This small board works well for plastic. or wood.  I use a low angle block plane on a 1/4 inch acrylic base. the base is stroked with a little candle wax to lubricate the plane.
In the video the plastic block is approximately 3/8 inch thick x 1 inches wide the plastic is evergreen styrene strips glued together.
Michael
  • 8 months later...
