Cutty Sark by coffeebeans - Artesania Latina - scale 1:84
Very very very well and nice
Go on !
In progress:
CUTTY SARK - Tehnodidakta => scratch => Campbell plans
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-1#entry64653
Content of log :
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-62#entry217381
Past build:
Stella, Heller kit, plastic, Santa Maria, Tehnodidakta kit, wood, Jolly Roger Heller kit, plastic
Link to comment
Share on other sites
Onwards with the build, and onto the side rails and embellishments
first off the list was the troublesome stern part of the kick board, the angle needed was tricky to get with the provided sapelli, the grain of almost all strips were to an angle rather than ripped straight, meaning any attempt at bending ended up with it flaking out at the bend.
Finaly, after about 5 attempts i had one i could work with
from then on it was fairly easy sailing
here it is blended in
now for the uprights, these were spaced at 14mm
the 'embelishments' took a fair chunk of time to make, and i wasn't too keen on them protruding from the sides, but this was just a case of what the kit called for, also i am awear that they dont continue around the stern on the actual ship but the kit instructions pictured them to
Edited by Luca_B
Link to comment
Very nice. Looking real sharp mate.. You did a good job bending that stern piece.. Not surprising it took a few times.. Regards Oliver
Link to comment
Very good, Luca
You follow plans well, even plans are quite different than CS in Greenwich on stern inside bulwark
Those white panels ... They take couple of months on my CS, and they are so small, you can not even sneeze when working with them
Realy nice looking inside bulwarks
Keep god work !
Nenad
In progress:
Content of log :
Past build:
Link to comment
Impressive Luca! Please keep moving on this amazing work. Very sharp and clean!
Thanks for sharing with us. Can't wait for new photos :)
Cheers, Bugra.
There is nothing that a little sanding can't solve.. Bugra.
Current Builds :
H.M.S. Triton Cross Section by Bugra - 1/48
Turkish Traditional Ship - Surmene Takasi by Bugra - 1:35
Link to comment
Hey Luca,
I am really enjoying your log of Cutty Sark. I intend this to be my next model so be warned, I will be poaching some of your great techniques! Hope you don't mind.
Great photos too of great build.
Cheers,
Peter
Build Log: Billing - Cutty Sark
In The Gallery: HMS Unicorn, HMAV Bounty, L'Etoile, Marie Jeanne, Lilla Dan, Zeeschouw "Irene"
A Toast: To a wind that blows, A ship that goes, And the lass that loved a sailor!
Link to comment
Thanks guys for all the kind words, they really kick me on in this build.
hmm it seems my first two pages of pictures have vanished.
would anyone have a quick fix for this, or do i just have to reload them?
Edited by Luca_B
Link to comment
Hi Luca
  is there a reason why I'm unable to view your photos all I'm getting arew numbers and a jpg letters
and when I try to click it, it starts buffing and never shows up, reason I want to follow your post is that
 I also have the AL Cutty Sark  kit
                                       Ronald
Link to comment
Hi Luca
                                       Ronald
Hi Ronald.
yeah the server for the site apparently had a glitch so i will have to reload my pictures again, will get onto it soon hopefully.
also a quick update.
first on the list was finishing off the railing.
The kit instructed to use 1x3 sapelli, which i thought wouldn't be thick enough, but used it anyway.
the upside was it was realy easy to shape to the curve, also it dosnt look too out of place there.
Next I tackled the rub rails.
main problem with this was the bend at the stern, and limited material i had left for it.
Luckily i planned way ahead by buying the same dimension of styrene moulding.
This made making the curve a breeze.
I had seen this done on another log somewhere here, cant exactly remember where sorry
Link to comment
Nice job, Luca
You have got right angle and curve of stern profile, which is really tricky.
In the middle of the deck it seems that you had a small barely visible problem with the width of the bulwarks, or with a line of deck ?  It is not quite visible, but right on that place, I bumped in swamp, so I looked very carefully. Or, it is only angle of shooting ?
Keep good work
Nenad
Edited by Nenad M
In progress:
Content of log :
Past build:
Link to comment
Nice job, Luca
Keep good work
Nenad
Haha yeah it is a bit off, i only really noticed it a quarter of the way through, the problem was I thought just cutting mass strips at 5inch would work rather than slowing down and marking it all out on ply, I didn't think it would really matter back then, but of course I nearly lost sleep over the damn thing...
Lucky the caulk isn't as dark, it should be drowned out with all the fittings
Luca
Link to comment
... it should be drowned out with all the fittings ...
Just like that. My mistakes are much bigger, and intend to overload whole deck to mask them. Yours are invisible. That is exactly point in one of my first posts about "not run" thing. Saving all lines and curvatures and angles of deck lines and hull lines in proper shape and proportion is pretty f*** thing to do. I discover this too late, you have better luck or more skill
Waiting for more of your good work
Nenad
Edited by Nenad M
In progress:
Content of log :
Past build:
Link to comment
Fantastic work Luca. The whole hull,strakes and bulwarks look great. Coppering next?
Cheers
Alistair
Cheers
Alistair
Current Build - HMS Fly by aliluke - Victory Models - 1/64
https://modelshipworld.com/topic/34180-hms-fly-by-aliluke-victory-models-164/
Link to comment
Thanks all for the kind words.
Bob, same felt here. I defiantly wouldn't have got this far by now without everyone's help and helpful build logs to get inspiration.
And yes Alistair, onto the much anticipated coppering!
First off i feel like an idiot, i may have wiped the SD card of the camera unknowingly.
Luckily only losing a small part of the build, but still wasn't too happy...
all i could salvage was one photo of drilling the port holes
anyway this is the stage i am at now.
Paint is down, with some touch ups needed, photo etch parts glued into place and also started with the first run of copper plates.
the copperline instructed by the kit felt to me to be way too low, opinions on where it is now before i get too ahead of myself?
Thanks
Luca
Link to comment
Luca,
It all depends which period you want to depict. The load line during the tea runs on China was higher than during the wool runs on Australia. I can get you the exact figures but I need to go out for a few hours. When I get back, I'll look it up.
Lou
Link to comment
Luca,
Lou
I reckon ive nutted it out Lou, ive been looking through all pictures i could, especially your onedrive, and it looks to be alright.
this AL kit is more so on the 'stylized' side than 100% accurate replica ,what i am wanting to achieve on future models.
Next kit i buy or even scratch build i will research a bit more and spend a bit more where it counts, any ideas of good kit brands?
I have heard caldercraft is quite good, but Amati fittings are from what i have seen, quite accurate.
Thanks
luca
Edited by Luca_B
Link to comment
Ah, old everlasting modeller question
Triple "A" rule
Artistic or Accurate Approach
keep good work
Nenad
In progress:
Content of log :
Past build:
Link to comment
ive done a little cropping to get an idea of how close it is.
as shown some of the preformed ply pieces like the name plate and the beak aren't exactly right in the kit making it seem a bit off but im thinking of just going for it.
Edited by Luca_B
Link to comment
For people taking the Accurate Approach: B) (like me, the nutty professor)
From the Original specification:
No.58 Yellow Metal Sheathing. Vessel to be sheathed from Keel to 18 ft water mark on top of paper and tar sheathing to be to be smoothly put on, sheets to be 22, 24, 26 oz. metal.
This applies to her period as a tea clipper. From this figure and the scale you are using you could calculate how high the the sheathing should go. During her wool period under Captain Woodget the load waterline was 20 ft. (higher than in the tea period, not lower as I wrote before) and the sheathing should end a bit above that.
Finally, for smart appearance the upper belt was raised a bit at both ends of the ship.
Lou
Link to comment
Lou, what you meant was that she FLOATED higher right? ;) LOL
As far as raising the ends a bit, it was raised more in the bow and the reason was so that the bow didn't look droopy. Because the bow is closer to the centreline of the boat (obviously) a straight line will move further from the viewer when seen in profile view. By adjusting it up a bit aft and even a bit more forward, you compensate for this tromp d'oeuil.
This slightly raised bit was the boot topping or boot top. Often times (though not in the case of our ship) a different colour of paint between the bottom paint/copper and her topside paint.
Edited by Sailor1234567890
Link to comment
quick question, what would the preferred layout of the tiles be?
would it follow the same pattern of this picture?
i am unsure of what would be right for the cutty.
also this is my first coppering attempt, any help or tips would be much appreciated!
thanks
Luca
Edited by Luca_B
Link to comment
I haven't a clue about the right height for the waterline for Cutty Sark. Overall your build looks amazing - very crisp and clean.
For the plating I suggest working from the keel upwards. That way if you do need to overlap the plates the lap will be on the upper side of the run. I found overlapping and avoiding stealers gave me the result I wanted. That said my hull is much more curved than Cutty Sark.
Cheers
Alistair
Cheers
Alistair
Link to comment
Your post beat mine. That looks like a very complex layout. Perhaps simplify with overlaps? I'm sure it is right but it just looks very difficult to do. Coppering isn't easy as I have found and just getting the hull coated is enough. Perhaps go for the two top lines of copper and then dress up from the keel? Or do a gore line and lay up from that? In any case I still reckon go from the keel up and you can overlap the plates as you need to.
Not much help I'm afraid, others may offer better.
Cheers
Alistair
Cheers
Alistair
Link to comment
Thanks Al and Bob, yeah I know it isn't a clipper, was just wondering if we followed the same sort of guidelines.
I think I will just do the two waterline rows then come up from the keel as suggested.
Just wondering Bob, did you end up doing a row at the waterline, or sheared the last plates to the waterlines horizontal level?
I have looked through your log but it's hard to spot.
Thanks
Luca
Edited by Luca_B
Link to comment
In the tea period she floated higher (draught 17'6") so the upper sheathing belt ended lower. In the wool period she floated lower (draught 20') because of the heavier cargo, so the sheathing ended higher. Or the other way around. At the moment she doesn't float at all. :(
Lou
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
