Triton Cross Section 1:32 (Pete 38)
Very nice work Pete.I like your mill.Looks like it's very accurate. Frames are vere nice.      Larry
With Age Comes Wisdom,I'm Still Waiting!
Current Builds:Syren.Triton Cross section.
Completed Builds: Virginia by AL
                           King of the Mississippi by AL
                           Constellation by AL
Link to comment
Share on other sites
Pete, your mill work looks very clean and sharp. I've started a slush fund for my next possible buy for ship work and a mill is one of the items that keeps popping up on my shoulder. :)
1st Year Apprentice :mellow:
A new member of the NRG as of 8/28/13
Work in Progress -
 Triton 28 Gun Frigate Cross Section
Link to comment
I have now cut all the notch with my mill in the fames. Still have 2 frames left to be glued. Hopefully tommorrow.
With that done I can now glue up my keel and false keel and get them mounted to my building board.  Have been using the keel itself to check and size the notchs
I wanted to try the black paper approach to simulate the caulking at least 1 time so I fiqured this is the simplest place to try it.
I started by glueing the false keel to the black paper itself. I had heard somewhere that when using the paper it would weaken the joint, so I treated it like it was just another piece of wood to glue between the two.
After the glue had dried I then glued and clamped the keel to it
After the glued had dried on this assemble I scrapped the excess glue off. Dome some light sanding with a sanding stick with 80grit then used a razor blade to scrape to get the final finish on the piece.
I have left the false keel long on each end so that I can mount it securely to the build board with no worries of it moving.
This was the first time using the black paper and will propably be my last. I will go back to the pencel to simulate any caulking that I will do. The paper when sanding down can leave a mess on the wood that was a bit of a pain to get cleaned off. Even though it looks okay.
Edited by Pete38
SEE YA LATER
im-outta-here-bye-bye-smiley-emoticon.gi
Link to comment
Pete:
Nice work on the keel assembly. Everything looks very nealy done.
Russ
Link to comment
Since the last 2 frames are in process of being glue decided to start the treenails on the frames.
First I cut a piece of heavy plastic (from screw container) and made a template for the treenail positons. This in order to repeat my pattern with all the frames.
This idea was taken from some previous post on MSW1 (I had seen this in chad86 build)
Temporary attach to the frame with a little tape and mark the locations of the treenails with a pick
I marked the hole this way instead of using the plastic patten on the dremmel drill press so the hole would not loose their loaction
SEE YA LATER
Link to comment
I set up my dremmel workstaion with a scrap piece of wood on the bottom to prevent tearout in the frames as the bit passes through.
Made sure the drill bit  (.310 size) was square with the base
Then drilled the marked holes all the way through the frame. Being carefull to back the bit out multiple time to clean so as to keep the hole drilling straight.
I then started to install the treenail in the frame (using bamboo treenail)
When dry fitting the treenail in the frame there was no problem getting the treenail all the way through the frame, but when adding some waterdowned glue, this would swell the bamboo just enough to make it a problem getting all the way through. Have to work fast in order to make it in one length of treenail
SEE YA LATER
Link to comment
Pete:
That is very accurate work. One thing to consider is to use a drill bit that is a touch larger than your treenails. That will allow it to swell a bit with the glue. I would keep the bit you are using and just give the treenail stock an extra pull or two through the last hole in the plate you used. Just enough to give it a breath of clearance.
Russ
Link to comment
I received my Jim Byrnes draw plate about a 2 weeks ago. Haven’t had a chance to try it as yet. Looks like I made a good choice and will plan on using it and Russ’ notes about treenails to put it to work with this project. :)
Work in Progress -
Link to comment
Pete,
Those are some lovely frames.  Nice and exact work on the treenailing.
Link to comment
Mark  thanks for the nice compliment :blush:   Just try to make it so I don't have to go back and make the frames over again.  50/50 chance so far :D
Only 50-50?  I must have done something wrong then.  My scrapbox ate about 75% of my frames from this project.   :)
Link to comment
Hey Pete,
I echo what Kip just said about the restart of you build log.
Beautiful build you have going. I find section models very interesting. Your build logs are always a joy to visit. Thanks for sharing your techniques and methods.
Keep on.....
BFN
Cheers,
Hopeful aka David
“there is wisdom in many voices”
Completed: Sharpie Schooner (Midwest) Posted in kit build log.
Current: Sultana (MSW) Updating the build log and continuing on with the build
Next: Lady Nelson (Amati Victory)
Edited by hopeful
Link to comment
Pete
Your build is looking great.
Ron
Current Build: H.M.S. Triton Cross Section 1:48
Why is it that I always find out the best way to do something is after I have already done it the wrong way? - Me
Link to comment
Nice work Pete.                Larry
                           Constellation by AL
Link to comment
Just a small update. I have now all the frames glued up....rough sanded with the drum sander on the drill press... and the paper templated remove.  Will now concentrate on the treenails for each frame before raising them. Here's a few pictures
Could not resist just standing them on the building board ..keel for the pictures.. :D
SEE YA LATER
Link to comment
Great job Pete!
I do like the set square you have made with that round shape. It looks pretty secured with the screws and everything. It is also a neat contrast between the white layout and the wood of the frames and the keel.
I´ll stay tuned for more. It´s looking good to me!
Daniel.
Link to comment
Very nice Pete. Frames are looking very good.
Ron
Link to comment
Looking really nice. I hope you are enjoying it as much as we are.
Rusty
"So Long For Now" B)
Current Builds: Speedwell
Link to comment
