18th Century LongBoat by jburchfield1 - Model Shipways - 1/4" scale - SMALL - 1st ever build
Link to comment
Share on other sites
Tks everybody.
Floyd, not treenailing this one.  Too small and I had enough problems just getting the planks on!   :D
Mike - Nope, no holes.  Just for clarification "in service" means (at least to me) that the boat is being used on a daily basis - not looking like it just came from the manufacturer.  That look (new) is ok, I just prefer something that looks more aged/scuffed/used.  Although, there are a couple of small holes in the planks at the stern between the 3rd and 4th planks (that spot where there is such a major change of direction.
Grant - I just meant I didn't follow the instructions.  But since I eventually want to scratch build, guess maybe that's a good thing.  Just couldn't get the edge glued boards cut without snapping something off somewhere.  So made them out of one piece.
Working on the thwarts and locker today.
Previous build(mostly) - 18th Century Longboat
Current build - Bounty Launch
Next build - San Francisco by AL
Future build - Red Dragon
Future build - Mayflower from Model Expo
Link to comment
I was working on the oars while waiting for paint to dry and I have a question.
If my math is correct (5" oar x 48" scale = 240" or 20 feet).
Were the longboat oars really that long?
Link to comment
Longboat 1:48 scale 1/4"=1ft
Here is a good link on oars. . .   https://sites.google.com/site/shipwrightsfaq/smf-qoars
Edited by Stuntflyer
Current build - Sloop Speedwell 1752 (POF)
Completed builds - 18 Century Longboat (POB) , HM Cutter Cheerful  1806 (POB), HMS Winchelsea 1764 (POB)
Link to comment
Tks for the link.
I don't have any boating/sailing experience (except one 3 day gambling cruise) and the only oars I've ever seen belonged to a canoe.
Never realized that there were so many (and so long) types of oars.
Link to comment
Party Time!!   :dancetl6:
Just successfully blacked my first brass parts.  Those parts for the thwart holding the mast.
Took several tries, but figured out that if I run the brass strip thru some 400 a couple times before I make the parts, they are much cleaner and take the blackener perfectly.
Can't focus the camera that close so no pic, but you'll see them on the next shot.
Link to comment
Pops, Did you try Acetone? I prefer the Acetone to sanding. But you are correct you need to treat the metal before you blacken. I soak in Acetone then rinse. After everything is completely dry I blacken. I use a 2:1 mixture of the Blacken It. I am also careful to rinse this so that the chemical reaction stops. And then get it completely dry so that there is no rust.
Current Builds - 18th Century Longboat, MS Syren
Completed Builds - MS Bluenose, Panart BatteStation Cross section, Endevour J Boat Half Hull, Windego Half Hull, R/C T37 Breezing Along, R/C Victoria 32, SolCat 18
On the shelf - Panart San Felipe, Euromodel Ajax, C.Mamoli America,
Its a sailor's Life for me! :10_1_10:
Link to comment
Floyd - Yeah, I tried the acetone, didn't clean it enough.  My process was - draw the brass thru some 400 sand paper a couple times on the flat surface, then soak in acetone for 10 minutes, rinse, soak in vinegar for 10 minutes, rinse, soak in Novacan Black for about 10 min, rinse, pat dry.
I figured the acetone would remove finger oils left after sanding/handling.
However, I used a 10 to 1 ratio for the Novacan Black.  Maybe not strong enough because I noticed that it rubbed off in a couple small spots.
Actually, just read the instructions (gotta learn to do that first) and it says to use it straight from the bottle - so that's probably the problem.
Link to comment
Well, I've made a little bit of progress.
Here's the hull after the first coat of poly.  post-12441-0-55682600-1403892069_thumb.jpg
It's not as "glossy" as in the images, but I'm gonna use a little steel wool, when it's finally completely dry.
I've noticed that putting enamel (testors) over the stain (minwax) extends the dry time from hours to days.  Is that common?
Maybe I should be using acrylics?
Link to comment
Got everything done up to the rudder.
Have not yet purchased the materials/torch for silver soldering what would be the second best method......
Regular CA, Extra Thin CA, or epoxy to attach the "pins" to the gudgeon?
Link to comment
That's what I would do Pops. CA should be the trick
Link to comment
I did it with gel CA (gel super glue). Regular or extra thin CA is very liquid, and will flow away from the tiny metal pieces, gluing your fingers to the planks. Terrible thing!
Link to comment
Contact cement works very well in these situations where you have two dissimilar materials to join.  Apply a tiny bit to the pintle/gudgeon and to the model. Let dry according to the directions and then mount the hardware.  Just remember, you only have one try with contact cement.  The advantage is you do not have to worry about glue seepage.
Toni
Chairman Nautical Research Guild
Current Builds:     NRG Rigging Project
Completed Builds: Longboat - 1:48 scale       HMS Atalanta-1775 - 1:48 scale       Half Hull Planking Project      Capstan Project     Swallow 1779 - 1:48 scale               Echo Cross Section
Link to comment
Every time I use CA I am reminded why it was invented in the first place. To glue skin. :P
Link to comment
Toni, that "one try" thing is why I don't use contact cement anymore.  Hands are a little too shaky now.
Did it with CA (gap filling) and seemed to work fine.
Got the rudder on today and that completes everything ('cept the tiller and windlass handles which will be the very last 2 things to go on.
Sorry no pics, I'll get some up tomorrow.
Got my "lathe" set up so I can start tapering the masts, etc.  I'm hoping the rigging will be just as much fun (though frustrating at times) as the rest has been.
Link to comment
Well, got the bow sprint mounted today.  Have completed shaping the boom and gaff, but have to re-do the main mast.  Seems I can't drill a perfectly vertical hole consistently.  Pictures to follow.
I have learned the following important things while working on this longboat...
1.  I love this craft/hobby without reservation.
2.  The most important thing (in my opinion) is accurate measurements (down to 1/64").
3.  Patience and perseverance are critical.
I'm changing my next build to the Bounty Launch so that I can get more experience planking and proper measuring (on a less expensive model) before I move to larger craft.
Edited by Pops
Link to comment
Pops, You may want to consider getting some additional wood for your Bounty Launch. I knew someone who built it with the wood supplied and he broke quit a bit of it trying to soak and bend.
Link to comment
Well, here's the pics I promised.  In real life things are not as "shiny" as they appear in these pictures.
Interior, everything done except tiller and and "arms" for the windlass......
Outer hull...............
Floyd - I just got notice from Model Expo that my 4 packages of 1/32" x 1/8" x 24" basswood have shipped.  Not sure what size is used for the Launch, but should be close and I still have about 25 12" strips from buying the Longboat twice.
I want to try boxwood but can't get it from Hobby Mill (because I live in Ohio as well) and I'm still not sure how to go about it at the Lumberyard (haven't figured out what the process is and how to make sure I'm ordering the right thing) but planning on getting "better" wood when I start my first larger ship.
Edited by Pops
Link to comment
As another alternative you could try using hard maple and that is available here in sheets and strips.   Very inexpensive.  the wood is much harder than basswood and I have in fact used it for another pinnace build.   I used it for the frames and keel.   After applying wipe on poly it looks very good and very similar to boxwood.   It is not as hard as boxwood and you cant get as sharp an edge on teh wood but it is leaps and bounds better than basswood.
http://www.nationalbalsa.com/category_s/232.htm
Chuck
Link to comment
Ahem, Well if it will help you and Jeff do business. I would be willing to be the transshipment location. I.e. you order from me and I order from him. Slight shipping cost should be the only issue.
Link to comment
Chuck - Thanks much for the link.  That looks good and also it's 1/16" which gives me plenty of sanding room!   :piratetongueor4:   Got it bookmarked so I can pre-order when the time comes.
Floyd - Thanks for the offer BUT it's a sales tax issue for him and you know how the government gets when they don't get their share.   Don't want to create trouble for anybody.  B)
Link to comment
Link to comment
TKS for the kind words guys.
It's acceptable for a first attempt, but will do things differently for the next one.
Currently trying (and trying and trying and trying) to make those teeny, tiny, did I say tiny? jaws for the gaff.  Can't seem to keep from breaking them.
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
