Cutty Sark by coffeebeans - Artesania Latina - scale 1:84
Luca, following Campbell's plans, I tried to introduce gore strakes whenever I saw the plans depict them, and things just seemed to fall into place.  I did one strake at a time, port and starboard, and used calipers to make sure everything was symmetrical.
Bob
Link to comment
Share on other sites
  • 6 months later...
Hello everyone, I've had a little break on my build while coppering but did bits and pieces here and there but its FINALY nearing completion!
Along the way I had a few hiccups... one being after the majority of plates being fixed finding out the nail orientation was upside down :S also just the general laying out of the plates was a bit frustrating and probably not ideal.
anyway work on the plates is nearly complete, appart from the rudder which im currently working on now, Its been a while since ive worked with timber :S
Link to comment
Veeeery good! I like it!
Can you attach some close up of stern and bow decoration?
Edited by Nenad M
In progress:
CUTTY SARK - Tehnodidakta => scratch => Campbell plans
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-1#entry64653
Content of log :
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-62#entry217381
Past build:
Stella, Heller kit, plastic, Santa Maria, Tehnodidakta kit, wood, Jolly Roger Heller kit, plastic
Link to comment
thanks guys, i have been looking at your builds closely too and seeing heaps of great stuff.
Here you go nenad, they were just the photo etched brass pieces from the kit but i might modify the rear to come out a bit,
also still not finished painting and trimming the styrene strips yet , im going to just go over it with some gold and black when i get around to it
Edited by Luca_B
Link to comment
little bit of work on the rudder tonight, hopefully ill finish coppering it and solder up the hinges.
For brass blackening i found this from an Australian hunting site,
also i know people say diluted hydrochloric acid is good for cleaning the brass before hand but im not quite sure what ratio water to acid or if i should bother using it at all, Thoughts?
Link to comment
Thats it for me tonight, hopefuly thats the last copper plate i see in a while...
the rudder is ready for the hinges and mounting but first im going to have a go at blackening the brass, hopefuly there are no hiccups.
Link to comment
Very nice work in a rudder
In progress:
Content of log :
Past build:
Link to comment
G'day all, small halt in construction due to a few end of year surgeries and recovery but back to it with a bit of a back log seeing as i didn't have access to a computer at that time.
first off the list the rudder was to be completed.
Using blackened and niped short nails i pilot holed through the timber and used a dab of ca gel to hold the pins in place
also added was the ring at the rudder breach
Edited by Luca_B
Link to comment
Next to go were the hatchways, thank god back to some timber work!
just following the instructions the hatch ways seemed to be protuding quite a bit so i sanded them down to just above the covers height
also this tool i picked up for measuring is a must have, i dont know what i did with out it for multiple common parts
This is my method of blackening the handels of the hatch covers.
it involves cleaning for about 10 mins with either a diluted acid or metho, then washing the parts with water, then dunking in the blackening liquid and siring.
i am pretty new to the whole thing and still haven't found the sweet spot but im sure ill pick it up
Edited by Luca_B
Link to comment
now for the chainwales, starting off with these 'sapeli' blanks i sanded the back side to the curve if the ship then added the deadeye chain holes and pins.
to make painting the pins easier i masked the pre holed plank and put the pins in dry for a coat of matte black
post-6383-0-36573800-1419830969_thumb.jpgpost-6383-0-36045300-1419830971_thumb.jpgpost-6383-0-09081100-1419830973_thumb.jpg
Link to comment
for a few of the other cutty builds i have seen some attempts at the dead-eye strap/clamps, it looks a bit much for me so im going to have to compromise but not by much :)
here are the front two chainwales in place ready for deadeyes
for the forming of the brass wire i used some jewlers pliers to bend to a workable circumfrence
then using the kits pre made deadeye blocks i just inserted them and completed the loop with pliers and cut to length
then for a coat of black paint on the lot followed by a white acrylic modeling marker ran over the brass itself, sort of representing the white straps used on the cutty.
a better representation of this would have to be Bob's build on page 48 he has a prototype of what it should realy look like
Link to comment
Hello Luca
I hope you are doing well
Keep going with nice work
All best wishes for hollidays
Nenad
In progress:
Content of log :
Past build:
Link to comment
for something a little diffrent i thought id tackle one of the catheads and FINALY figured out hot to get better shots of my work with an iluminated magnifying glass! as shown in the later pictures
starting with walnut 4x4 blanks i cut and shaped one to size
then for the pulley holes the instructions stated 2 lots were drilled where my other more reputable book said 3, so i went with 3.
i then added a brass band at the end with ca glue, then sanded it back, and also a couple brass eyelets for the release rod
a hole was now cut into the railing to accommodate this
dry fitting, painting and fitting then took place
for the cathead figure i use some bakable modeling clay and cut a rough cats head
and here it is with all parts assembled
Edited by Luca_B
Link to comment
One of my favorite ships and you're doing a fine job.
Cheers and Happy New Year
GEORGE
Link to comment
Thanks George, I picked her up after seeing my partners grandfather's model of the ship, I loved the shape and look and still do. Edited by Luca_B
Link to comment
Hello Luca
Nenad
Yeah getting better every day, it does give me some time to build so that's an upside :)
Happy holidays to you also
Luca
Link to comment
Just finishing work on the catheads, also paint and placement of the capstan.
for the deadeyes i foresaw a bit of a problem with fitment.
if i fitted them now the rigging will become quite a pain in the...
So for now im just drilling the holes to suit and waiting until i start the rigging.
next of the list are the 'wardrooms', the pre lasered parts that came with the kit wernt really up to scratch, the walnut arches crumbled at the slightest touch of the exact-o blade.
also the variety of timbers they have asked to use are pretty clashing to me, so i have stained the lasered ply a redish jarrah color and will cover the darker timbers in a thinned stain/varnish.
All i could really do was re enforce the rear side with watered down pva and hope it held together
Link to comment
Luca,
well done !
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
  • 2 months later...
Hi Luca,
Just finished going through your thread, really fine job so far.  The Cutty Sark is one of my favorite ships and will be next on my list.  Looking forward to your next update and following your progress.
Cheers,
Boyd
Boyd
Current Build - HMS Bounty - Artesania Latina - Scale1:48
Link to comment
Hi Luca,
I was just catching up with your Cutty Sark. Nice work indeed. I have been neglecting my shipyard, but you are giving me a huge boost in my own inspiration.
Thanks for posting all your pictures!
Peter
Build Log: Billing - Cutty Sark
In The Gallery: HMS Unicorn, HMAV Bounty, L'Etoile, Marie Jeanne, Lilla Dan, Zeeschouw "Irene"
A Toast: To a wind that blows, A ship that goes, And the lass that loved a sailor!
Link to comment
"...for the deadeyes i foresaw a bit of a problem with fitment.
if i fitted them now the rigging will become quite a pain in the..."
Real pain ... what tools to use
... and a bit of panic ... how thin ropes for deadeyes have to be ... inside deadeyes lower than main rail are thrue challenge ... 4mm deafeye with three holes ..
Huh huh huh
In progress:
Content of log :
Past build:
Link to comment
  • 1 year later...
  • 8 months later...
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
