Dubz
HMC Sherbourne by Dubz - (Pimp my Sherbourne)
Those masts turned out really nicely.  I think your scale of 1:64 is somehow different to everyone else's 🙂 , you manage to get such precision on all small details.
Share this post
Link to post
Share on other sites
Thanks Chuck, Tony, Chris, Jason and the likes 🙂
More progress on the mast. Small parts done with boxwood and pinned with 0.3mm brass rod. Nothing is glued yet except the crosstree to avoid any trouble with the rigging 🙂
cheers,
Dirk
Share this post
Link to post
Just in time to continue with your Sherbourne! Thought it would never happen:) What you do is amazing.
Share this post
Link to post
And more mast detailing. Today I made the cleats. I used @Chuck ones and again thankful for him providing us all these little helpful addons 🙂
The cleats needs to have the angle of the deck.
Second coat of Oil for the mast.
On deck
cheers,
Dirk
Share this post
Link to post
Thanks for the likes 🙂
Finished most of the the mast parts today.
First I wanted to paint the lower mastpart red but I am unsure now ...
Inbetween project.
cheers,
Dirk
Share this post
Link to post
I still love your close up work .. what a build !   re last photo   hmmm Cogs n' Bars n' Stuff .. interesting... part of a rope making kit I wonder,  or something else ..... We wait to find out ☺️
All The Very Best Mate
Eamonn
Share this post
Link to post
I'm still struggling HOW to do my Sherbourne Rig. I know I like to do the "older" one but it is very hard to finde good sources in detail. At the moment my only "inspiration" is Marquardts Rig.
On 12/31/2014 at 1:33 PM, Gregor said:
Mainmast to pole head 22 yards 10 inches (diameter 15 3/4 inches)
Topgallant mast 7 3’’ (6 ½’’)
Boom 14 19’’ (10 5/8’’)
Spread yard 11 9’’ (7 1/8’’)
Gallant yard 9 0’’ (4 5/8’’)
Gaff 10’0’’ (7 3/4‘’)
Topsail gaff 2 24’’ (4 5/8’’)
Crossjack yard 12 0’’ (6 ¼’’)
Bowsprit 15 24’’ (14 7/8’’)
Flying jib boom 9 15’’ (6 1/8’’)
I tried to convert these dimensions to 1:64 and they feel wrong, crossjack yard just 10,97 meters (171 mm). May anybody do the same so we can compare results? Possible that yards and inch were different to mm at this time?
I also wondering that there are just three yards mentioned, It seems the Top gallant Yard is missing or is possible the "Topgallant Mast" the yard?
Interesting is the Topsail Gaff. Very rare seen on models and paintings. I like that. The following painting shows the topsail gaff but again another different rig.
Right now I'm testing the following dimensions adapted from the image above and the Alert book.Sherbourne_Yards_2.png
Any input is appreciated 🙂
cheers
Dirk
PS: I am also working on this
And this 😄
Share this post
Link to post
Right now searching collections.rmg.co.uk. Will take a while with just "cutter" as search word .. hehe .. but already found a good one. Topmast aft, only three yards and 1783. I will edit this post with more finds.
Very interesting is that there are two cutters with topmast aft but different rigs.
Source: https://collections.rmg.co.uk
Another one with 3 yards and old rig (sail)
Share this post
Link to post
The dimensions in original from the Sherbourne plan. It would be great to convert these to metrics and 1:64 as I don't understand/trust mine.
EDIT: Guess I found one mistake 😉
cheers
Dirk
Share this post
Link to post
Ok I should have checked Gregors dimensions as he missed a line and then mixed the values too. AND there are FOUR yards and it seems to fit dimensions wise 😉
EDIT: Corrected Values as of 21.08.2019
Share this post
Link to post
One more question: "Mainmast to pole head" ist this the WHOLE length of the mast? "Pole head" confuses me. Or ist "Topgallant Mast" ADDED to this? So that the mast in whole is in mm 428,25?? (27,28 meters)
cheers
Dirk
Share this post
Link to post
According to the measurements on the original plan these are the yards, boom and gaff. Topsail gaff is missing yet (38 mm). But she had 4 yards as the Alert.
The relation of gaff and boom is exactly the sames as on the Alert, yards are different though.
Still not sure about the exact mast, topmast and fullmast dimensions.
cheers
Dirk
EDIT: Length corrected as of 21.08.2019
Sherbourne_Boom_and_Gaff_01.pdfSherbourne_Yards_Final_01.pdf
Share this post
Link to post
And further on. I have questions, I need answers 🙂
According to the Original Plan the following values needs clarification: "Mainmast to pole head" 22 18", "Topgallantmast" 7 28", and the sentence below "The mast head to be 13" 6’ (??) long which length includes in the pole head".
  • WHAT exactly is the masthead, green or red part?
  • WHAT does "The mast head to be 13" 6 long which length includes in the pole head". mean?
  • How much is 13" 6 in cm? EDIT: Is 120,4 cm, what makes no sense for a head ???
  • WHAT exactly is the Topgallantmast dimension (7 28")? INC. or EXCL. the pole head? (I guess EXCL.)
  • How long then is the common pole head?
  • WHAT does "Mainmast to pole head" mean? The whole mast up to the EXCLUDED pole head? But then it is the Topgallantmast included as the mainmast don't have a pole head (?)
  • Is the length of the mast the WHOLE mast or the mast above deck?
I really want to find out the exact dimensions for the Sherbourne's mast 🙂
Dirk
Share this post
Link to post
How to calculate the length of the "common Pole Head" (Source: Schrage):
Hypothesis: The given length of 7,11 meters for the topgallant mast is excluded the pole head as there are three different types of pole heads which can and will be calculated.
(Length of topgallant x 0,388)
So full length of this spar should be:
(Length of topgallant x 0,388) + Length of topgallant
(7,11 meter x 0,388) + 7,11 = 9,87 meters
That seems a reasonable length for a cutters topmast(?). What do you think?
Dirk
Share this post
Link to post
According to this calculation I made another, higher, Topgallant mast with a common pole head.
Comparison old and new Topgallant mast.
cheers,
Dirk
Share this post
Link to post
Some progress. More spars.
And next to go.
I still have these questions open please 🙂
  • WHAT does measuring wise "Mainmast to pole head" mean? The whole mast up to the EXCLUDED pole head? But then it is the Topgallantmast included as the mainmast don't have a pole head (?)
  • What does the following mean: " The mast head to be 13’ 6’’ long which length includes in the pole head." and what exactly does this measure refer to (assumed 4.12 meters)?
cheers,
Dirk
Share this post
Link to post
If you’re running off shipyard drawings, the mast length is the whole mast, from the step on up.
 The polehead measurement is everything above the mast top.
 I may or may not have used the mast length measurement as above the deck on my Prince de Neufchatel, and had to compensate for the difference while making sails.
Edited by GrandpaPhil
Share this post
Link to post
Thanks Dirk
Share this post
Link to post
I apologize for the quality of the doodling, I used the markup tool on my phone.
 The mast length to the top is to the right. The mast top is to the left.
Share this post
Link to post
More progress on the yards.
I finished the spread yard. This one will stay natural.
The others got their black paint today so that I can finish them. I airbrushed the parts and used Vallejo Black Primer. Easy to spray great looking result imo.
The mast got paint too (I will go with this dimensions now) 🙂
cheers,
Dirk
Share this post
Link to post
Beautiful Stuff As Usual Dirk..  Wonderful to see her progressing again !
All The Best
Eamonn
Share this post
Link to post
More progress 🙂
How to:
The spars.
I love the effect of oiling 🙂 Not sure yet if I will paint that black or not.
cheers,
Dirk
Share this post
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
    No registered users viewing this page.
Our Emblem
