HMS Pegasus by vulcanbomber - Amati/Victory Models - 1/64
Thanks for the likes and comments.
Finally my set of very fine brushes arrived and I got down to painting the gold scroll work on the frieze. I took me several attempts to get it looking good. Then I made the rudder and attached it.
pegasus439.thumb.jpg.d4d9ab167099850cd8c93d8586e2981f.jpgpegasus440.thumb.jpg.56bd8309bf9e921620a626352834decb.jpg
Next were the oars,Tricky little things, but I'm pleased with the way they came out. The blade was made from some 1.5mm boxwood, the shaft was a wooden cocktail stick and the grip made from some small strips of boxwood glued to the cocktail stick and reduced to create the squared section.
pegasus441.jpg.b27f40d20786b9b0778864956853ce87.jpgpegasus442.jpg.d932d8ffc2ef5fe0a0c589be6a58a2b8.jpgpegasus443.jpg.be3d18f0a5b428e64fd9034575c2ff64.jpgpegasus444.jpg.f321898022c9df2a00b7738baa9e801d.jpg
The finished oars
pegasus445.jpg.b200cc47e1ef77d759eb142947cef9b5.jpgpegasus446.thumb.jpg.dd51e76b58294a0a09a761dc394340cb.jpg
First Completed Build: San Francisco (Original Version)
Current build: Victory Models HMS Pegasus
Cross Stitch Project (Finished): Battle Of Agamemnon and Ca Ira
Cross Stitch Project : Victory & Temeraire
Link to comment
Share on other sites
My Pinnace is finished!
pegasus447.thumb.jpg.180d2fcdce26b8b4b86d33e84f1e29ed.jpgpegasus448.thumb.jpg.98f3f99e313b9e1b4025cc78e6865900.jpgpegasus450.thumb.jpg.6973a68a3020f923e11ffff03cfa50d4.jpgpegasus449.thumb.jpg.9ef9bc3244d8a55c68b246ec3f07e576.jpgpegasus451.thumb.jpg.19b2fa49ba793639ca7f4c880095fc4f.jpgpegasus453.thumb.jpg.0eb88df7ef5db8ca802d3532646b1abe.jpgpegasus454.thumb.jpg.2aa06a76828953549b2241c14c1dc8d7.jpgpegasus452.thumb.jpg.8ec7fe32792e5220bda172449df4d7a5.jpgpegasus455.thumb.jpg.fc94d95502d6d7ce16e87ef023f42d23.jpg
Edited by vulcanbomber
Link to comment
Here she is in her place on board Pegasus.
pegasus456.thumb.jpg.f34c96fd064a36cd8e9ef439b2e712c6.jpgpegasus457.thumb.jpg.2937f20e61e41a33c6a62586ba9b02f7.jpgpegasus458.thumb.jpg.451f2d36723ac98e650e0a8e276a796a.jpg
pegasus459.thumb.jpg.64cd711f90ba0183b2a2ccc3dd5acec1.jpgpegasus460.thumb.jpg.8e8e73c8ef764eac78e1fc4a4b7a5c78.jpgpegasus461.thumb.jpg.611281b7c96af24ab82ef9e0e52ee2b5.jpg
Next to do is the long boat. I will probably start that at the weekend and will be made in the same way as the pinnace.
Link to comment
I have been working on my little longboat for Pegasus.
I have made the hull using the plug method again.
The false keel and frames were cut from 1.5mm Basswood, frames are glued to keel and let dry.
pegasus462.jpg.5adf48dfde57d8fc0a6ba0b6463f1489.jpgimageproxy.php?img=&key=4f3b55ae31fcd018pegasus463.thumb.jpg.f53329e8b0b24038a3634e4649ec4c5c.jpgpegasus464.thumb.jpg.a26ad9927c0a72c0a79c42c0e4b8bfa4.jpg
The balsa fillers glued in and roughly shaped.
pegasus465.thumb.jpg.6314f4512b69bcbe2cf1e5ac3f85b4ef.jpgpegasus466.thumb.jpg.50926e337f5d01c410af3566adeb5fa2.jpg
After sanding.
pegasus467.thumb.jpg.d5a27c46a308eec209268278e6065104.jpgpegasus468.thumb.jpg.bfad461a0f0c29882506fe5cf53979fe.jpgpegasus469.thumb.jpg.ccfe3a833ee93c476edd62737cacd89c.jpg
Large balsa bock glued to top of plug for sticking the frames to, and the frames cut, soaked and bent round the plug. Held to thoroughly dry by rubber bands.
Frames now glued in place and ready for the planking.
pegasus471.thumb.jpg.5be9150e891ca1bad46392e4ebcad339.jpgpegasus472.thumb.jpg.256bd2c476578776134c640862e46c64.jpgpegasus473.jpg
Link to comment
The new keel was cut from 1.5mm basswood and glued in place. I even managed to make a rabbet!
pegasus474.thumb.jpg.641df04bf48145202a40d682d3152b88.jpgpegasus475.thumb.jpg.45903d57603f197c6633cb96764ba4aa.jpg
Planking is 0.5mm maple strips 3mm wide.
pegasus476.thumb.jpg.e2041419c02d92e576582b96c45720cd.jpgpegasus477.thumb.jpg.ee9083a35ff73fde8d8666a7369d3f85.jpgpegasus478.thumb.jpg.afa05504ee42b0b0c5a001d64be83193.jpg
Now ready to cut from the plug.
Link to comment
Now off the plug and in need of a tidy up inside.
pegasus480.thumb.jpg.d50f13771368bb46dc45832b83abed86.jpgpegasus481.thumb.jpg.baa44e4af73341a252f8633d1fc5d0d1.jpgpegasus483.thumb.jpg.0ef9fb6bc2bd94b7258d04d72f0ead96.jpg
After a tidy up with my trusty Dremel and the capping rail fitted (cut from 0.8mm basswood)
pegasus485.thumb.jpg.6779374caad0adff2cceb2ab09b02ee6.jpgpegasus486.thumb.jpg.2e7b0404607671f2ff1463be8069e25a.jpgpegasus487.thumb.jpg.d9013fbeccd3baa78922903686197ad2.jpg
So this is where I am at now. Next will be the floorboards.
Link to comment
I have a question regarding the stowage of the mast and rigging for the longboat when it is not in use / being readied for use.
I am toying with the idea of having the longboat shown being lowered from Pegasus's spars, as though it was being readied for launching, but I don't know how the mast and rigging would be stowed and how much would be in place before it is lowered to the water?
What rigging (if any) would be attached to the mast ready for stepping it when the boat hits the water?
How would the shrouds and ratlines be stored, would any of it be left attached to the longboat? Same with the stays?
Any thoughts and suggestions would be appreciated.
Thanks Guys.
Link to comment
7 minutes ago, Blue Pilot said:
I just read through your entire log, beautiful work.  Thanks for sharing it was fun to read.
Thanks for looking in, always welcome.
Link to comment
A little more progress over the Christmas period on the Longboat for Pegasus.
Floorboards installed and bow & stern platforms.
pegasus488.thumb.jpg.84daac60d6199b1830e5fd8c722b6825.jpgpegasus489.thumb.jpg.00465fd0ba784e6302d0c8158ab291dd.jpg
Frieze (hand painted paper) added to hull.
pegasus490.thumb.jpg.70d74708a7321467941753ff844cf64f.jpgpegasus491.thumb.jpg.7c70ea4e4f91e654baec764357055508.jpg
Thwarts, mast step and  stern locker wall.
Mast, gaff, boom and bowsprit made.
pegasus493.thumb.jpg.b6b355bd75529bd1a39889101487a89d.jpgpegasus494.thumb.jpg.e15ab1c8a8bc74dbbdd3f120b4d164f8.jpg
Now on the the windlass and other fittings.
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
