Licorne (1755) by mtaylor - (POF) - 3/16 - French Frigate (Hahn) - Version 2.0 - TERMINATED
Looking very nice Mark. Shame about the broken frames, but nicely recovered.
Link to comment
Share on other sites
Hi Mark.
That is some really nice work on that framing as well as the repair work. It's always fun making more
frames once you thought you were done huh? ;)  I also like being able to use the framing jig upside
down and right side up. Did it a couple of times and thought it was great.
Rusty
"So Long For Now" B)
Current Builds: Speedwell
Link to comment
Thanks Rusty and Grant.
I'm firm believer in Murphy and "crap happens" so being prepared for re-do's and do-over's and repairs is part of the building process.
David and Sam,
Saw blades in abundance, I have.   My current favorite for this work is the one that X-acto makes that resembles a #11 blade with teeth on it.  Since the frames are laminated of two pieces (one forward, one aft) the glue line is the problem.  I'm not sure alcohol is the answer because it can weaken the joint above and below the cut.  I thought about filing out the waste area but that's time consuming, tedious, and I'm not sure I could get it exact or even close.
There's only 3 more gunports which are in the aft cant framing. So I'll muddle along using the current process.
I still will have to file/sand out the sides of each port a bit more.. but that's not bad.
Link to comment
Hi Mark,
To cut out my ports I used a Razor Saw which I'd ground a section about 50mm long off the end until it was only a couple of millimetres wide. This lets me get into some really tight places :) .
:cheers:  Danny
Cheers, Danny
Link to comment
Mark, if I recall correctly when you layed up the frames you turned the grain slightly, I can see where that would stop you from making a cut top and bottom then just "breaking" along the grain. Could you make lots of little saw cuts an nibble away with a small chisel? There is a name for the technique but its eluding me at the moment. That might help cut the parts out without breaking?
Sam
Current Build Constructo Enterprise
Link to comment
David and Sam,
hello Mtailor.
I always thought Murphy lived very near my house. je je je
Link to comment
Link to comment
Link to comment
Thanks for looking in and commenting Danny, Sam, Cabrapente, David, and Sjors.
Murphy apparently took a few days off (thank heavens) as things went well.
Sam, if I remember, I'll do a quick photo essay when I cut the next gunport which will be later in the week.
I got the hull (what there is of it so far) faired out close.  It will still need work but that will come after the cant frames which is the next project.   There's still some low spots and high spots but overall, pretty close.
I also reshaped/reworked the rabbet so the planking will set right.   It was tedious and had me sweating blood but worth every second of it.
The keel has glued on and sits square and level with everything.
Link to comment
Mark....happens to the best. As for me (not even close to being among the best) re-doing my mistakes seems to have become a way of life lately.
"That which does not kill us makes us stronger".....Friedrich Nietzsche....Must have been a very good modeler.
Dave
Edited by SawdustDave
Sawdust Dave -
Current build - USS Constitution 1:60th (scratch)....
Visit my blog site - All previous builds.... http://davesmodelships.blogspot.com
Link to comment
Very nice work Mark.  This is going to be a beauty :)
Mike
Current Wooden builds:  Amati/Victory Pegasus  MS Charles W. Morgan  Euromodel La Renommèe
Plastic builds:    SB2U-1 Vindicator 1/48  Five Star Yaeyama 1/700  Pit Road Asashio and Akashi 1/700 diorama  Walrus 1/48 and Albatross 1/700  Special Hobby Buffalo 1/32  Eduard Sikorsky JRS-1 1/72  IJN Notoro 1/700  Akitsu Maru 1/700
Completed builds :  Caldercraft Brig Badger   Amati Hannah - Ship in Bottle  Pit Road Hatsuzakura 1/700   Hasegawa Shimakaze 1:350
F4B-4 and P-6E 1/72  Accurate Miniatures F3F-1/F3F-2 1/48  Tamiya F4F-4 Wildcat built as FM-1 1/48  Special Hobby Buffalo 1/48
Citroen 2CV 1/24 - Airfix and Tamiya  Entex Morgan 3-wheeler 1/16
Terminated build:  HMS Lyme (based on Corel Unicorn)
On the shelf:  Euromodel Friedrich Wilhelm zu Pferde; Caldercraft Victory; too many plastic ship, plane and car kits
Future potential scratch builds:  HMS Lyme (from NMM plans); Le Gros Ventre (from Ancre monographs), Dutch ship from Ab Hoving book, HMS Sussex from McCardle book, Philadelphia gunboat (Smithsonian plans)
Link to comment
She is looking very good Mark, so now you ar ready to tackle the challenging frames.
Michael
Link to comment
Mark,
   A little at a time is working for you. Screw the sweat, in the long run it is lest re-work. Who cares how long it takes. Your doing an excellent job and learning and having a good time, isn't this suppose to be a hobby. Keep the pictures coming, and Thank you for sharing this with us.
Wacko
Joe :D
Go MSW :) :)
Link to comment
She's looking fantastic Mark!!
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
Link to comment
Looking very nice Mark. Can't wait to see the cant frames in place.
Link to comment
been out of the loop for a bit.........sad to have heard that you were having trouble with the gun ports, but I see you have that well in hand now! she's looking really good.......time well spent, in my view! very nicely done ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Thanks for the likes and comments.
Didn't get much done yesterday or today.  Yesterday had the heatpump and all the ducting in the house cleaned and serviced.  The temp hit 104 degrees F, and it was just too hot until the A/C finally got everything cooled down.
Today was rib day with homemade Jerk Sauce.  After marinating and slow cooking on the grille, I'm in heaven.   Ok.. so this doesn't turn into Facebook...
Michael
Indeed, but I'm wimping out and doing the aft frames first.  They're not as challenging.  :)
Mark,
My thinking exactly, Joe.  I might sweat while doing it, but at the end of the day, it feels good.
Licorne is coming along nicely. Well done. The piece of ebony for the false keel will look terrific when finished. Will you be using ebony for the wales?
Alan
I'll be using ebony for the top rails, channel wale and the upper most piece of the main wales, Alan.  The mains blend into the planking.  So they aren't distinct. Here's a pic showing the cross section.  Ignore the arrow as the pic is from another discussion.
I can't wait for the cants, either, Grant.  But I'm being cautious on this build.  I don't want to do a Ver 3.0.
It's just the materials and the size, Popeye.  I'm learning.... ever so slowly.. but still learning.
Link to comment
She's looking good Mark , nice work
Best Regards,
Pete
"may your sails be full of wind and the sun on your back"
Current Builds :
 Future Builds :
N.G Herreshoff 12 1/2 Scratch Build 3/4" = 1' - 0" Scale
Completed Builds :
Volvo 65 Farr Yacht Design
Herreshoff Alerion
Volvo Open 70
 Member :
The Herreshoff Registry                                  Montgomery Sailboat Owners Group       Peter Kunst Sailboat Models
http://www.herreshoffregistry.org/                       http://www.msog.org/                      http://www.facebook.com/Peter-Kunst-Sailboat-Models-1524464774524480/
Link to comment
I mentioned above about how I cut gunports.   So here's how I do it.  I make no guarantees that it's the best way but it works for me.
First up is a laminated frame blank (I'm using a half frame as the full frames are done).
I then rubber cement the frame plan to it and carefully cut it out.
I fit the frame into position and check all the reference points both against the plans and in situ using the EdT tool. After that, the reference points are etched using the scroll saw and the frame cuts are made with the saw pictured.
I soak the joint in 91% isopropyl and wrap in a scarp of paper towel which is also soaked in the isopropyl.
The joint is then wrapped in plastic wrap and secured at each end with clothes pins (pegs) so as not let the whole frame separate.
After doing something else for about a half an hour, I grab the frame with pliers and piece to be removed with a pair of cutters.
A slight pull and the piece comes out, usually cleanly.
At this point, the frame is glued into place, space blocks added between the newly installed frame and the existing frame, everything clamped and the glue allowed to cure.  After curing, I double check all reference points, just in case....
I hope this helps someone.
Link to comment
i love being part of the MSW community again and catching up on everyone's logs again, mark this looks brilliant, well done
Its all part of Kev's journey, bit like going to the dark side, but with the lights on
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
HMS Indefatigable 1794 by Kevin - Vanguard Models - 1:64 - Feb 2023
HMHS Britannic by Kevin
SD 14  - Marcle Models - 1/70 - March 2022 -  Bluebell - Flower Class - Revel - 1/72   U552 German U Boat - Trumpeter - 1/48  Amerigo Vespucci     1/84 - Panart-   HMS Enterprise  -CAF -  1/48
Finished
St-Nectan-Mountfleet-models-steam-trawler-1/32 - Completed June 2020
HMS Victory - Caldercraft/Jotika - 1/72 - Finished   Dorade renamed Dora by Kevin - Amati - 1/20 - Completed March 2021
Stage Coach 1848 - Artesania Latina - 1/10 -Finished Lady Eleanor by Kevin - FINISHED - Vanguard Models - 1/64 - Fifie fishing boat
Link to comment
Very nifty Mark.  I made a not of it, just in case - - -  ;)
Cheers,
                       VOC Ship Surabaya
Link to comment
Thanks for the "likes" and comments.
Sam,
On Licorne, they are 1/2 the frame thickness.  Other ships... not going to vouch for them.  I have some other Hahn plans which when I dig them out of the dark recesses of my storage area, I'll check.
Link to comment
Wow Mark, Incredible workmanship . Thanks for showing how you did it  " Amazing "
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
