18' Cutter by Maurys - Scale 1:48 SMALL
As a diversion, I've started an 18' cutter with a plug and instructions from Admiralty Models.  I don't think they offer the plug any more, but the instructions can be found via a Google search.  The various parts of the keel assembly are each a different thickness, so I used my Byrnes thickness sander to get the right dimensions.
The keel is 3 1/2" sided, the stem 3" the stem apron 4 1/2", sternpost 3" and the sternson knee and transom are 1 1/2".
I chose to make the apron separate from the stem and getting it to match the after side of the stem takes some care.  I thought it easier than cutting it in one piece as David Antscherl did in his practum.  Lining the pieces up for gluing was a matter of sanding several shims to get the pieces centered on the keel with a proper fit.  No rush job here.  Prepping the plug is easy, with  adjustments where the apron fits...just a series of sanding the inner slot equally on both sides (count the strokes) until the apron fit snugly.  Once that was done, I used the keel assembly in the plug to align and glue on the transom.
Maury
Edited by Maurys
Link to comment
Share on other sites
Have fun with the cutter.  As I recall, there was a problem with the top of the sheer.  What are you going to use for the planking?  We used holly at the seminar; it bends beautifully and is a nice contrast to the costello of the frame.
Link to comment
Excellent start Maury. It looks like you have one of the newer plugs with the cast separator so the problem Toni described should not be an issue. I also made my apron separate from the stem and found it much easier this way. I look forward to your build.
Link to comment
Hang on to your seats. Toni, the ribs and planking are to be of holly. Probably finish the interior details with box.  The garboard plank is always a challenge.  I'm starting with a card template, but I'm not able to make fine adjustments to the card stock.  Card's cheap.  I'l just do another one.
Thanks for tuning in.  Feel free to add suggestions as we move along.  This is my first attempt at clinker built planking!
Maury
Link to comment
Three patterns for the first garboard (in card), followed by a plank in holly that was too short by 1/16".  Once more...   I wedged a couple of pieces of 1/64 scrap between the plug and into the rabbet to hold the keel assembly in place on the opposite side I'm working on.  I steamed the plank (wrapped in a wet paper towel and microwaved for 30 seconds) then put it in place and clamped it for drying.  After the piece is dry, I'll sand a little on the upper edge to get it to the plank line on the plug.  By the way, one side of the plug has the planks laid out with a very fine score.  That's a big help and I don't know why the score was not put on the other side.
Maury
Link to comment
That's a great idea about wedging the keel in place from the opposite side Maury.  I've been doing my own scratch version of this at a 1:90 scale with my own plug and have been having issues with keeping the keel in place. Your solution is so simply elegant and obvious, that I completely overlooked it.  Thanks! :)
Edited by gjdale
Link to comment
The garboard is an issue.  First one was too short (by 1/64th") and would show badly.  Lining up the plank into the stem rabbet after bending was another problem.  Now I know why I should be making it in pieces.  I've decided on two planks per strake all the way up to the sheer strake.  I think making a butt joint will be easier than making each strke in one piece.  Thanks for everyone's comments.
Maury
Link to comment
Now on to the first strake above the garboard (mounted upside-down).  This is where the edge of the garboard gets sanded a bit and the fore end of the plank gets a rolling bevel to 45 degrees.  Not as hard as I thought, but I think I'll do the rolling bevel on the next side before I glue it in place.  I don't have a full compliment of clamps so scrap planks and rubber bands will do.
Maury
Link to comment
Dave,  There is about 1/32" over-size to account for the overr-lap if the garboard plank.  Whem I fit it on, I had to sand off about 1/64" to line it up to the scores on the plug.  As for the exposition, I'm just following the instructions David and Greg put out.  Masters, both.  It's a good thing that isopropyl disolves titebond glue!
Maury
Link to comment
Pic. of the ends of the first planks above the garboard.  You can barely see the scores on the plug that guide me to the run of the planks.  Both planks are the same width at the ends so there is some camera-angle distortion. My over-lap is much smaller than 1/32".  I wonder if that will present a problem when I take it off the plug (not enough gluing surface?)  Any thoughts?
Maury
Link to comment
Bob, Good eye.  David pointed out in the instructions that almost all of the ribs were left on the plug when he lifted the shell off the plug.  He therefore recommends that the planks be laid without ribs and then go back and form up the ribs separately and install them inside the finished shell.
Maury
Link to comment
Lokkks like an intersting build.  I think I will pull up a chair as well.  Boats like this can be both fun and challenging.  Everything has to fit just right or else it does not look good.  Are you going to stay natural or will you paint?
David B
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
