HMS Bounty Launch by kscadman - Model Shipways - 1:16
Gahm, I'm starting to lean toward using this technique on my Syren long boat. I've been sanding on the lifts for what seems forever and it doesn't seem like I've made much progress.
Richard
Current Build - U.S. Syren
2nd Build - HMS Bounty Launch
When organizing your thoughts, never use the Dewey Decimal system.
Link to comment
Share on other sites
I'm halfway thru the planking and it hasn't been without its trials and tribulations. I was using the head post template but for some reason (me, of course) I didn't get the garboard and the plank next to it in the proper place. But I corrected this with the third plank. I tried to remove the garboard and second plank but I've been using carpenters glue since its stainable.
Unfortunately its also WATERPROOF so I couldn't remove the planks and re-position them. (Hello wood filler)
The good part is that my planks are aligning with the marks on the molds.
Richard
Link to comment
Did you try isopropyl alcohol? It should loosen the wood glue. But, wood filler works too. Nice progress so far.
Link to comment
Tom, thank you for the tip. I used the isopropyl alcohol and I was able to remove all the planks. One plank did split toward the bow. Now its time for clean up and repair.
Richard
Link to comment
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
