HMS Pegasus by vulcanbomber - Amati/Victory Models - 1/64
Well, I've been busy beavering away on Pegasus. :D
I'm working on a couple of different parts. I wanted the get the rubbing rails complete so made the quarter badges. They were really easy to make and look so effective.
The first two parts are wooden and painted black, here they are glued together:
The rest is of brass etch painted white, gold and ochre:
I glazed the windows, a piece of clear plastic is included in the kit for this. I found it easiest to cut a piece a bit larger then the window part I was glazing. I then used bostic all purpose glue, and with a pin, spread it on the back of the brass window and stuck it down on the clear plastic. When stuck, I used a sharp knife and cut around the window. any glue strands that showed through could be easily scraped off with a pin:
Glazed windows ready to attach to the wooden surround:
Make sure the windows are flush with the surface:
The two pieces for the top and bottom parts of the quarter badge are stuck together:
Then attached to the unit along with the two other parts:
Next were the posts that went between the windows. check the fit on these before you stick them on. I found some were too long to go in the space and had to trim the bottom off:
The finished quarterbadge:
Edited by vulcanbomber
Replace missing photos.
First Completed Build: San Francisco (Original Version)
Current build: Victory Models HMS Pegasus
Cross Stitch Project (Finished): Battle Of Agamemnon and Ca Ira
Cross Stitch Project : Victory & Temeraire
Link to comment
Share on other sites
glad to see progress on your build Caroline  :)   very nice work!     I hope this is a prelude to more in the future  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Nice clean work on the windows!   ;)
Cheers,
Tim
Tim
Future Build:
  • BlueJacket - USS Kidd (Fletcher Class Destroyer) Solid Hull
  • BlueJacket - U.S.S. SAMUEL B. ROBERTS, DE413 | Butler-Class Destroyer Escort
  • BlueJacket - 310' Destroyer "The famous "four-piper" of both World Wars"
  • Model Shipways - Pride of Baltimore II (Topsail Schooner)
  • Model Shipways - Willie L. Bennett (Chesapeake Bay Skipjack)
  • Constructo - Pilar (Ernest Hemingway's Fishing Yacht)
  • Sergal - Race Horse (Bomb Ketch)
  • Classic Warships - USS Salem CA-139 (Heavy Cruiser) Resin Kit
  • Pen Duick Schooner - Half Hull (Scratch Build)
  • CSA Submarine Hunley (Resin Kit)
  • Classic Warships - USS Washington BB-56 (Battleship) Resin Kit
  • Blue Ridge Models - USS Alaska CB-1 (Resin Kit)
Completed Builds:
Member:
Hampton Roads Ship Model Society
Link to comment
Nice work on the badges. They really came together! Tell me why is that the women always show up the men? ;) Keep up the good work!
Current Builds - 18th Century Longboat, MS Syren
Completed Builds - MS Bluenose, Panart BatteStation Cross section, Endevour J Boat Half Hull, Windego Half Hull, R/C T37 Breezing Along, R/C Victoria 32, SolCat 18
On the shelf - Panart San Felipe, Euromodel Ajax, C.Mamoli America,
Its a sailor's Life for me! :10_1_10:
Link to comment
Wow!  You are making progress and beautifully so.   Keep up the great work.
Link to comment
Thanks all, your comments are really appreciated.
Here is the quarter badge just balanced in place at the stern. It's not glued on yet:
I worked on the bow of the ship next. I liked what Blue Ensign created under the forcastle with his Pegasus so much I decided to adapt the idea to mine, especially as I am planning to add barrels. buckets and sacks to the area too, I thought it best to get it looking a bit more like it should.
Next I added the ropes to the gunport lids as I'd forgotten to do them earlier:
Replace missing images.
Link to comment
Next I worked on the first of the guns located under the forcastle. I wanted to have them in the stowed position so after some research I made a start.
I used two pictures as guides:
standard.jpg.2d46efb208b9ce85610002dda04c0bfe.jpgcannon1.jpg.0bfd54e1f245e3f2f0119e7de938ecfd.jpg
First I made the Breech rope, knotting and siezing one end to a ring then it was threaded through a ring on the carriage body and looped around the cascabel knob. Here a long loop was created by placing a bit of siezing above the cascabel. It was then threaded through the ring on the other side of the carriage and knotted and siezed onto the final ring.
Pegasus237B.jpg.aefc34c24fe33b65fe02b35cddb42bde.jpgPegasus237A.jpg.d2a5df17d8f3808b3f133df4db012d05.jpg
Then I made the side tackles in the usual way, but instead of the free end coiled on the deck, it was wound around the tackles themselves:
pegasus241.jpg.a2a2c9effa87a0e05386fa6dfe526e1b.jpg pegasus242.jpg.6db5ca4494a77854883999c3727e5ddf.jpg
Next I added the other 'strapping' type ropes to the barrel:
Link to comment
As I said before, nice work!  I'm looking forward to seeing more.   ;)
Tim
Future Build:
Completed Builds:
Member:
Link to comment
Thanks! I really enjoyed making the cannon rigging, even though it was really fiddly. :D
Link to comment
I have a question.  I was looking at your paint job and I really like the colors you selected, but I couldn't tell if you had used a wood sealer before you applied the paint?
Tim
Tim
Future Build:
Completed Builds:
Member:
Link to comment
Daniel {Dafi} did the same thing with his Heller Victory cannons.......have you seen them?   good to see your working on your build again,  a very nice beginning,  indeed!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Tim, No I haven't used a wood sealer, just used the recommended blue enamel colour given in the instructions. The unpainted wood will have a clear satin varnish added at a later date.
Thanks for looking in Popeye, I haven't seen Dafi's Victory build, I'll go and have a look, thanks!
Thanks David, I really enjoy making the little extra's; it's what really makes a build truly your own.
Link to comment
Thanks ZyXuz
Thanks for your tip Arthur.
I have attached the two bow cannons in place and added some sacks and barrels to the bow area.
The bulkhead wall is in place and I've 'opened' one of the doors.
I've checked the lighting and it still all works fine. I'll now glue the fordeck into place and get the bow completed.
Link to comment
Hi Caroline nice to see your Pegasus is moving forward nice rigging on the stowed guns are you showing the others stowed or run out.
Ray
Ray
 Current build A set of HMS Diana`s boats @ 1/48
 HMS Royal Marine a Military class Trawler
 Completed  HMS Diana
Completed build The Lady Nelson
Completed Build HMS Pegasus
Link to comment
Hi Ray, I think at the moment I'm leaning to mainly stowed, certainly the waist ones will be stowed sideways against the gunport. I like to be a bit different.:)
Link to comment
The foredeck and bulkhead wall is in place now.
Next I made a mistake.
Reading the instructions I put the capping rails on next........... DON'T!!!!!
A small section of the bulwark has to be cut out for the catheads, this needs to be done BEFORE the capping rail is attached.
A note on the catheads (Thanks Blue Ensign!) the sloped bit sits on the deck, BUT it needs to be altered so that is fits nicely on the deck AND goes under the rail confortably. ;)
Link to comment
is there anyway the bulwark can be cut out and the cathead slid into place?
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
you could gently drill a hole and then use needle files to square them off
Current builds : HMS Bounty, Constructo Pilar
Next build : undecided
On the Shelf : AL San Juan, Mamoli HMS Victory
Builds on hold : Ochre Gorch Fock, Hachette/Amati Black Pearl
Previous Builds Gallery : Virginia; King of Mississippi
Previous Builds logs : AL King of Mississippi 1/80
Link to comment
Hi Popeye, Adrieke, You could, but it would be difficult. I was lucky and was able to remove the capping rails without any damage. :) I just wanted to warn any future builders.
The next bit I did was fitting the headrail and cathead on the starboard side. Well I invented some quite unique expletives while tackling this bit, not very ladylike at all, surprised my husband no end!!! :o
First I glued the upper prow rail (part 127) and lower prow cheek (126)  and the head timbers (25, 26 and 27) in place, no problems there:
Next I bevelled the edges of the two bow cheeks (54) they needed quite a bit of shaping to get them to sit flush against the prow and the wale.
Next I put the top rail temporarily in position so I couls see where I needed to cut the bulwark to accomodate the cat head. I was so glad I'd been able to remove the capping rail here otherwise it would have been really awkward.
As mentioned earlier I had to alter the slope on the cathead where it sits on the deck to get it to fit comfortably under the capping rail as angles upward slightly.
After that was accomplished I glued the upper rail in place.
Then it came to the inventive language section with fitting the lower bow rail (125). The thing is so fragile I lost count of how many times it broke and I stuck it back together again, it ended up in such a mess I decided there was nothing for it but to cut some new ones using the other intact one as a template. Eventually I managed to manipulate one into position.
The main problem is that it is too delicate to get it to sit flat in the slots of the head timbers and then twist slightly up to the prow. But I wasn't going to let it beat me, so I beat it into submission!
Once that was finally in place I could fix the cathead and it's support and then the extended rail a section of decorative brass stripwhich runs from lower bow rail to the cathead support.
The last bit to do was to cap the outer edges of the head timbers. I had to file some of the lower bow rail to get the caps to lie flat against the head timbers.
Link to comment
Hi Caroline,
Good fix on the head rails, you would never know there was a problem in the first place, well done. :)  :)
I am looking forward to seeing more progress, but no rush. ;)
mobbsie
mobbsie
All mistakes are deliberate ( me )
Current Build:- HMS Schooner Pickle
Completed Builds :-   Panart 1/16 Armed Launch / Pinnace ( Completed ),  Granado Cross Section 1/48
Harwich Bawley, Restoration,  Thames Barge Edme, Repair / Restoration,  Will Everard 1/67 Billings
HMS Agamemnon 1781 - 1/64 Caldercraft KitHM Brig Badger,  HM Bomb Vessel Granado,
Thames Steam Launch Louise,  Thames Barge Edme,  Viking Dragon Boat
Next Build :-
Link to comment
sometimes........yas jest has ta git tough!   it's inventive and it works.........looks nice!  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Thanks for looking in Mobbsie, Marktime and Popeye, part of the fun is solving problems and the sense of acheivement when they have been solved. :D
I have done a little more work on the bow, the starboard side headworks are completed and I've almost finished them on the port side. The unpainted bit at the stem is the filler bit behind the pegasus figurehead.
Finished headworks:
Added the ochre coloured rubbing rail (?) in this area:
Port side as she stands:
Bow on view:
Link to comment
I ordered a plinth for Pegasus to be displayed on, it is ash with a danish oil finish. I'm really pleased with it.
I've also taken a few pics of the bow with the light on under the foc'sle:
Link to comment
bow is looking very nice :) and in the dark with lights on looks really cool :)
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
