Pen Duick by Matija - 1898, 1:20
Link to comment
Share on other sites
Your deck is beautiful.  Well done.
Bob
Current build:  SS_ Mariefred
Link to comment
Thank you Mike, Omega, Bob, Mark, Tasmanian and others for the kind words and the likes.
It is now nearing the completion of the deck.
The following is still fine sanding and we will see the final result.
Regards, Matija.
Link to comment
Thank Row and others who likes.   :)
The deck is nearing the end, here are some photos:
Regards, Matija.
Link to comment
Link to comment
Patrick, thanks for the compliments. Nice to hear from a true master :)
How do I have a problem with bad English I made a few pictures to explain how I do it.
I do not think I'm doing something special that others do not work.
  maybe is  the secret to great pressure on the planks glued part.
each plank especially sanding and checking measures
It begins like this
the coarse sanding but must be at right angles
checking
adjustment
Here it is evident that the pressure on the plank gets result
follows gluing black paper
placed plank is for example, not glued
Patrick, I think I could answer on your question, and I hope it is understandable.
I hope that I helped to someone   ;)
Regards, Matija.
Link to comment
Thank you for showing how you did that beautiful work on the planking.
Link to comment
excellent step by step, reminded me of long hours this summer doing a similar thing on the cover-board on Maria.
Your deck looks beautiful.
Michael
Link to comment
Hi Matija
Many thanks!  The pictures painted a thousand words and made the process you use really clear.  What's also evident is the amount of work and effort required to achieve your level of precision.  Thanks once again and I look forward to more updates.
Cheers
Patrick
Link to comment
Fantastic work, this gives at the model great aspect , it seems to bee at scale 1:1
Link to comment
Hello Matija
Great workmanship! - I just learned a few things. Thank you for posting this skills.
Regards
Mike
Thanks Mike, I'm glad if I could help a little..
I hope that I will in the future be of help.
Michael
Thanks Michael, I have seen your masterpiece Maria ...
You are unsurpassed, congratulations. :)
Thanks to everyone else for the kind comments and likes - Mark, Druxey, Patrick, Leo,...
Work on the deck is nearing its completion but still slow going.
  While the adhesive dries I started working on the deck furniture
Matija :)
Link to comment
Superb! simply Superb, the rework of the deck was certainly worth all the effort.
Michael
Link to comment
Hi Matija
I love the work you've done on the deck furniture. Even though it may be early days, the workmanship is already evident as witnessed by the carefully rounded corners, precision of the construction and the beauty of the wood.
Well done and I can't wait for more updates.
Cheers
Patrick
Edited by Omega1234
Link to comment
Matija,
Beautiful work - your attention to detail is quite simply stunning!
Patrick's (Omega1234) comment about the '... carefully rounded corners' is all too true and prompted me to think about how you might have made them. Were they cut from solid timber, laminated or created using some form of dark art?!
Keep up the fabulous work,
Regards,
Row
1:28 Scale J class yacht 'Enterprise' (R/C)
Build log currently at: http://www.rcsailing.net/forum1/showthread.php?6264-1-28-J-Class-Enterprise-build-log
Link to comment
Matija,
Regards,
Row
Yes, how did you round the corners so tightly?  We want to know.
Bob
Link to comment
Thank you all for your interest and good words.
Michael, I hope that the deck will remains the same after the coating protection.
Corners I got after several attempts. I first tried to laminate.
The thickness of the finished slats is 1.25 mm. When bent in several layers, very thin wood,  it is badly looked or cracked. I cut it out from pieces of wood and manually processed. No dark art only work and repetition ;)
The pictures show cutting only for example, now I  cutting the  bad  tree   ;)
Finishing with power tools and hand
Matija
Edited by Matija
Link to comment
You did a fine job.
Bob
Link to comment
Extremely impressive work - all that and you've still got your fingers &thumbs intact, I think if I'd attempted something so intricate I'd now be in bandages!!
Row
Link to comment
Hi Matija
I can only repeat, what all the previous speakers have already said!
... and I was also wondering how you've made the wonderful rounded coaming?!
Thank you for showing us the way of solution in your post  :)
Again and again it's a pleasure to visit your workshop ...
Regards
Mike
current scratch build 1:15
Colin Archer - RS14 "Stavanger"
Link to comment
Thanks to everyone that follow my log, which give likes, support and nice words.
Row, it's all luck,  as all fingers is complete, so far I have only good sanded nails .. ;)
Thanks Mike, I'm also a joy to see your log and the progress of construction.
Today I finished my deck. Now give him a lot of attention, sanding and coating ...
Here are a few photos, I hope you will like:
Regards, Matija.
Edited by Matija
Link to comment
Matija,
That decking is beautiful, beautiful, beautiful. Such nice work. I wasn't familiar with this yacht, Pen Duick, until your build log, here, and I find it such a very attractive boat - you're doing a fantastic job of her. (Makes me add it to my 'potential builds' list)
Cheers,
Elia
Elia
Rose Valley, PA
Arethusa: 1907 Gloucester Knockabout
Link to comment
Beautiful deck on a beautiful boat.
Bob
Link to comment
Thank you Patrick, Elia, Bob ... and all the faithful visitors of my log.
Elia, this is a beautiful ship, I am impatiently waiting for several years to begin work. It is a great pleasure to work.
... I hope I will not regret it ;)
Cheers,  Matija.
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
