HMS Snake by Beef Wellington - FINISHED - Caldercraft - Scale 1: 64 - First wooden ship build
Sailor - cheers.
Does the hull just sit in the supports, or is it fastened to them?
Robert
Robert - I was planning on just having her sit in the cradles, it seems pretty sturdy.  I have thought about putting a few small rods in and drilling a couple of holes in the keel bottom to be doubly sure, but I think unless there's an earthquake should be solid, especially once in a case (that I have yet to figure out as well).  Any recommendations on either point would be appreciated.
Cheers,
Jason
In the shipyard:
Link to comment
Share on other sites
Hi Jason
please do tell us about the base..
Where did you buy it from?
Thanks
ST
Stergios, this is where I found the base - www.historicships.com, I went with the mahogany.  The wood for the cradle got from www.woodcraft.com.   Shipping is pretty high from both.  The cradle was made by using the contour gauge against the hull to get the shape and then cutting out with a fret saw - basic woodworking but I haven't had to do anything like this since school so was a bit trial and error  :)
Cheers,
Jason
In the shipyard:
Link to comment
Thank you Jason
I'm still trying to declare what's the more safe way of keep her stable and safe in to the future. Placing her on a base using cradles or fixing her on two 2mm rods as I have already predrilled the respective holes at her keel....
Happy New Year !!
Link to comment
Love what your doing here Jason, the base and stand looks very good.
Be Good
mobbsie
mobbsie
All mistakes are deliberate ( me )
Current Build:- HMS Schooner Pickle
Completed Builds :-   Panart 1/16 Armed Launch / Pinnace ( Completed ),  Granado Cross Section 1/48
Harwich Bawley, Restoration,  Thames Barge Edme, Repair / Restoration,  Will Everard 1/67 Billings
HMS Agamemnon 1781 - 1/64 Caldercraft KitHM Brig Badger,  HM Bomb Vessel Granado,
Thames Steam Launch Louise,  Thames Barge Edme,  Viking Dragon Boat
Next Build :-
Link to comment
Cheers Mobbsie and all the 'likes'.
Think I'm officially into the rigging stage.  Mizzen mast stepped and the shrouds in installed.  I'm going to wait to finish 'tightening' these until later.  Found the method of getting the 3.5mm deadeyes into the shrouds at the correct height very fiddly, after many choice words found that using 2 pieces of wire in the holes worked better for me (rather than a single one as called out in the instructions) as this provided some more stability.  Hopefully the 5mm deadeyes will be a little easier.
Theres quite a stack of shrouds around the mast which is quite pleasing, glad that these were served.  Following Andy's advice the Burton pendants were 'painted' with quite a bit of dilute PVA and then weighted so that they followed a more natural, less gravity defying line.
A belated Happy New Year to everyone!!
Edited by Beef Wellington
Cheers,
Jason
In the shipyard:
Link to comment
Looks nice Jason.  I'll be doing the same very shortly.....
John
Current Current Builds:
US Brig Niagara on my website
FINISHED BUILD LOGS:
New Bedford Whaleboat - page on my Morgan Website:  http://www.charleswmorganmodel.com/whaleboat-build-log-by-john-fleming.html
C.W. Morgan - Model Shipways 1:64 http://modelshipworld.com/index.php?/topic/1785-cw-morgan-by-texxn5-johnf-ms-164-kit/
USS Constitution - Revell 1:96 http://modelshipworld.com/index.php?/topic/1796-uss-constitution-by-texxn5-johnf-revell-196-kit/
website US Brig Niagara Model http://www.niagaramodel.com
website Charles W Morgan Model http://www.charleswmorganmodel.com
website PROXXON DISCOUNT TOOL STORE http://proxxontoolsdiscount.com
Link to comment
Great job Jason !
2 things.....
You have on the mizzenmast no platform ?
Be careful that you take enough distance between your deadeyes.
The are short all ready and when you tying up the lanyards and the tension in the shroud is working, you have the opportunity that the deadeyes are "kissing' each other.
I had that problem with the Le Mirage and had to change it.
Best wishes my friend !
Edited by Sjors
Link to comment
Great job Jason !
2 things.....
Hi Sjors - no, there is no platform on the mizzen mast, the mizzen mast seems quite 'stunted' compared to larger ship rigged vessels.  The mizzen cross tree is about the same size as the crosstrees on the main and fore top masts.
Here is a picture of the deadeyes but not yet tightened fully, please tell me if I've done something wrong.  I first put the shrouds around the mast and then looped around the deadeyes before seizing them.  As is the shrouds looks taught, but I'm not sure how taught these need to be - the .75mm line seems much stronger than the masts at this scale and I'm worried I'd break something if they needed to be much tighter.
Cheers,
Jason
In the shipyard:
Link to comment
Hi Jason,
You don't do anything wrong.
The only thing that I was talking about is when you tight up the lanyards and there is much stretch in the shrouds, you pull the deadeyes together to each other.
I know from previous builds that the stretch can be a lot.
Better is to keep the shrouds a little bit shorter so you have the opportunity to pull the lanyards straight and avoid touching of the deadeyes.
I hope you understand what i mean.
Link to comment
Here is a picture of the deadeyes but noit yet tightened fully, please tell me if I've done something wrong. I first put the shrouds around the mast and then looped around the deadeyes before seizing them. As is the shrouds looks taught, but I'm not sure how taught these need to be - the .75mm line seems much stronger than the masts at this scale and I'm worried I'd break something if they needed to be much tighter.
Hi Jason,
Those look spot on to me. I didn't tighten too much when I rigged the lanyards, just enough to get some tension in the shrouds.
Jim
Current builds:
HMS Snake
HMS Hood
Mechanical Solar System
Completed builds:
HMS Ballahoo
Link to comment
Sjors - understand you perfectly, thanks.
Jim - appreciate the confirmation
Full steam ahead it is...I suspect that the other shrouds and stays will take quite some time, but already I hear the very faint Syren's song of the ratlines.
Cheers,
Jason
In the shipyard:
Link to comment
Nice looking work Jason!
- Bug
Link to comment
She's looking great Jason! Glad to see the rigging coming together - the shrouds are laid very nicely.
hamilton
current builds: Corel HMS Bellona (1780)
MS Glad Tidings (1937) (in need of a refit)HMS Blandford (1719) from Corel HMS GreyhoundFair Rosamund (1832) from OcCre Dos Amigos (missing in action); Amati Hannah (ship in a bottle); Mamoli America (1851)Bluenose fishing schooner (1921) (scratch)
under the bench: Admiralty Echo cross-section; MS Emma C Barry; MS USS Constitution; MS Flying Fish; Corel Berlin; a wood supplier Colonial Schooner Hannah; Victory Models H.M.S. Fly; CAF Models HMS Granado; MS USS Confederacy
Link to comment
Really great work Jason.  I'm a bit further along in rigging my Badger, but I think I would have had an easier time going with your approach of adding the mast sections and accompanying rigging in sections, rather than building the entire mast, stepping it, and trying to run the rigging.  Things get a bit complicated with the lines doing it the latter way.  The only good reason to do it the latter way in my opinion is that it is probably easier to ensure that the mast sections are all lined up correctly.  I'll be interested to follow your steps and see how you liked your approach.
Mike
Current Wooden builds:  Amati/Victory Pegasus  MS Charles W. Morgan  Euromodel La Renommèe
Plastic builds:    SB2U-1 Vindicator 1/48  Five Star Yaeyama 1/700  Pit Road Asashio and Akashi 1/700 diorama  Walrus 1/48 and Albatross 1/700  Special Hobby Buffalo 1/32  Eduard Sikorsky JRS-1 1/72  IJN Notoro 1/700  Akitsu Maru 1/700
Completed builds :  Caldercraft Brig Badger   Amati Hannah - Ship in Bottle  Pit Road Hatsuzakura 1/700   Hasegawa Shimakaze 1:350
F4B-4 and P-6E 1/72  Accurate Miniatures F3F-1/F3F-2 1/48  Tamiya F4F-4 Wildcat built as FM-1 1/48  Special Hobby Buffalo 1/48
Citroen 2CV 1/24 - Airfix and Tamiya  Entex Morgan 3-wheeler 1/16
Terminated build:  HMS Lyme (based on Corel Unicorn)
On the shelf:  Euromodel Friedrich Wilhelm zu Pferde; Caldercraft Victory; too many plastic ship, plane and car kits
Future potential scratch builds:  HMS Lyme (from NMM plans); Le Gros Ventre (from Ancre monographs), Dutch ship from Ab Hoving book, HMS Sussex from McCardle book, Philadelphia gunboat (Smithsonian plans)
Link to comment
Here's some good news for all you Snake modelers out there looking to get rich :P .  Check out the link below, seems the going rate for a completed model is around GBP 1,450 (~US$2,400) which includes the case.  Its clear no one does this to get rich!
http://www.rubylane.com/item/802481-3341/Fine-Cased-Model-1797-Sloop
Cheers,
Jason
In the shipyard:
Link to comment
Jason,
  I once calculated the highest possible amount I could sell my San Juan for, then divided it by how long it took me to build and came up with a potential earning of something like $2 an hour...  hehe.
- Bug
Link to comment
Well Jason,
You're responsible for me getting to be a half hour later as I've read all the way through your log.  She looks great and you can see the benefit from all the extra work you are putting in.
Colin
Current Builds: HMS Pandora 1/64 Scratch
                         Jeannie Johnston;
                         18thC Longboat with my son
Previous Builds: HMB Bounty - Caldercraft
Running Round my head: HMS Speedy (1782) - vaguely thinking POF
"If at first you don't succeed, try it your wifes' way"
Link to comment
Now you've made me go and do some extra work on my Burton Pendants. :D :D :D :D :D :D :D
Got to soak and weigh them down now, good thinking mate. ;) ;)
I like what you are doing here, clean and tidy, don't worry about the ratlines, the king of ratlines i.e. Sjors, will always help you out if you need it. :o :o
Be Good
mobbsie
mobbsie
Next Build :-
Link to comment
Bug - nice to have you on board.  I think I'm below the $1 mark  :P
Colin - thanks for kind words, I'm learning from your wonderful Pandora
Mobbsie - it was Andy that put me onto that.  Anyway, I owe you at least a couple for the 'mouse' help...speaking of..
First Mouse:
I've been procrastinating over my first mouse on the mizzen stay.  Size was estimated from various drawings.  Followed Mobbsie's method and made the mouse out of wood dowel and glued onto the line which was then served.  PVA glue was brushed onto the wood to keep the serving line in place (this photo is the second attempt and you can see the fuzz from attempt 1)
Finished moused end...Lever identifies a pretty small eye vs the instructions which call for a much larger one against the mouse.  The stay was served a little beyond the mouse which per Lever can be done "according to fancy".
Mizzen stay in place...it looks OK to me but as always would welcome feedback if I'm off track before committing to this.
Cheers,
Jason
In the shipyard:
Link to comment
Nicely done, I like the serving....your pictures show us how it's supposed to look.  Thanks..
John
Link to comment
Andy - appreciate the observation, I had tried what you describe before taking the photo, but it just didn't look right.  Turns out, I had the stay going under the wrong cross tree arm.  All corrected now and sits a treat on the crosstree
BE, John, Jim and the 'likes' - thanks as always
Main Stay and Preventer Stay collars
Started tackling the main and preventer stay collars while waiting for some line to stretch out for the main mast shrouds, (still don't feel I have the shroud thing figured out just yet, but its early days...).  After a bit of a break in the shipyard, these took a full day to complete.  The instructions indicate that the collars should be lashed under the bowsprit through some eyes, but I decided to take the approach outlined in Lever for these.  Unfortunately, because the gammoning is in place, a lot of fiddly steps needed to be done on the ship.
As anyone who's done any serving knows, and I'm rapidly learning, is that the process requires you to know the correct length of line you need to serve because 'trimming a bit off' isn't an option.  Here's the first step figuring out the length of served line I'll need.  Marker pen on similarly sized natural line.
Detail of the final collar as per Lever
Main stay collar in place...
...and preventer stay.  I had added the cleats onto the bowsprit before mounting, and commented at the time that the plans were inconsistent.  Luckily the collars seem to sit nicely where intended
Cheers,
Jason
In the shipyard:
Link to comment
Interesting approach and info on serving.  I'll be doing that soon and it is something new.....never done before, thanks for the pictures....
John
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
