HMS Alert 1777 - 1/64 by Lee
Tip - Joining Clamp
In this small scale model, the spacing between frames is very narrow, sometimes less than 1mm, holding parts after gluing is somewhat difficult. For this, I made special clamping tool and found that it is quite useful and handy, so I introduce it to all. As can be seen at last pic, it can be made easily with paper clip and small wood block and wedge without special tools.
Cheers
Lee,
Very nice work, I`ve looked into yours (1:64)  and Christian`s  build ( 1:32) several times now, and because being on the watch, highly inspirated, and gathering information on a 18th century naval cutter decided to obtain a rare "revised version" of  Goodwin`s book, with a great bit of luck at Ebay, for scratch-building the cutter "Alert" in 1:48 scale with lapstrake planking.
That spanning clamp you designed is a very smart little jig I like very much. Trust that many fans of your build will be watching your progress with great interest, well done so far, it is a very ambitious task in that scale, but looks wonderful
Nils
Edited by Mirabell61
Current builds
-Lightship Elbe 1
Completed
Link to comment
Share on other sites
beautiful work Lee,
I`d love to see some Close ups of the floor you just did, it Looks great....
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
That's beautiful, Lee.
Link to comment
Lee I have just finished going through your build, what a beautiful job you are doing. Your workmanship is very clean and crisp, I shall continue to follow along.
Michael
Link to comment
Lee,
very nice build, also the dark Background of the photos in contrast to the wooden tones looks great
Very inspiring !
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Lee,
just a question, I remember you mentioned that only one hull-side will be Planked on in- and outside for leaving the Frame disposal for sight to the inside. This will be wonderful, and is completely on my wave as well......, but due to the Frames Standing quite Close this will narrow the sight very much. Do you have something arranged for a better sight inside. Will the upper deck be semi-planked, with perhaps reduced number of deckbeams or so ?
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Question about planking line
As shown in the pictures, flat lower deck plane at the midship is almost coincide with upper thick stuff plank line, however, at the fore most deck plane is far below from the line, ie., inner hull plank line seems too much curved upward at the fore section. Is it generally right or I made mistake?
In Goodwin's book, he did show very little information about inner hull planking. He only commented thick stuff placed over the chock of futtock joint. So I followed that as possible as I can.
Link to comment
Upper deck clamp, deck hook, inner hull planking between deck clamp and thick stuff.
Upper deck hook was joined directly to the stem and hawse pieces at the height of upper deck line. The deck clamps were also placed at both side of inner hull following the deck plane line. Then, inner hull between clamp and thick stuff of port side was covered with normal planking boards as was done below the thick stuff.
Cheers,
Lee
Link to comment
Thank you Wyzwyk for your interest on my building log.
Thank you Druxey for your kind comments on the planking line. Though the upper thick stuff lines are much curved upward, they ended just below the upper deck hook fortunately. I think the ends should be terminated at around upper breast hook to get more reasonable result.
Link to comment
Upper deck beam
Cambered upper deck beam were prepared by steam bending method and joined on the deck clamp temporarily. Bending was more simple than cutting curved beam, however, it is not easy keeping bending radius constantly for each beam. As can be seen on the following pics, some of beams are needed rectifying the curvature. After marking the position of carling, they will be removed for scoring recesses, attaching hanging and lodging knees and so on.
Regards,
Lee
Link to comment
Hi Lee,
looks very good! It's a lovely little and fine model!
According to beams: I would highly recommend to cut them instead of bending. It's not soo much more work. Otherwise this can end with bad surprises later... Now it's a state where you can avoid some problems.
Alex
Edited by Alex M
Current build: HMS Sphynx, 20 gun ship launched in 1775 at Portsmouth, Hampshire.
On the drawing board: HMS Anson, 64 gun third rate ship of the line, launched in 1781 at Plymouth
Link to comment
Hi Lee.
As always you continue to produce outstanding work which amazes me.
This will be a splendid model and I wonder on how someone can put so much detail into such a beautiful ship.
Just outstanding.
Regards Antony.
Best advice ever given to me."If you don't know ..Just ask.
Completed Mayflower
Completed Fun build Tail boat Tailboat
Completed Build Chinese Junk Chinese Pirate Junk
Completed scratch built Korean Turtle ship 1/32 Turtle ship
Completed Santa Lucia Sicilian Cargo Boat 1/30 scale Santa Lucia
On hold. Bounty Occre 1/45
Completed HMS Victory by DeAgostini modelspace. DeAgostini Victory Cross Section
Completed H.M.S. Victory X section by Coral. HMS Victory cross section
Completed The Black Pearl fun build Black Queen
Completed A large scale Victory cross section 1/36 Victory Cross Section
Link to comment
Lee,
excellent looking deck beams,
but I`m with Alex, and would`nt take the risk of those beams remembering that were straight once, to slowly creep into that straight Position again.
Suggest that you fit some pillars midships in order to safely and  permanently Keep the curvature of those beams
example...
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Hi, I always appreciate your kind words and "like"s.
Alex and Nils, thank you for the kind recommends about deck beam and I agree with you. At this moment, I removed all the beams from the ship and will observe closely the shape change, however, I'm not so worry about the flattening of beams because the hull wall will act as the constraint of shape change. Anyway, this is a good chance of experiment and in the next project, I may take the method of shape cutting.
Regards. Lee
Link to comment
Going outside of hull
By the lots of joining long stuffs, she became strong enough to work on outside of hull. First, stepped and rough starboard side surface of frame was smoothened with rasp, file and scraper was used for final finishing. Port side frame surface, where the planking will be scheduled, was only finished with rasp.
The main wale was prepared with 2mm thick ebony strake. They were steam bent and joined at the same height of upper deck clamp.
Next step will be the planking of port side by clinker type.
Cheers, Lee
Link to comment
beautiful Lee,
clinkered port side....., that will be a treat...
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Progress of port side hull planking
About half of port side hull has been planked up to now. It takes so many time and rework than I expected. I thought there will be a little chance of fairing of clinker type planking, I was careful on work. However, I found there are many unsatisfied area. I learn that "Do not believe the view by eye." and taking picture is much helpful to check the result.
Cheers, Lee
Edited by JK Lee
Link to comment
Good work Lee,
ist going to look beautiful when the portside planking is completed
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Very good planking, Lee!
I find a clinker hull easier to plank than a carvel one....
How many clinked hulls you have build? Can you show us fotos?
Alex
Edited by Alex M
Link to comment
Hello Lee.
This is most excellent work. And your ship is looking very good.
Is it possible to have a close up of the planking overlap.
I am very interested in this method of planking.
Many thanks Antony.
Completed Mayflower
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
