Licorne (1755) by mtaylor - (POF) - 3/16 - French Frigate (Hahn) - Version 2.0 - TERMINATED
Just love the lay of the lines.  Made the hair stand up on the back of my neck.  What's an inch or 2 between friends!
Augie
Current Build: US Frigate Confederacy - MS 1:64
Previous Builds :
US Brig Syren (MS) - 2013 (see Completed Ship Gallery)
Greek Tug Ulises (OcCre) - 2009 (see Completed Ship Gallery)
Victory Cross Section (Corel) - 1988
Essex (MS) 1/8"- 1976
Cutty Sark (Revell 1:96) - 1956
Link to comment
Share on other sites
An additional hint: once I have a strake of planking laid, I run a sanding stick along the edge of it to ensure it is even and lines up with my mark-out before proceeding with the next strake.
Link to comment
Thanks again for the "likes" and comments.
I never thought of doing the whole strake, Druxey.  I've doing that at the joints only.   Thanks for the tip.
Link to comment
You're right, Robin...  I'll amend that from now on so "abuse is always welcome". :)  ;)
Link to comment
Checking in again, great to see the progress on the planking, I would imagine that on the full size ships of the period that a 3 inch variation would have been part of the plus or minus tolerance during the planking up from the keel and would have been corrected over a few planks as Druxey suggested on the model planking.
Michael
Link to comment
nice to see an update on her Mark.........very nice work!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Thanks for feedback, comments, and likes.   Garboard strake on both sides is in and I'm lining things off and sorting out the planking strategy.  Right now, life keeps getting in the way.  :)
Link to comment
You've got her planking well beyond the critical stage at this point Mark. Just a matter of keeping tight fitting back to the garboard.
Smooth sailing from here. She really looks great.
Edited by SawdustDave
Sawdust Dave -
Current build - USS Constitution 1:60th (scratch)....
Visit my blog site - All previous builds.... http://davesmodelships.blogspot.com
Link to comment
I still cannot wrap my head around the skill necessary to do what you are doing.  Such an incredible looking piece of work and such work going into the incredible looking piece.
Just amazing man, just simply amazing....
-Adam
Current Builds
Santa Maria - Artesania Latina (1:65) POB
MayFlower - Model Shipways (5/32"=1') POB
Blue Shadow - Mamoli Revolutionary War Brigantine. (Fict) (1:64) POB (Recommissioned as the Kara June)
On The Shelf Waiting so Patiently
USRC Ranger - Corel (1:50) POB
18th Century Longboat - Model Shipways (1:4) POF
La Nina - Artesania Latina (1:65) POB
U.S Brig Syren - Model Shipways (1:64) POB
Completed Builds
Phantom NY Pilot Boat - Model Shipways (1:96) Solid Hull
Decommissioned Builds
(Time and conditions were not good to these. They have been cancelled =( )
Willie L Bennett - Model Shipways (1:32) POF
USRC Harriet Lane - Model Shipways (1:128) Solid Hull
Link to comment
Thanks for the likes and comments.   Short update time.
I've laid 12 stakes of the 8" wide planks...  15 to go.   Looks rough but I'm seeing light so what appears to be gaps is just mismatch in thickness and shadows... I hope. :huh:
From the re-lining off I just finished a strake ago, I won't need a stealer at the stern.  Looking at the French ship monographs I have, a short, wide plank can be added such that the strake is continuous.  I've added one and probably won't need any more. From the dead flat, the strakes run from 8" to almost 4" and then back to 8" at the sternpost.
On the bow side, the planks run from 8" at the dead flat and then eventually taper to 4".  However, at least one drop plank is needed which will be put in in my next two strakes.  I'm trying hard to keep scale on this even though it looks strange due to the scale (to my eye at least).
First two pics show her in all her unsanded, rough looking planking.
The third pic is my side project, the longboat.  I needed a way to do this so thought, fiddled, thought, and then came up with a plan I think will work.  I'm using a variation of Chuck's method.  I did have to re-do this once already as for scale, the frames should be 2" (1/32") wide, but I kept breaking them and then realized there wasn't enough meat to hold the planks securely. So, I doubled the width of the frame.  We'll see where this leads.... hopefully not the scrap bin. :)
All in all, I'm pretty pleased.  There's some things I need to think about for the next ship, like is scale planking better or worse than eye-appeal cause these planks are relatively tiny compared to the planks I've used in the past.
Enough over-thinking for now... pressing on.
post-76-0-53521600-1443044719_thumb.jpgpost-76-0-04508100-1443044732_thumb.jpgpost-76-0-83127500-1443044746_thumb.jpg
Link to comment
It doesn't look like you have much more to go with the planking Mark.   :dancetl6: Nice work!
Edited by GLakie
GEORGE
Link to comment
Very nice symmetry as seen from the stern view.  Going to look great after sanding/finishing.  Will the hull be a natural finish ?
Augie
Previous Builds :
Link to comment
coming along very good Mark........you almost there!  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Coming along beautifully, Mark !!
(By the way, that's a fantastic idea pre-marking the frames for your planking.)
CaptainSteve
                        Apostol Felipe (OcCre)
                        HMS Victory (Constructo)
Link to comment
Hi Mark
Really nice work on both hulls! The long boat is a surprise because I hadn't recalled you mentioning that you'd started it before, but nonetheless, it'll be a welcomed side project to Licorne.
I also must echo what everyone else has said about the planking of Licorne's hull - terrific job, that's for sure!
All the best
Patrick
Link to comment
Very nice planking there Mark.  After sanding it'll be a jewel.
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
Link to comment
Thank you for the comments and likes.   It is shall we say, interesting, doing a French ship when all you've ever looked into was the American and English vessels.
Steve,
I picked that up from here on MSW and also from a couple of books.  Keeps one honest in the planking.  :)
Omega1234, on 23 Sept 2015 - 5:53 PM, said:
Hi Mark
All the best
Patrick
Hi Patrick,
I mentioned way back here;  http://modelshipworld.com/index.php/topic/5339-licorne-by-mtaylor-pof-316-french-frigate-hahn-version-20/?p=331918 when I started cutting parts for the longboat.  I started one early on using a plug while waiting for the wood for the framing but that bit is in the fireplace. It just wasn't working for me.  I made some basic mistakes in the plug...
Link to comment
Omega1234, on 23 Sept 2015 - 8:59 PM, said:
Thanks Mark, Definitely getting old!!!!
Cheers
Patrick
I am too.  I had to do a search and see if I had mentioned it. :blush:
Link to comment
Very sharp Mark!  the symmetry is spot on.
cheers
Pat
Link to comment
The planking looks marvelous, looking forward to see the sanded version ... I see you've been toasting wood again ... that long boat looks like a real challenge ... you could have tried Johann's (Archjolo) method if you wanted more meat ...
Carl
Link to comment
Nice!! looking planking Mark......... it's getting there!!
frank
completed build: Delta River Co. Riverboat     HMAT SUPPLY
                         USRC "ALERT"
in progress: Red Dragon  (Chinese junk)
Link to comment
Minor update for the ship... a big one for me.
Planking continues.  No pics yet.  But while waiting for glue to try, etc. I've been busy working on carvings... or trying to anyway.  Also made minor progress on the longboat and a few drawings for parts needing to be cut out.
So.. the carvings.  The picture shows the first one I've attempted..  well actually it was the 4th attempt and hopefully, I can live with it.  The first two carvings I'll need are the name cartouche on the stern and Arms of France above the stern windows.  Mulling it over, I went for the "easy one".    I soaked them in isopropyl for about 12 hours and that removed most of the char.
I ended up doing bas-relief style on it after several failures of trying to carve the letters such that they stand proud.  Not going to happen in my lifetime. So I ended up removing the char as I carved out about 1/2mm deep leaving the lip and lettering (as one area not the individual letters) standing proud.  A touch of well-thinned brown paint (used a needle for this) and what I wanted highlighted is now about as good as it will get.  It actually looks better in real-life as most of us don't have eyes with macro mode. :P  :P
Onwards......
Link to comment
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
