Licorne by mtaylor - (POF) - 3/16 - TERMINATED LOG
Thanks for dropping by and the kind words Aldo, Juergen, and Mobbsie.
I've been working on the gundeck capstan.  I'm on hold for the foredeck capstan as it's smaller and I wanted to see how the big one went first.  Taken several tries but that part of learning. Mostly, I had issues with the power tools.. the mills specifically in setting things up.  Somewhere around here are probably 10 to 15 bits of things that went flying off before I figured how how to get everything clamped down perfectly..   Live and learn.
I also had to do some research.  The plans and most of the builds I've seen for French ships show the capstan style from the late 1600's to the mid-1700's.  I finally located several pics of some ship models for the mid-late-1700's.
First picture is of the parts (but not the whelps).
This was the fun part.. using the rotary table.  Had a bit of problem figuing out how to secure things to it. Took a couple of runs to various hardware stores for some M6 screws and nuts but I got it sorted out.   Below are the parts set up for rounding off and starting the machining.  The spindle has been machined down.  As for the chunk on the left,  I ended up using a tapered wood screw to center the wood square pieces and secured with washer and nuts.  I didn't get a picture of that.
After machining in the pawl slots on the bottom and the bar slots on the head, I assembled everything (but not glued) for a size check. Twas a bit too high.
After re-sizing the height, I finished the shaping of the head and then reset the height again.... it was still to high.  It's been taken apart, re-machined for height and reglued.
Right now the whelps blanks are drying in position and I'll spin it on the lathe to shape them.  Probably tomorrow.  I hope.
Side note.. I have an old coffee cup that is kept about 1/4 full of alcohol.  Simple matter to drop the whole assembly in and in a bit, it comes apart.  Wipe off the softened glue and the parts are as good as new.  Save a lot of re-making parts when some part of the assembly need re-work or replacement.
Edited by mtaylor
Corrected mis-type
Link to comment
Share on other sites
Very nice work Mark!
Mike
Current Wooden builds:  Amati/Victory Pegasus  MS Charles W. Morgan  Euromodel La Renommèe
Plastic builds:    SB2U-1 Vindicator 1/48  Five Star Yaeyama 1/700  Pit Road Asashio and Akashi 1/700 diorama  Walrus 1/48 and Albatross 1/700  Special Hobby Buffalo 1/32  Eduard Sikorsky JRS-1 1/72  IJN Notoro 1/700  Akitsu Maru 1/700
Completed builds :  Caldercraft Brig Badger   Amati Hannah - Ship in Bottle  Pit Road Hatsuzakura 1/700   Hasegawa Shimakaze 1:350
F4B-4 and P-6E 1/72  Accurate Miniatures F3F-1/F3F-2 1/48  Tamiya F4F-4 Wildcat built as FM-1 1/48  Special Hobby Buffalo 1/48
Citroen 2CV 1/24 - Airfix and Tamiya  Entex Morgan 3-wheeler 1/16
Terminated build:  HMS Lyme (based on Corel Unicorn)
On the shelf:  Euromodel Friedrich Wilhelm zu Pferde; Caldercraft Victory; too many plastic ship, plane and car kits
Future potential scratch builds:  HMS Lyme (from NMM plans); Le Gros Ventre (from Ancre monographs), Dutch ship from Ab Hoving book, HMS Sussex from McCardle book, Philadelphia gunboat (Smithsonian plans)
Link to comment
Thanks Mike.
Ok.. I lied.. not intentionally... I couldn't wait to shape the whelps.  It has a few rough spots to be cleaned up, but I'm pretty darn happy with it.
Link to comment
nice capstan Mark...well worth the effort!  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
finally located several pics of some from the mid-late-1700's...
Funny I didn't think they had photography that far.... back I could be wrong of course... have been many times before ;)  :P
Michael
Link to comment
Thanks Popeye.
Michael,
Oops... :blush:   I meant pics of models...Sometimes my fingers out type my brain. :)
Link to comment
Thanks Harvey.   Don't toss the kits... just bash them. :)
Thanks John.  You don't have to worry.   It's back in the bottle now that I'm done ripping the capstan apart. ;)
Link to comment
Wonderful work Mark.  I'm smiling with your success.
Augie
Current Build: US Frigate Confederacy - MS 1:64
Previous Builds :
US Brig Syren (MS) - 2013 (see Completed Ship Gallery)
Greek Tug Ulises (OcCre) - 2009 (see Completed Ship Gallery)
Victory Cross Section (Corel) - 1988
Essex (MS) 1/8"- 1976
Cutty Sark (Revell 1:96) - 1956
Link to comment
Nice job Mark. Of course the re-dos were really just an excuse to play with the power tools some more!!! ;)
Link to comment
Very nice work.
Bob
Current build:  SS_ Mariefred
Link to comment
Terrific and inspring work Mark!!
(Unlike others, when I see a full scratch built I get ascared and retreat to the safety of my kit and practicums :P )
-Adam
-Adam
Current Builds
Santa Maria - Artesania Latina (1:65) POB
MayFlower - Model Shipways (5/32"=1') POB
Blue Shadow - Mamoli Revolutionary War Brigantine. (Fict) (1:64) POB (Recommissioned as the Kara June)
On The Shelf Waiting so Patiently
USRC Ranger - Corel (1:50) POB
18th Century Longboat - Model Shipways (1:4) POF
La Nina - Artesania Latina (1:65) POB
U.S Brig Syren - Model Shipways (1:64) POB
Completed Builds
Phantom NY Pilot Boat - Model Shipways (1:96) Solid Hull
Decommissioned Builds
(Time and conditions were not good to these. They have been cancelled =( )
Willie L Bennett - Model Shipways (1:32) POF
USRC Harriet Lane - Model Shipways (1:128) Solid Hull
Link to comment
Thanks for the nice comments everyone.
I'm at a point of comtemplating the next step.... more furniture?  I have the fireplaces to do.  Or finish the planking in the Great Cabin?  Or maybe...?   I'm thinking I'll finish the Great Cabin before the fireplaces.  In looking back, I can see errors and areas that could be better overall but when I did them, my skills just weren't there.  But as someone has said, it's the next ship that will be better.  :)
Hmm... I just realized that I'm putting off the exterior planking.. :P  :P  :P
Link to comment
Isn't it great to have so many choices :) ?
Augie
Previous Builds :
Link to comment
it might be wise to do the hull planking before more structures are added.    then it can be taken out of the jig........although making the structures now is a good ideas as well......it well protected.  just keep them removable for now,  if you choose a different route.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Thanks everyone.  It is I who needs to thank everyone for not only the inspiration but the encouragement to push my limits and become a better modeler.  I'm not there yet, but my confidence level is building.
Decisions, decisions...
Popeye,
The pumps and capstan are loose right now as at some point there's artillery to be built, fitted, and installed.  Fat fingers and small parts in the way aren't a good mix. :)
Harvey,
Your Conny is practically a scratchbuild.. ;)
Link to comment
lol you will say that on your next build as well, - just that the bits you are not happy with then - will be better than the bits you are happy with on here - thats life - i quess
Edited by Kevin
Its all part of Kev's journey, bit like going to the dark side, but with the lights on
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
HMS Indefatigable 1794 by Kevin - Vanguard Models - 1:64 - Feb 2023
HMHS Britannic by Kevin
SD 14  - Marcle Models - 1/70 - March 2022 -  Bluebell - Flower Class - Revel - 1/72   U552 German U Boat - Trumpeter - 1/48  Amerigo Vespucci     1/84 - Panart-   HMS Enterprise  -CAF -  1/48
Finished
St-Nectan-Mountfleet-models-steam-trawler-1/32 - Completed June 2020
HMS Victory - Caldercraft/Jotika - 1/72 - Finished   Dorade renamed Dora by Kevin - Amati - 1/20 - Completed March 2021
Stage Coach 1848 - Artesania Latina - 1/10 -Finished Lady Eleanor by Kevin - FINISHED - Vanguard Models - 1/64 - Fifie fishing boat
Link to comment
Thanks B.E. and Kevin.
Kevin,
You're right.. but then, I think it goes with being modelshipbuilder. :)
Link to comment
Hi Mark.... just catching up on your progress, your work is really out standing, and I enjoyed the video, was interesting.
Frank
completed build: Delta River Co. Riverboat     HMAT SUPPLY
                         USRC "ALERT"
in progress: Red Dragon  (Chinese junk)
Link to comment
Mark,
I have just been reading through your build, and love what I have seen, except for the fingers, sorry.  I was wondering what glue you were dissolving with the alcohol on the capstan.  That could be useful information to me.  I have been away from my build for the last couple of weeks (my wife's health issues).  I hope I can remember what I was working on when I get back home in another week or so.
Keep up the good work (CAREFULLY)!
Walter Biles
Link to comment
Thanks Frank.  I posted elsewhere about the videos on this particular ship.. Or you just go to Youtube and search by the name.  Interesting stuff.
Thanks Walter.  I'm using PVA.. Elmer's Wood Glue, specifically.  If you need to dissolve CA, use acetone but do follow all precautions.  That is some nasty stuff.
Link to comment
Nice job on the CAPSTAIN Mark.........!
Thank You all...
Mario
:piratetongueor4:  :piratetongueor4:
"Each of us is a mixture of some good and some not so good qualities. In considering one's fellow man it's important to remember the good things ... We should refrain from making judgments just because a fella happens to be a dirty, rotten SOB(biscuit) ;) "
My Builds....
BETTEAU WAR OF 1812     BOUNTY LAUNCH(bashed)    CHESAPEAKE BAY FLATTIE
THE SEA of GALILEE BOAT   VICTORIAN STEAM LAUNCH(bashed)    HOWARD CHAPELLE's CRABBING SKIFF
LADY KATHRINE 1812 SCHOONER
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
