HM Cutter Cheerful 1806 by Chuck - FINISHED - 1:48 scale - kit prototype
That tuck frame is a really cool detail.  The red counter is a great example of how colorful ships could be in period.
Link to comment
Share on other sites
Wonderful. That looks really perfect.
Regards Christian
Link to comment
The cross section of your hull planking shows how incredibly good your planking skills are. The joints are perfectly tight though out the thickness of the planks, not an easy task.  I forgive you for hiding this nice detail with a perfect stern section ;)
Remco
Treat each part as if it is a model on its own, you will finish more models in a day than others do in a lifetime.
Current build HMS Kingfisher
MSW 1.0 log click here
Link to comment
I love it.  Very nicely done.  Looking forward to the final plans.
Maury
Link to comment
For everyone following this project,especially those of us contemplating embarking upon it somewhere down the road, I offer a bit of inspiration. There is a wonderful painting by Montague Dawson entitled ~ The Fleet Messenger ~ which depicts one such as this under a full press of sail in advance of a squadron of ships of the line.Just type in the names and several images,and sources,will come up.
Link to comment
I could not have said it any better.
Beautiful work Chuck
Link to comment
That square tuck is a wonderful detail and precisely executed by you - as we'd expect. I quite like what I see as a slight translucency in the red paint - you can perceive the planking underneath. I'd keep it that way myself and perhaps you intend to?
Cheers
Alistair
Current Build - HMS Fly by aliluke - Victory Models - 1/64
https://modelshipworld.com/topic/34180-hms-fly-by-aliluke-victory-models-164/
Link to comment
Thank you Alistair
Red is a very transparent color to paint with.   If you use thin coats it will be somewhat transparent.  I have many more coats and more sanding to get it where I want but it will most likely have some transparency.
I found some workshop time....so I finished planking the starboard side.  Its a big milestone but then I look at the port side and have to repeat the entire process, including the square tuck   But it all worked out very well.   Once the other side is finished I can start treenailing.   :P
Link to comment
Ah that's so nice!!!!  Well done. B)
Rusty
"So Long For Now" B)
Current Builds: HMS Winchelsea 1/48  Duchess of Kingston
Completed Build Logs: USF Confederacy , US Brig Syren , Triton Cross Section , Bomb Vessel Cross SectionCutter CheerfulQueen Anne Barge, Medway Longboat
Link to comment
That's some beautiful planking work Chuck. I hope the planking on my "Connie" turns out as well. But then again, if it does, I won't want to paint her as she should be.  :o
Cheers and I hope you and yours have a Happy Holiday
GEORGE
Link to comment
To reduce the transparency of certain reds, the first coat of paint should have a little white mixed in. This will create a dark pink but, panic not! The subsequent coat or two of red alone will give sufficient coverage.
Link to comment
Wow, that's a really beautyful planking. Do you like to copper her?
Regards Christian
Link to comment
Thanks Guys
Christian...I wont be plating the hull.   She probably was copper plated but few contemporary models including the Surly ...They were not plated.   The Surly model was painted with white stuff.   I couldnt find anything definitive about it so I am going to leave the hull as is.
Chuck
Link to comment
fantastic planking Chuck !
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Hi Chuck,
Just catching up with your latest project, Cheerful is coming along beautifully Sir, perfect planking work! B)
Thanks for sharing your various construction techniques, your log will serve as an excellent tutorial for future builders of this wonderful cutter.
Best regards,
Aldo
Currently Building:
HMS Pegasus (Victory Models)-Mothballed to give priority to Triton
HMS Triton (first attempt at scratchbuilding)
Past build:
HM Brig Badger (Caldercraft), HM Brig Cruizer, HM Schooner Ballahoo
Link to comment
Hello Chuck
About red transparency; this is a solution that have given me excellent results.
The wood stain industry pursue transparency, no brush strokes, homogeneous color and a smooth sheen finish.  All the attributes we need for red in the gunport etc.
I mixed water base polyurethane (Varathane, 266228 MATTE) matte finish with Crimson red acrylic (Winsor&Newton, Galeria) at 2/3::1/3 volume to volume.
I prepared the surface with water base pre stain wood conditioner (as if it was going to be stained).
The first cover with the mix was dark magenta/pink with a lot of transparency. The second cover turned deep red magenta no brush strokes. The third cover was perfect Crimson with nice transparency and clean finish. Each cover dried quickly within minutes.
Guillermo
Link to comment
I have been working on both models and wanted to show the finished square tuck and Cheerful.  I am just about done with the planking but will be doing a tech session next Tuesday night at my club meeting.  So until then I wont be getting more done.  I may however move ahead and start treenailing.   I have only five strakes left as you can see and its killing me that I cant just finish it up.  But a week will go by really quick.
Chuck
Link to comment
Chuck,
I very much admire your Cheerful, and Winchelsea builds, and I'd love to build a model of the same calibar!
Will Cheerful ever be available as a kit? Or will it be sold purely as a set of plans with a practicum? I am weighing up a complete scratch build similar to Cheerful, or buying a "semi-scratch" kit from someone like The Lumberyard.
Thanks,
Jon
Caldercraft HM Cutter Sherbourne Kit Bash - Scale 1:64 - http://modelshipworld.com/index.php/topic/10547-hm-cutter-sherbourne-by-jonnyamy-caldercraft-kit-bash-scale-164/#entry317289
!!!ON HOLD!!! Mantura/Sergal HMS President - Scale 1:60 - http://modelshipworld.com/index.php/topic/5589-hms-president-by-jonnyamy-circa-1760-sergal-160/
In the Pipeline:
18th Century Longboat - Scale 1;48 - - http://modelshipworld.com/index.php/topic/11273-18th-century-longboat-model-shipways-by-jonnyamy/
Completed Builds:
40 Foot Gaff Cutter - Solid Hull Concept Model
Caldercrafter HM Mortar Vessel Convulsion - Scale 1:64 - http://modelshipworld.com/index.php/topic/8593-hm-mortor-vessel-convulsion-by-jonnyamy/
SCRATCH BUILD - Vagabond 19 foot Sloop - Scale 1:20 - http://modelshipworld.com/index.php/topic/10172-vagabond-19-6-keel-sloop-pob-scale-120-by-jonnyamy-small/#entry302726
Link to comment
I will be offering the bulkheads pretty soon.  But thats it.   It will never be a complete kit .  Only a few items to help the scratch builder.
Link to comment
Count me in for a set of the bulkheads. HM Cutter Cheerful will be my no. 3 build, just as soon as I finish the Niagara.
Chuck, she is looking majestic!
Regards,
Larry
Current Build
US Brig Niagara
Completed Builds
George W Washburn - 1890 Tugboat
Future Builds
18th Century Longboat by MS
HM Cutter Cheerful
Wappen Von Hamburg by Corel
If your not making mistakes, your not challenging yourself – my life has been full of challenges :)
Link to comment
Spent the day treenailing...woo-hoo!!!   Managed to get half of the starboard side done.   I am using a #78 drill bit for the size.  They are subtle which I like.  In fact here is a close up as it may be hard to see in the full profile image.  But it ads the nice texture I like without looking to measle like.  Clicking on the two bottom pictures might give you just a hint of treenails although it may also be my photography skills.
Chuck
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
