Endeavour I by Sam1957 - Midwest - 1934 Americas Cup Challenger - 1:63
The build log begins! Dedicated to my sailor girl! Funny but I thought I would be intimidated by the abundance of parts but fortunately I am not. Wish me luck boys, I need this done by January / Feb 2015 and awaaaay we go ...
Scale 1:63
Edited by Sam1957
Link to comment
Share on other sites
The kit makes into a great model.  My main complaint is that they very soft wood for almost everything but this can be swapped out easy enough and the instructions are easy to understand.  Have fun and enjoy.
David B
Link to comment
I see what you mean Dave, very soft. Have to use a light touch! Have you are anyone else here tried a softwood hardener? Minwax makes one that is designed to re-enforce soft wood fibers. I am going to try a test on some scrap.
Link to comment
The secret to working with balsa is not to use it if you do not have to.  Otherwise use a sharp knife at all times.  The minute it dulls out either sharpen or replace it.  Use a wood hardener or a solution of white glue and water.  This will raise the grain but if you are cutting or shaping you do not have to worry.  I have found aspen works good as a substitute if you cannot get basswood.
David B
Link to comment
So far so good! Not bad for a few hours before turning in...
Trying to figure the best way to secure the sub-deck to the bulkheads due to the slight curvature. I guessing CA is the right glue in this case.
Sam
"It's never too late to have a happy childhood!"
Link to comment
Soak the deck for a little while then clamp and tape it down over night.  After that check the fit.  The less stress the better.  I am partial to wood glue and 5 min epoxy myself.
David B
Link to comment
Great another J class Yacht.
Michael
Link to comment
  • 2 years later...
Hi Sam! Did you ever finished this model?
Bought one from Ebay, unfortunately it is very incomplete , missing almost all wood parts and Sheet 2 of plans
Any chance you could help me with sheet 2 of plans?
I can buy more wood and see if I am able to cut my own parts
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
