HMS Alert 1777 - 1/64 by Lee
Lee,
She's looking pretty good.  A little fairing and the framing should work for you.  The only thing I see that might give you problems is a couple frames in the mid ship area that might have to be de-glued and re-set but that will depend on how flexible the frames are.  If they're flexible enough, a bit of heat might work to move them into position and then the wales and deck clamps to secure them.
Link to comment
Share on other sites
Thank you for kind comment, Mark. I agree with you about the importance of frame alignment. I've thought about using base plate with squaring jig but I concluded it would be useless due to the irregularity of frame shape. Fortunately, frames are flexible enough, I'll try to adjust frames to keep alignment and symmetry during joining cross members.
Lee
Link to comment
Lee,
It looks like that joggle in the middle got sorted out with the keel and limber.  :)   As for the breasthook, I think it connects to the stem and to the frames.
Link to comment
Hi Lee,
Your workmanship is obviously terrific, but I have a question.  Assuming there are no gun ports, the sides of which the frames would form, why are there filler pieces, offsets, and dog legs in some of the futtocks?  I understand the siding of each futtock reduces as you go up, so there would be a step at the butts, but I cannot figure out a reason for the other shifts of the futtocks.  Again, your workmanship is very good, but I would like to understand the whys of the dispostion of the frames.
Thank you
Allan
Link to comment
Hi, Allan. Thank you for your interest on my building log. I'm following the plan of "Anatomy of the Ship" series written by Goodwin. Yes, there are evenly spaced 6 gun ports at each side of hull and also, some of top timber are used as the post supporting the sheer rail. In my understanding, the shifting of top timbers is assumed to accommodate the mismatch of gun port and frame position. Anyway, it is quite unique frame design.
Lee
Link to comment
Hi, Mark. Thank you for your kind comments. I've reviewed some logs in this forum to get the answer and found that the clutch and breast hook placed over the planking from the log "HMS Naiad" by EdT. So I'll de-bond the hook and score the bottom to fit to the profile of planking boards.
Lee
Yep... you're right.  I didn't have my thinking cap on straight.
Link to comment
Lee,
as I've written earlier I think that the frames design in the AotS is wrong. The shifted top timbers are only a fix for this design. Also the positions of the gun ports don't match the position of the original drawing.
I could only find double frames for cutters. If I read Allans comment he confirmed what I think.
There exist no contemporary drawing of the framing design for the Rattlesnake class. I've drawn a simplified framing but will now try to make a new reconstruction of the framing to check if my ideas are possible.
Edited by AnobiumPunctatum
Regards Christian
Link to comment
beautiful work Lee,
very detailed framing for scale 1:64, precise and neat, Looks great
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Tip - Joining Clamp
In this small scale model, the spacing between frames is very narrow, sometimes less than 1mm, holding parts after gluing is somewhat difficult. For this, I made special clamping tool and found that it is quite useful and handy, so I introduce it to all. As can be seen at last pic, it can be made easily with paper clip and small wood block and wedge without special tools.
Cheers
Link to comment
Thick stuff, footwaling, mast step, hooks and aft magazine
I decided to plank only the port side to see the inner parts after finishing this ship. As one trial, half of aft magazine platform was planked. To get some contrast, I choose lumber of bright domestic pear wood for the planking board.
Cheers,
Edited by JK Lee
Link to comment
Hi Lee.
This is a really outstanding model.
And your craftsmanship is so good.
Very nice photographs that really show alots of nice details.
Regards Antony.
Best advice ever given to me."If you don't know ..Just ask.
Completed Mayflower
Completed Fun build Tail boat Tailboat
Completed Build Chinese Junk Chinese Pirate Junk
Completed scratch built Korean Turtle ship 1/32 Turtle ship
Completed Santa Lucia Sicilian Cargo Boat 1/30 scale Santa Lucia
On hold. Bounty Occre 1/45
Completed HMS Victory by DeAgostini modelspace. DeAgostini Victory Cross Section
Completed H.M.S. Victory X section by Coral. HMS Victory cross section
Completed The Black Pearl fun build Black Queen
Completed A large scale Victory cross section 1/36 Victory Cross Section
Link to comment
Port side inner hull planking, limber board and bolting
Inner hull between thick stuffs of port side were planked. Planking boards were tapered and dropped at the ends of fore and aft.
To simulate bolting, blackened steel pins were nailed. Two kinds of bolt heads, square and round size of around 1mm, were tried but they seem to be oversized in this small scaled ship.
Link to comment
Very nice work on the planking, Lee.  Will you be leaving the other unplanked?
Link to comment
Nice..Very nice.
Antony.
Completed Mayflower
Link to comment
Treenailing, aft magazine & lower deck beam, oiling... some progress at the inside of hull
In this small scale, diameter of treenail would be about 0.5mm, however, it's not easy for me making treenail of that size. Yes, from the other's building logs, I learned how to make treenail with draw plate but I failed. I think I need more experience. So, I drilled 0.5mm empty holes without treenails on the planked board. I hope I can try again in the near future.
The fitting on aft magazine was simple, light room and magazine access stair. Lower deck beams over the magazine were added.
One more progress was finishing oil trial. I usually used linseed oil and wax for the finishing of furniture but they have a problem of bonding strength with glue on the oiled surface. So I tried varnish type oil and found that the result of joining strength and color was not so bad.
Happy new year!
Lee
Link to comment
beautiful build Lee,
the Fitting out of the interior will be great
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Lower deck beam and deck planking, pump well and shot locker
Happy new year 2015!
Lower deck was partly planked over the aft magazine. I'm not sure my understanding of plan around the aft clutch, some part of clutch crossed the deck plank.
In this small ship, lower deck beam structure is so simple, ie., beams are not curved (no camber), no knees and a few carlings. Pump well and shot locker was installed in front of lower transverse bulkhead.
Cheers.
Link to comment
Really nice progress, Lee.
Your build log is a big motivation, to work on the drawings for my build.
Regards Christian
Link to comment
Hello Lee.
Building at this small scale ... You must have surgeons hands and fingers :)
Capturing and incorporating all the little details is what I find so interesting about this build.
Truly amazing build.
A happy new year to u Lee.
Regards Antony.
Completed Mayflower
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
