberglass gloss that I was hoping for,  I then shaped the rudder and sprayed 2 coats of primer. I then turned my attention to Keel # 4  I first installed the winow glass . ( I use the plastic from X-Acto blade refill packages ) I then made the cabin top, the hatch rails ( I found a unique knot in the wood that I used for the inside face of the inside hatch rail ) and installed them I then took some Birch ply for the cabin face then installed some Mahogany for the drop board rails . Here are the results
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Link to comment
Link to comment
Hi David, For Keel # 4 I have not decided yet, on Keel # 3 the Cabin / Cockpit Coamings are made from a Birch plywood and I am going to use a Cherry Stain for the brightwork then a varnish , And I am going to use a sand color for the deck, I may make the fish well deck and cockpit floor a teak deck by using strips of Birch with Black paint as Caulking.
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Link to comment
If my memory serves me this craft was painted the way the fisherman wanted it to identify it. There was no standard shade.
David B
Link to comment
Hi David, Thank you  I try to go with what looks good
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Link to comment
After my morning Coffe , I unmasked Keel # 3 and took a couple of shots with Keel # 4 I wanted to show the Tumblehome and the natural curve it makes at the top of the deck. here is what it looks like
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Link to comment
They are looking great. I like how the stern meets the deck on the left hand boat. That is very classy looking. Beautiful work.
Russ
Link to comment
Thank you Russ and David, The Boat on the left is Keel # 3 , This is the Transom I like the best I love how the Tumblhome rolls over, And I will do this style again
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Link to comment
Today I decided to work on the Cockpit Floor for Keel # 4 , I first laid out the Cockpit Floor so that the Bildge could be accessed, Then figured out where the Bench would go . I then cut out strips of 1/64" Birch ply and roughed in the Pieces. Then fine tuned them Painted the edges Black ( I got a little sloppy ) and glued it up . This is the First one I have done like this . I will do the same for the Fish well Deck . I did start to cut out the bench sides and proped them up for the Photo. Here are the results
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Link to comment
Hi Rchard, I can understand about needing a break ( I just had one for about 4 months ) The boats are starting to come together . Thanks for the likes
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Link to comment
On Keel # 4 Today, I started by shaping the Mast and fitting it. I decided to add a square piece of Birch Ply as a Mast step. I then stained the Birch on the Cockpit face , Cabin entry and the companion way rails a Cherry . On the Cockpit floor I made a new Hatch cover ( I didnt like the first one ) Laid out the Deck for the cut outs ( I will do the Fish well deck the same as the Cockpit floor ) Then Painted the Cabin top a gloss white. Here are the results
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Link to comment
I like the cockpit.  They keep getting better.
Bob
Current build:  SS_ Mariefred
Link to comment
Thank you Bob, I appreciate it  , I am happy with the way its turning out
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Link to comment
Today, I finished the Cockpit floor , first I cut out Birch ply for the bench supports and stained them cherry . Next was to cut out the Deck hatches on the fish well deck . then I cut out more birch strips for the deck . I installed the bench supports and installed the birch strips on the fish well deck .I sanded the Cabin top to get it ready for a second coat . I like how this has turned out Here are the results
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Link to comment
She is looking great.
Michael
Link to comment
Thank you Michael, I appreciate it . Hows the Cutter comming along ?
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Link to comment
Pete I am working on the big boat right now so the cutter sits as inspiration within sight of the big work.
Michael
Link to comment
I thought today would be a good day to work on Keel # 4 , I started by refitting the Centerboard.  Then I cut out the Bowsprit Blank, marked it now its ready for shaping. I then made the inside drop board rails , and installed them. I then cut out the seat, wich I made out of 2 pieces so that the seat fits under the Deck. Next I ripped down more of the 1/32" birch ply for the decking . I then laid it out the seats in the same fashion as the cockpit floor and fish well deck. I then installed the seats and added a pre bent pre stained strip cut it to fit aft of the seat and match the cockpit coaming . Here are the results
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Link to comment
It is coming along well. Details are important on a large scale model of a small boat. Yours are looking good.
One question. Are you doing the planking details on the seats off the model and then installing the seats as completed units? I ask because the caulking details are bold. If they are good for you, then no problem. If scale is an issue there, you might want to see if you can tone them down. It is your choice though.
Russ
Link to comment
Thank you Russ, The seats were made off the model then installed .This is the first model that I have tried this on,so scale was not that important ( it just had to look good ) I made the caulking a bit dramatic to see how it would look overall. Its all a just learning process ,and Its alot of fun.
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Link to comment
Here are a few Hull shot comparison pics between Keel # 4 on the left , and Keel # 3 on the right ,
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Link to comment
Thank you Russ, I am pleased with how the paint turned out, especially on Keel # 3
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
