Herreshoff Buzzards Bay 14ftr By Pete48 - SMALL 3/4" = 1'- 0" - Finished
Today , I got the trim package stained ( rub rail & toe rail) I then painted the waterline on the Rudder ( Gloss White ) and the Spreaders ( flat White ) I installed the Rub rails first followed by the Toe rails , I then installed the fore and aft Cockpit trim . Then I was able to get 3 coats of Epifanes varnish on all the trim, Almost ready for rigging and Ballast.  Here are the results
"may your sails be full of wind and the sun on your back"
Current Builds :
 Future Builds :
N.G Herreshoff 12 1/2 Scratch Build 3/4" = 1' - 0" Scale
Completed Builds :
Volvo 65 Farr Yacht Design
Herreshoff Alerion
Volvo Open 70
 Member :
The Herreshoff Registry                                  Montgomery Sailboat Owners Group       Peter Kunst Sailboat Models
http://www.herreshoffregistry.org/                       http://www.msog.org/                      http://www.facebook.com/Peter-Kunst-Sailboat-Models-1524464774524480/
Link to comment
Share on other sites
Thanks Geoff, it was alot of fun ( I am starting to enjoy doing the finish work ) , She's getting close
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Link to comment
Great job on the trim. That sets off the hull and deck nicely. She is looking really spiffy.
Russ
Link to comment
Thanks for all the likes
Thank you Russ, shes comming together
Thank you Jay, Hopefully this week, I will start ballast and rigging
Thank you Dave, I am pleased with the color scheme , She's a looker
Thank you Richard, Glad to see you stop by
Thank you Geoff, the 12 1/2 is not yet perfected, I am going to re loft the Profile drawing , I ended up with a glitch . So I will build another 12 1/2 with the corrections. Then I will talk about a 1:1 scale ( it has been a plan for a long time to build a full size Herreshoff, over 15 years)
Best Regards,
Pete
Here are a few more shots
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Link to comment
She's looking better all the time.
Bob
Current build:  SS_ Mariefred
Link to comment
Link to comment
Thank you Bob, Getting closer to Sailing
Thanks David , This one is right on the money,( I have a full set of plans for the Buzzards Bay 14 ) When I was Talking to Geoff , I was refering to my 12 1/2 proto-type, The 12 1/2 is the Boat that I intend to do a 1 : 1 build, I am still developing the Plans, and have another model to do, once I have made all the corrections
Best Regards,
Pete
Edited by pete48
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Link to comment
Thank you Robert, She is a beauty, This build has turned out alot better than I had hoped for , The only thing that is not Plan correct is the Cockpit floor , I raised it thinking that I could hide the radio gear in the bilge, as it turns out she is a bit small for raidio gear .However  I will still take her Sailing .
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Link to comment
Today , While paint was drying on the 12 1/2, I decided to do some tank testing . I used small fishing weights ( the round ones ) filled the bilge where the lead for the Keel is . Then I put her in the water tank ( kitchen sink )  The water line is right on the money, This boat has been a pleasure to build . Here are the results
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Link to comment
Lovely. What are you going to make the sails from?
Michael
Link to comment
Thank you Geoff , She passed with flying colors
Hi Omege, She is a bit to small for radio gear , so I will let her free sail
Thank you Michael, I am thinking a light weight rip-stop nylon ( white)
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Link to comment
Link to comment
Thanks Omega,  I am thinking that she will sail beautifuly ,  I would like to do one R.C, I will have to bump up the scale to at least 1" = 1' - 0 "
Thanks Jay ,She's getting closer , I am going to start making cleats and blocks , I can't wait to see her sail
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Link to comment
Hi Pete. For what it's worth, I used to scrounge in the bins of the local sailmakers for discarded bits of sail cloth. The most suitable bits that I found useful were the lightest weight spinnaker cloth. Not only was it light, but, because of its weight and flexibility, I found that they always looked realistic and drew beautifully when under way.
All the best.
Link to comment
Thanks Omega , I will look into that ,That Sounds good
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Link to comment
Come on Pete.  With all the small and mini RC equipment out there.  Surely  you can find some that will fit.  Go for it.
Bob
Link to comment
Hi Cap'n'Bob, True they do make radio gear that small, however there has been talk about building a 12 1/2 at 1:1 in this house , Hopefully , once the revised 12 1/2  is built ( the next build  ) and the boat goes together like on this one did. I can make a step toward 1 : 1 build . so I will hold off on Radio gear for now
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Link to comment
Today, the Boat moved into the fitting out stage. ( one of my favorite parts of a build ) I started by trimming the back deck and installing it . I then made doors for the Bow and Stern cockpit lockers. I then stained and installed them. Next I moved to installing the chain plates for the shrouds ( I found these beading parts at michael's wich are perfect) I drilled holes at the chain plate locations and installed them with epoxy. next was attaching the turnbuckles . I also started making the 2 cleats for the mast.  I also started  making the double block for the main sheet. in the pic you can see the beading part I used for the chain plate base's. I also installed the rudder with epoxy . ( she will sail straight ) I drilled the hole in the boom for the topping lift and installed a small metal cleat (left over from the lobster smack build) here are the results
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Link to comment
And here is the rest of the pic's
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Link to comment
Link to comment
Thank you, David and Geoff, she is a beauty
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Link to comment
Looks great Pete,
nice also the yellowish tone of the Sub waterline rudder blade in comparison to the hull varnish tone
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Thank you Nils , thats the beautiful thing about wood . You dont know how the color is going to turn out until the finish is on it .
Thank you Robert ,  I prefer to make all the parts that I can.  The Herreshoff boat's are amazingly beautiful ,  I hope that I captured that essence
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
