Licorne (1755) by mtaylor - (POF) - 3/16 - French Frigate (Hahn) - Version 2.0 - TERMINATED
Doesn't look bad to my eye Mark.  I know my first attempts at carving will be nothing short of laughable.  :P
GEORGE
Link to comment
Share on other sites
Interesting method Mark; I am assuming you laser cut this then cleaned the char and did a bit of relief carving - did I get that right?
cheers
Pat
Edited by BANYAN
Link to comment
Thanks for the comments and the "likes".
cheers
Pat
Exactly Pat.  I couldn't (and I did try) cut something out that tiny to save my soul.  I did do a clean-up and relieve between "La" and "Licorne" but it was touch and go as even the smallest scalpel I have was almost too big.
Link to comment
Pretty cool!! Mark....
frank
completed build: Delta River Co. Riverboat     HMAT SUPPLY
                         USRC "ALERT"
in progress: Red Dragon  (Chinese junk)
Link to comment
I think they look great Mark. Like you said, none of us have macro eyes, well all except maybe my boss but his eyes arent human.
I dont think you need to change anything, but if your goal was to have the letters stand proud, could you set the laser to remove everything but the letters?
Sam
Current Build Constructo Enterprise
Link to comment
Sam
Dooohhhhhhh............ post-76-0-67529200-1444021299.gif    Now that the gauntlet has been tossed, I must try it.  Yeah... leave the letters and burn the area I want to shave down.... hmm... rats... still leaves clean up around them.  That probably won't work either.   Good idea though.....
Link to comment
RESPECT, Mark that looks fantastic, it looks to me that you have got it just about right. If it looks better in the flesh than in the picture then I would say your already there. :dancetl6:
I know it may be late but you have made a superb job on your stern counter, it certainly paid off to do the redo although it may not have seemed like it at the time. Lovely stuff. :)  :)
Kudos all round mate.
mobbsie
mobbsie
All mistakes are deliberate ( me )
Current Build:- HMS Schooner Pickle
Completed Builds :-   Panart 1/16 Armed Launch / Pinnace ( Completed ),  Granado Cross Section 1/48
Harwich Bawley, Restoration,  Thames Barge Edme, Repair / Restoration,  Will Everard 1/67 Billings
HMS Agamemnon 1781 - 1/64 Caldercraft KitHM Brig Badger,  HM Bomb Vessel Granado,
Thames Steam Launch Louise,  Thames Barge Edme,  Viking Dragon Boat
Next Build :-
Link to comment
How bad is the char? You mentioned rubbing alchohal(?) to clean up most of it? Do you by any chance have one of those cheapie sand blasters? http://www.harborfreight.com/21-oz-hopper-gravity-feed-spot-blaster-gun-95793.html
We use something similar at work to sandblast detail into foam for plugs with corn starch or baby powder. Turn the air down low.
Just a thought, again I think what you have looks great.
Sam
Link to comment
Mark, you could also use a Macaroni chisel (yes, there is such a chisel and it's not made from semolina ;) ).  Pfeil makes them down to 4 mm in width. Some other brands may go as small as 2 mm. It has a square shape and cuts on three sides. Looks like picture below.  Would be far easier than trying to program the laser.  BTW I have two of these chisels.
Looks great as is tho. Nice job.
Edited by Jack12477
Link to comment
Thanks for the "likes" and comments and for helping me push the envelope a bit further.
Sam
Sam, no sand blaster here.  The alcohol soak gets the smoke and much of the char off.  A bit sanding takes care of the rest.  :)   It's not so much the char that is the problem but the Euro Boxwood seems to have a lot oil in it that turns into a black glaze when hit by the laser.  Not a serious problem though.
Jack,  I've got chisels (Dockyard brand) down to 1.5 mm and a couple of micro-surgery scalpels even smaller.  The lettering on the plaque is <1mm high.
Link to comment
Microsurgery ... I like it !
In progress:
CUTTY SARK - Tehnodidakta => scratch => Campbell plans
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-1#entry64653
Content of log :
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-62#entry217381
Past build:
Stella, Heller kit, plastic, Santa Maria, Tehnodidakta kit, wood, Jolly Roger Heller kit, plastic
Link to comment
Jack: how do you sharpen a small macaroni chisel? I've always been curious about that.
Have not had to do that to mine yet.  Just stropping it (carefully) has kept the edge sharp.  You have to strop each side individually just like you would a V-gouge. Before I start carving I strop any knife/gouge first then after about 10-20 minutes of carving I stop and re-strop them before continuing. That pretty much keeps the edge razor sharp (at least for me).
To re-sharpen it I would image you would start with the flat bottom, sharpen it on a stone, then do each side holding the side flat to the stone, then use a small square stone to sharpen the inside edge. I would not try to use a belt sander on this one. Some of my woodcarving mates use small belt sanders to do their knives and gouges even V-gouges.  I would do this one by hand on a very flat stone probably one of my ceramic stones.
It does do a nice job of cutting a squared bottom / side tho and without a lot of effort.
The Pfeil brand chisels come razor sharp and honed right out of the box so they are ready to use immediately.
Edited by Jack12477
Link to comment
Jack: ¿Como afilar macarrones cincel pequeño de la ONU? Siempre que Teñido eso Sobre curiosidad.
Druxey hola. Yo no soy un experto, pero con la Dremel y archivos pequeños, hice mis propias guvias.
practicando en poco tiempo obtendrá un buen progreso.
Pongo fotos de mis guvias. y aliexpres, es una tienda a través de Internet, no hay costos de transporte. Puse 2 enlaces: 4 guvias 1,5 mm y guvia 1 1 mm.
saludos cabrapente
http://es.aliexpress.com/item/Trumpeter-09923-Micro-Model-Chisel-F1-Flat-1mm-Tip-1x1mm-Free-Shipping/2020492323.html?adminSeq=201843456&shopNumber=413964
http://es.aliexpress.com/item/Free-Shipping-4Pcs-Big-Size-Woodpecker-Dry-Hand-Wood-Carving-Tools-Chip-Detail-Chisel-set-Knives/32233733646.html?adminSeq=201687738&shopNumber=1342030
Edited by cabrapente
Link to comment
Mark,
Nice job on the carving. You could cut out the letters and glue them on another piece of wood if you wanted more height and better access to the crannies and nooks in the letters ... looking at the result, you hardley need the height ... it stands out pretty well on it's own!!!
There we need a sharpening steel Druxey ... a common kitchen utensil ! Comes in mighty handy in modelbuilding ...
Which means ... trial and error ... toss the ones which are ruined after sharpening and buy a new one ... which is sharp like a rasor on arrival, and doesn't need sharpening ;) (saves a lot of time sharpening too! ;) )
Cheers
Carl
Link to comment
Thanks, Jack, for describing how you keep your macaroni's edges keen. I have a number of other Pfeil brand craving tools, and can attest to their sharpness, as well as their quality, straight from the factory.
Link to comment
Carl,  it's cheaper to keep them razor sharp - these tools in US retail starting at $45-$55 and upwards per chisel.  Kitchen steel will ruin one of these chisel.  Rather we use either a ceramic stone (new type) or the older style Arkansas stone.  The ceramic stones do not need a lubricant like the Arkansas stones do and the sharpen a lot faster. I've used both and prefer the ceramic for my carving tools; I use the Arkansas for other knives (e.g. pocket knife).
Druxey: The other brand, which I do not have (yet), that is as sharp as Pfeil with same quality is Two Cherries brand.
Edited by Jack12477
Link to comment
I've not used the water-stone yet but plan to get one sometime in future. And, yes, I forgot to mention that I use a leather strop with a white chalk-like "pumis" (for lack of a better name) which I dust onto the leather.
Link to comment
When was moved my sister packed my stones.  But they left my leather strop.  Now I have to get a new one when I get  chance.
David B
Link to comment
Minor update... planking is ongoing but I needed a break.  So back to the longboat.
Reworking again... 5th time I think, the form for making the longboat.  1st was the hand carved plug... tossed it.  2nd was the bulkheads like Chuck uses and BE did so well at 1:64...  broke the bulkheads.  3rd was the same using thicker bulkheads, still broke off the framing bits.   4th was a plug that used the laser to cut out... Something hiccupped and it came out 1" too long.  I'm still not sure what happened...  So.. number 5... in all it's glory.  Exact size and I'm happy.   Now to put it together and start adding stuff like frames and keel.  :)
Link to comment
I'm not sure how many is the charm anymore, George.   I know I turned the air blue and paint peeled off the walls when the keel didn't fit...and then I discovered what happened.....  Even the dog hid. ;)
Link to comment
I remember those feelings also. Got them a few times on the different work sites. Show 'em what to do and even demonstrate how to do it, and they still get it wrong. Yeah ---- I've "lost it" a few times!   :D
GEORGE
Link to comment
Something to consider for keeping carving tools sharp:
Get some pieces of scrap leather from a local shop that works leather.
Coat the smooth side with Flexcut Gold Polishing compd.
It comes as a stick - use like a crayon to coat the leather.
Strop the edge frequently - pull the blade.
I must sometimes move the blade slightly in the cutting direction when I place it on the leather - I can tell because it messes up the surface of the leather.  Several back up pieces of leather is useful to have.
Unless you mar the edge of the tool by hitting steel or something, you should not need to use a sharpening stone ever again.  Stropping should be enough.
NRG member 45 years
Current:
HMS Centurion 1732 - 60-gun 4th rate - Navall Timber framing
HMS Beagle 1831 refiit  10-gun brig with a small mizzen - Navall (ish) Timber framing
The U.S. Ex. Ex. 1838-1842
Flying Fish 1838  pilot schooner -  framed - ready for stern timbers
Porpose II  1836  brigantine/brig - framed - ready for hawse and stern timbers
Vincennes  1825  Sloop-of-War  -  timbers assembled, need shaping
Peacock  1828  Sloop-of -War  -  timbers ready for assembly
Sea Gull  1838  pilot schooner -  timbers ready for assembly
Relief  1835  ship - timbers ready for assembly
Other
Portsmouth  1843  Sloop-of-War  -  timbers ready for assembly
Le Commerce de Marseilles  1788   118 cannons - framed
La Renommee 1744 Frigate - framed - ready for hawse and stern timbers
Link to comment
Your 'bread 'n' butter' longboat be coming along nicely there, Mark.
Ah yes ... the wailing and gnashing of teeth, as well as ample usage of ye olde sailing language, wouldst be a staple in my build room.
:cheers:
Edited by CaptainSteve
CaptainSteve
                        Apostol Felipe (OcCre)
                        HMS Victory (Constructo)
Link to comment
Ah yes ... the wailing and gnashing of teeth, as well as ample usage of ye olde sailing language would be a staple in my build room.
:cheers:
I thought that was a prerequisite for ship building?
I think you're on to the solution with V5.0 Mark. Will be watching closely, I would like to add a ships boat or 3 to my next build.
Sam
Link to comment
Hi Mark -
Looking good.  That stack of lifts for the longboat should work out well.  Looking forward to your progress.
For carving those really small letters, I have had some good success by using micro-bitts for the Dremel that I have accumulated over the years.  Here is a photo of some of the smaller ones.  The last on the right is from my dentist, who is a great source of tiny tools.
Dan
Current build -SS Mayaguez (c.1975) scale 1/16" = 1' (1:192) by Dan Pariser
Prior scratch builds - Royal yacht Henrietta, USS Monitor, USS Maine, HMS Pelican, SS America, SS Rex, SS Uruguay, Viking knarr, Gokstad ship, Thames River Skiff , USS OneidaSwan 42 racing yacht  Queen Anne's Revenge (1710) SS Andrea Doria (1952), SS Michelangelo (1962) , Queen Anne's Revenge (2nd model) USS/SS Leviathan (1914),  James B Colgate (1892),  POW bone model (circa 1800) restoration
Link to comment
Carving out the inside of that boat will be easier with a moto-tool and a small bit then finish with sandpaper to clean it up.  I normally use my Foredom as I have more control over the carving.  Besides I foolishly brought my Dremel to work so I could sharpen a bunch of spur bits that our grinder was too large for and it walked off.  Since I never used it for modeling I did not miss it.
David B
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
