Byrnes Saw Auction - See in Naut General Discussion ×
Dubz
HMC Sherbourne by Dubz - FINISHED - (Scratch my Sherbourne)
Thanks for all the likes, very much appreciated. Glad you like what I do 🙂
Time for deconstruction ... this double block sits not very well under the triple block ....
And somehow the block itself thought the same .. broke ...
I changed to two singleblocks though as in the Alert book.
Triple Block was redone too then...
Started choosing the final belaying points, Peterssens book is one reference for that besides the builds of Tony & Gregor..
cheers,
Dirk
Share this post
Link to post
Share on other sites
Actually, your work makes me kind of depressed when I compare it to my own version of this model. ☹️
Only kidding! Well, maybe just a little bit serious. But actually I really appreciate what you are accomplishing with this build because it shows what can be done even with an "old" design like Sherbourne, i.e. relatively outdated in design concept when compared to the latest kits coming out (we all know which ones). A little extra research and effort and **poof** -- a stunning model results.
Share this post
Link to post
Congratulations. This is one of the best build logs I have ever seen. Everything is excellent.  I am learning a lot of things. Thank you for sharing.
Edited by mtbediz
Share this post
Link to post
Thanks for your kind comments and the likes. Good to read you like what I do 🙂 Very much appreciated 🙂
At the moment I am puzzling over the Truss pendants. Which yards were equipped with them for a cutter with this "older" rig?
Pretty sure the Cross Jack Yard was but what about the Spread and Topsail Yard? I would guess that at least the Spread Yard should have Truss pendants... any insight would be helpful and very much appreciated.
Cross Jack Yard with Truss pendants.
cheers,
Dirk
Share this post
Link to post
Hi Dirk,
On AVOS it is used only on topsail yard. The spread yard has a ring and through the ring it moves along the jackstay (which is rope coming from mast head to the deck prallel to the mast). But I am not by any means historian or expert!
PetaV
Share this post
Link to post
Yeah that's the "modern" solution like the french did it (La Cerf). On contemporary models like Hawke or Alert I can't see ANY Rack ... And Racks on Spread and Cross Jack Yard will collide with the main sail (that's avoiding the AVOS solution though) ... no wonder they change this cutter rig completely ... what a mess.
Dirk
Share this post
Link to post
I am still unsure about the truss (and the footropes) but for the moment I decided to have a truss for the cross jack yard (maybe topsail too) and footropes for the cross jack and the topsail yard (here without stirrups).
I just like to show these elements (and it was good practice for Syren too ;-)), even we don't know if this is historical correct. I'm the Captain 😛
And the block for the traveller inhauler.
cheers,
Dirk
Share this post
Link to post
Dirk, I may be wrong, but the passing of the outhauler through the bulwark hole seems to be wrong: you cannot
just bend the rope by 90 degrees and ground it on plain wood, the rope will wear-off, or the hole will be deformed within little time.
On Avos it is solved by using the roller, on Alert ... well, the monography by Goodwin outmanuvers that matter, but it looks like they just fasten the rope on the bitt on the bulwark rail.
Share this post
Link to post
Hej Dimitry, in principle I agree but it is also shown on some contemporary models. I will reconsider when I have to do final decisions ... 🙂 Now I have to count blocks, hope I have enough ... 😛
Dirk
Share this post
Link to post
If the word "contemporary" describes the models, made in our age, then you probably know, that they have numerous historical mistakes.
From both reasons: 1) people who built them do not care about historical accuracy or just had not dug deep enough 2) the more we live, the more information comes through research - so the info may be not available by the time they have built their models. I have met it several times on ships from Russian fleet - models built in 60-80s made by great modelists are great, but some recent archive discoveries tell us, that they are historically incorrect in several places.
P.S. I can send you more of our blocks, if you have not enough :)
Share this post
Link to post
Dimitry you are  right, lame excuses by myself .. hehe .. I will simulate a sheave there and/or dig deeper to find an appropriate solution 🙂
Pleeeease ... yes 🙂 Love these blocks!
Share this post
Link to post
Thanks for your continous support, comments & likes 🙂
Finally I had to make a truss for every yard as otherwise I would have problems with my rig. I never glue my mast parts so I always can deconstruct things easy 🙂
I made the sheave here for the inhauler.
And add most of the running rig like brasses and bowlines.
I made a bolster for the lines here:
Gettin very crowded 🙂
And started the rig for the rudder.
cheers,
Dirk
Share this post
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
    No registered users viewing this page.
Our Emblem
