Charles W Morgan Whaleboat by Salty Sea Dog - Artesania Latina - Scale 1:25 - POF - first wooden boat build - SMALL
10) Harpoons:
Augie and Matti - Thanks for answering my S.O.S. -sorry my plea for help was not more clearly written. I was in a panic and wrote that after dinner last night and had already spent 1-1/2 hours just to get the rope work shown in that picture. I went after it again after dinner and finished it late last night. It was a little over 6 hours to make the 6 wrapped connections. This isn't normal is it? I'm thinking that I won't live long enough to rig something like the Wasa! Most of the time though was to allow glue to set with 3 steps of gluing on the ends with loops and 2 steps in the middle wraps. I have a little clean up work and touch-up on the metal coloring still to do. I have to go to work in a bit and wanted to make this post to say thanks and explain better what I was trying to do.
Here's a piictorial sequence of the harpoon construction. The metal was filed and shaped quite a bit before attaching it to the wood with medium CA glue. The wood is finished with shellac.
Metal blackened with Perma Blue.
Here's yesterday's post after fumbling around for 1-1/2 hours with the rope.
Nearly done -just some minor touch-up left.
One last question: Is it ok to use Johnston's paste wax on threads or do I need to find some beeswax? I'm trying to 'convince' the rope to coil nicely in the line tubs.
-Buck
Current build: AL Morgan's Whaleboat (1st build)
Kits in the ships locker: I cannot confirm nor deny that there may be a few kits in there...
Link to comment
Share on other sites
Ok.... now I see what you had to do.  You did it well ...... nice job.  Those black bands are whipping and yours look good.  Never tried Johnsons on line but there's only one way to find out if it works :) .  My uneducated guess is that it will but you won't know the long term effects from the other chemicals in the formulation.  But you can get beeswax from Model Expo in a handy little plastic case or you can find it at many craft stores.  Beeswax is very pure chemically and will not damage rigging over time (ordinary parafin will).
Now......lines.  For the record, I HATE working with lines but here it's an occupational hazard.  I fight with them, curse them, try to make them do what I need.  It just takes patience and listening to the line.  If it wants to twist left and you want it to go right, turn it over...play with it.  You need to bend to it's wishes a little and the wax will help.  Rest assured that evrything I do with line follows the same path........
1)  The first try is no good whatsoever
2) The second is usualy acceptable but takes me 1 1/2 hours, no matter how simple
3)  By the time I get to the 6th time, it  takes 6.13 minutes (or less).
Patience and practice is all you can do.  You did the right thing by walking away for a bit, letting off some steam and then coming back with a fresh outlook.
All that said........    BEAUTIFUL JOB
Augie
Current Build: US Frigate Confederacy - MS 1:64
Previous Builds :
US Brig Syren (MS) - 2013 (see Completed Ship Gallery)
Greek Tug Ulises (OcCre) - 2009 (see Completed Ship Gallery)
Victory Cross Section (Corel) - 1988
Essex (MS) 1/8"- 1976
Cutty Sark (Revell 1:96) - 1956
Link to comment
So sorry it took me so long to finally read your log Buck. To say I am impressed is an understatement of gigantic magnitude!!!
I am so happy you live in Kansas....you just might receive a visitor for some tutoring on how to do this finish properly. :D
My hat off to you, you truly are an artist post-127-0-62980200-1367675788.gif
Robbyn
If you risk nothing, you risk everything!
Current builds
Syren (Model Shipways) version 2.0
AL San Francisco II
Mordaunt (Euro Model)
Completed Builds
18th Century Longboat designed by Chuck Passaro
In the closet
Battle Station
Al Charles Morgan (1980s version)
Link to comment
So Augie, are there certain swear words that work best or does it require a string of cuss words in specific order to complete a rigging task? Do different tasks require a different order? I have not seen anything in the help guides on what seems to be an essential skill requirement.
My wife is into the sewing arts and has some "Thread Heaven" which she says is recommended in her world more than beeswax. I'll give it a try and report back.
Hi Shaz! Thanks for dropping by my build and your kind words -they are appreciated!
-Buck
Link to comment
Buck,
I feel I'll just be repeating others from the forum ... Outstanding job!
"Thread Heaven" sounds a bit like turning you into a seamstress ;)
Carl
Link to comment
Ahoy Buck :D
I'll do the broken record thing
"Outstanding"
Your craftsmanship is amazing
WASA, WASA , WASA :D
Edited by JPett
 On with the Show.... B)
  J.Pett
“If you're going through hell, keep going” (Winston Churchill)
Current build:  MS Rattlesnake (MS2028)
http://modelshipworld.com/index.php?/topic/45-model-shipways-rattlesnake-ms2028-scale-164th/
Side Build: HMS Victory: Corel
http://modelshipworld.com/index.php?/topic/3709-hms-victory-by-jpett-corel-198/?p=104762
On the back burner:  1949 Chris Craft Racer: Dumas
http://modelshipworld.com/index.php?/topic/939-1949-chris-craft-racer-by-jpett-dumas-kit-no-1702/
Sometime, but not sure when: Frigate Berlin: Corel
http://www.corel-srl.it/pdf/berlin.pdf
Link to comment
Oh no.....your wife too?  Mine is a weaver and quilter.  Takes up 1/2 my shop with her looms.  Took a look at Thread Heaven and have no idea what's in it.  But, they did compare it to beeswax so I'm sure they know what they're doing.  Let us know how it works :)
Now as far as the chants involved, I'm afraid to post them on MSW as the post Police might put me 'on report'.  However, for some reason the tirade always begins with 'Oh _ _ _ _ !  You're on your own from there
Augie
Previous Builds :
Link to comment
Hi Carl! Thanks for stopping by. Your little Sea Witch is the coolest! I don't know about being a seamstress, but my wife is going to show me how to use a sewing machine so i can make the sail! :D
Hi JP!  I had the lid off the Wasa kit and was looking over the plans... Nope, not ready to go there yet!
Hi Augie- My wife is quilting as I type! I got some beeswax yesterday and did a comparison with the Thread Heaven today. I like the beeswax better.
 I am familiar with that "Oh _ _ _ _!" tirade. I have used it when I'm wrenching out in the garage. Usually after a little circlip whizzes off to hide somewhere!
Edited by Salty Sea Dog
-Buck
Link to comment
Hi JP!  I had the lid of the Wasa kit and was looking over the plans... Nope, not ready to go there yet!
Aint wives great?  Mine is also a weaver and the darned alpacas keep chewing on my rigging :D  :D  :D
Augie
Previous Builds :
Link to comment
Ahoy Buck :D
If you're ready, it's the wrong kit :P
  J.Pett
Link to comment
Ahoy Buck :D
Lol JP! - You sound just like the little voice in my ear! - the one from the little guy with the pitchfork! :)
-Buck
Link to comment
Buck,
Aways such a pleasure catching up on your progress. You're also amazing with miniature tools of the trade. Super nice details on your latest -- harpoons (:-)
Just don't practice in your fish tank, if you have one!?
Regards, Michael
Michael
Current buildSovereign of the Seas 1/78 Sergal
Under the table:
Golden Hind - C Mamoli    Oseberg - Billings 720 - Drakkar - Amati
Completed:
Santa Maria-Mantua --
Vasa-Corel -
Link to comment
Ahoy Buck :D
Thats not a pitchfork
He's trying to hand you something to open the box and get started
  J.Pett
Link to comment
Ahoy Buck :D
Now that's funny! :D
I was going to wait until later, but these are the 4 kits in the running for the next build. I would appreciate opinions on what you all think I should tackle next. I was thinking about progressively working through more difficult projects, but the Golden Hind would be a jump to the deep end instead of wading through less complicated builds first. Dirk's (Dubz) Revenue Cutter Alert build has me pretty excited about the Dallas though...
http://modelshipworld.com/index.php?/topic/700-usrc-alert-by-dubz-revenue-cutter-done/
I really like the trawler and the pinky but the Golden Hind would be a more useful 'stepping stone' to develop the skills that would be needed on the Wasa. So which should it be?
-Buck
Link to comment
Ahoy Buck :D
I really like the little guy, “Misty”  lots of hardware, which you do very well, but it is a bit to much like the whaleboat in this respect
Then there is Dallas, looks like a nice little build, but then so is the Eagle
Got it: Go with the big one. Start it and when you feel like it is getting a little stale, which the bigger, longer projects can, start one of the smaller ones as a side project to keep it fresh, then finish the Golden Hind.
You can do the other two while you are working on the other big one
Just my two cents, but I like interludes, and understand some don’t
  J.Pett
Link to comment
I can't speak for Mamoli kits but, given the choices, I'd go for the Golden Hind.  Particularly since your goal is the Wasa, she will give you the most translatable experience.
Augie
Previous Builds :
Link to comment
Galleon hands down.
You have the skill and what you dont have you will develop.
Its time to step past that line of float things at 1/2 pool and slip into deeper water. Plus Galleons are one of my favorite ship designs. If you build the Hind, you'll then be ready for the Wasa... of course you might want to send me the Wasa for safe keeping until you get around to it   B)
Link to comment
First of all, congratulations on the whaleboat and detail completion. You have a true showpiece!
My vote would be the Dallas.  If you can do that nice a job on a harpoon, I can't wait to see what you do with a carronade...
Link to comment
I don't know why no one has put their vote behind the beautiful 1750 Eagle.  Wow, she has great lines and a stern on her like no other, I mean baby's got back!  Plus knowing your skills Buck, your wood working would make that model look ten times, maybe even eleven times great then the box would suggest.  WIth that said I would put a very close second vote behind the Hind.
Brian
Link to comment
Wow I'm glad I was giving that eagle a closer look.
Scuppers! I need to get them drilled in the DSotM. How'd I forget. maybe I was waiting for stanchion placement...
I love the smaller fish vessels and the Eagle is a ccol little ship. The Misty is another detailed deck that would be nice to see Bucks skill let loose on.
and funny thing on the Dallas, there are 2 on ebay ATM, when I first saw your post I thought maybe you'd won another auction...how many would that make now... 31
They are all great kits and you cant really go wrong, whatever you pick, but if the Wasa is to be next after this build... I think you'll be really busy and might need a good friend to help store some of those extras taking up space. I would volunteer for that task if you need assistance.
Link to comment
Hi Buck,
My vote is the Dallas Revenue Cutter!!!  Beauuuuuutiful!  .....28"'s of fun!
Seriously, build the vessel of your choice, the vessel that really rings your bell!
Good luck,
Hopeful aka David
Link to comment
Thanks for all the responses. It's good to see that each choice has a following. Lol - Brian has an eye for a nice stern! The Eagle has that effect on me too! :D I think JP's solution of side builds may be the way to go.
I actually have been sporadically working on a Midwest dinghy side build. I wanted to do something special with it and am being influenced by Keith's Swift. I'm thinking of finishing and detailing it out like a wine red Gibson Les Paul Custom guitar with black & white binding instead of a rope bumper and a mother of pearl inlaid transom. I'm not totally comitted to that yet but I'll keep looking at it and mulling it over.
-Buck
Link to comment
Are you going to have Mary Ford sitting in it?
Augie
Previous Builds :
Link to comment
Ahoy Buck :D
I always liked Martin N-20
  J.Pett
Link to comment
JP -Willie Nelson's guitar "Trigger" is a train wreck- but I mean that in a good way! If it were a steel string instead of nylon string guitar, it would be in pieces. If I made the dinghy based on Trigger, it would have to be a diarama with a big hole in the dinghy washed up on some rocks! That might actually be cool for someone really good at distressing techniques.
Keith- the whole Les Paul binding idea originated with my fascination with the Dutch yacht De Sperwer. There was a build in MSW1 and it got me to thinking how you could use guitar binding to make the crisp black and white lines on the rubbing strakes. Photo courtesy of wefalck's website  http://www.maritima-et-mechanika.org/maritime/zuiderzee/zuiderzee.html
Sometime in the future I will be posting in the appropriate section a mini history of the De Sperwer (aka the "James Bond yacht") along with wefalck's pics (with his permission) and a huge amount of detail photos of the boat that was sent to me from the librarian at the Zuiderzee museum (also with their permission).
-Buck
Link to comment
Ahoy Buck :D
I worked with Willy a few times. Lets just say it was an experience. The second hand smoke only adding to it. I am not a big fan but love him personally. He is a great guy.
Edited by JPett
  J.Pett
Link to comment
I'd guess that you are safe from getting glaucoma now! :D I have heard that Willie is a really nice guy. There are so many amazing musicians, especially guitar players, that have come from that corridor from Austin to Dallas/Ft. Worth. Must be something in the Shiner Bock!
-Buck
Link to comment
Ahoy Buck :D
I am not a native Texan but have traveled
The people here rock :)
Don't drink Shiner B either, maybe I should start "lol"
  J.Pett
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
