Pinco Genvese by Angarfather - Finished
After many years of useing kits as the base for modelling, I started my first scratch model. Therefor I have choosed a smal ship, not a big one like my HMS Agamemnon.
On the Mediterranean took place since the end of the 17th century two particularly fast, lean and sharply built sailing vessels whose hull was probably developed from the galley and the caravel: a native of Venice Galeotte and Xebec. The warships of Geneva and Venice, and also well known as the ships of the northern African pirates.
At the same time Pinco was the typical merchant ship in the Mediterranean. In principle, a Xebec. However, not so fast, lean and sharply built, but with a good load carrying capacity.
Typical of these ships was the double rigging. In good weather latin sails. In bad weather square rigged.
I like this Mediterranean ships, and last but not least at the stern of the Pinco are not so much decorations. I have never before carved such ornaments, but I will do my very best.
I began the build August 15. by the plans from Euro Modell Como.
Before I started the first planking, it was necessary to make the transition in the forecastle completed. After the first planking I do not get off there.
I have made the first planking in a special way. 3mm plywood strips are glued between the bulkheads. The bow and stern sections are filled with balsa. After sanding is the result a strong base for the second planking
Second planking is made from wallnut
After mounting the hatches on maindeck planking was the next step.
I didn't find any information how the scuppers are to be made, and where there position is. And this is my solution: after reinforcing the bulwark at the positions, drilling in the scuppers.
Edited by Angarfather
on the : Staatenjacht Utrech
At last finished:
Gianna a Pinco Genovese
HMS Agamemnon
Link to comment
Share on other sites
Part 2
The Gallion
I think that the wood of a sail ship from the early 18.century was protected by tar. The guys in the International Maritime Museum, Hamburg told me, that this tar was not black but dark brown. And so I take "Van Dyck Brown" for this job, as I have seen the ships in the paintings of Rembrandt and van Dyck.
To cover the wales I scratched an angle trim. That had been a very fiddely job, for the 2*3mm wallnutbeams are very sensible under progress.
The skupperports are from 9mm Ramin. To make these parts was not a difficult job: first drilling the 5mm whole, than cutting into 2,5mm slides, some sanding - ready.
At last finished:
HMS Agamemnon
Link to comment
Part 4
The decoration of the transom was a interesting area. First problem was the framing. I wasn't able to make it from wood.
But the solution was to make it from 2mm soldering wire. In a vice I formed it into a fourcorner.
Some shots after painting the hull. I use distemper coulors. Tar = van Dyck brown  decorationareas = english red
rails are black.  The frames of the transion and the decoration = leaf gold
At last finished:
HMS Agamemnon
Link to comment
Part 5
It's the first time that I have to carve decorations.
My first akantus pieces
and than the next parts with leaf gold and in place.
That's my pinco today.
Last but not least : I belive that a ship must have a name. Her name is Gianna - and that's in german Hanna. :champagne:
Cheers Hartmut
At last finished:
HMS Agamemnon
Link to comment
Link to comment
Harmut,
I have to close my mouth........
That looks terrific !!!!!
You are saying that you have never do carving but men, that looks so good !
I will follow you further on !!!!!!!!
Let the pictures coming  :D
Sjors
Link to comment
Thanks mates!!!
Giannas stern decorations are finished now.
Naturaly, when al the wood work will be done, there will be some refinishing operation, in the coloured or goldareas.
regards  Hartmut
At last finished:
HMS Agamemnon
Link to comment
Hi,
one question. Is it ok to show how I make such little things like a ladder, or isn't it interesting? Things like this:
There are 6 little laders on pincos deck. Every with only to stairs. I think it's more easy to make this parts with a jig.
The laders in place
Another new little piece. The kabinedoor
This evening I thought how to make the cover of the hatchway on quarterdeck. The span width is only 1m /3,3". So I made the coverbeams like a roof.
The way: the parts after milling the covering of the hatch.
than sanding the "roofs"
I think that will be ok
Next step will be modelling the grasps - eybolds with rings -
kindly Hartmut
At last finished:
HMS Agamemnon
Link to comment
Hartmut,
By all means, show how you make the bits and pieces if you can.  We all like the "how do you do this?" types of posts.
Edited by mtaylor
 La Belle Poule 1765 - French Frigate from ANCRE plans                             Triton Cross-Section
        USS Constellaton (kit bashed to 1854 Sloop of War  _(Gallery) Build Log
        Wasa (Gallery)
        HMS Sphinx 1775 - Vanguard Models - 1:64
Link to comment
How did you achieve your treenails? They look great.
Regards, Scott
Completed builds:
Awaiting construction:
Link to comment
Hi mates!
thanks !
@: S.Coleman To show the nails I use this little device: two cutted hypodermic needles in the top of a soldering iron to burn in the covering of the nails.
Kindly  Hartmut
At last finished:
HMS Agamemnon
Link to comment
I have made the grips from 0,7mm black ironwire ( bindingwire from a floristshop).
All together 12 pieces for the quaterdeckhatch and 40 for the cargohatch.
The ready quarterdeck hatch.
The cargo hatch on maindeck
Milling the planks
Ready
A Happy New Year 2015 to all.
Cheers!   :champagne-popping-smiley-emotic
Hartmut
At last finished:
HMS Agamemnon
Link to comment
Thanks, John. I use distemper colours. These colors can be thined well. However, there are some small problems with the surface, as it is watercolor.
I had to make nearly 50 cleats for this little ship. And that's may way to do this.
First I have made a squarebar. Than milling the profile.
Thats the result, a profilbar.
Thereafter cutting with the circular saw
I attach the cleats with glue and a nail in a centerhole. Drilling in the centerhole
Now just grind a bit, and the first cleat is ready
Angarfather
At last finished:
HMS Agamemnon
Link to comment
Very well done Hartmut,
for being your first scratch model it Looks great, hatch covers, cleats, bilge pumps, Gold leaf plating, and, and.....
are you going to rigg sails ?
Nils
Current builds
Steamship Ergenstrasse
Completed
"Mississippi Lady"  sternwheel steamer 1:30 kit build fun boat as Xmas present
Pilot Schooner # 5 ELBE
"SS Kaiser Wilhelm der Grosse" four stacker passenger liner of 1897, 1:144 (scratchbuild)
"HMS Pegasus" , 16 gun sloop, Swan-Class 1776-1777 scale 1:64 from Amati plan  (scratch build)Pilot schooner #5 Elbe
"Pamir" 4-mast barque, P-liner, 1:96  (scratchbuild)
"Gorch Fock 2" German Navy cadet training 3-mast barque, 1:95 (scratchbuild)
"Heinrich Kayser" heritage Merchant Steamship, 1:96 (scratchbuild)
"Bohuslän" , heritage ,live Swedish museum passenger steamer (Billings kit), 1:50
Link to comment
Thanks, Nils,
Yes, gianna get's sails. Two sets. One latin, and one squaresails. Next week my wife will sew the sails. She is a perfect tailor herself, and I am very clumsy in needlework.
Hartmut
At last finished:
HMS Agamemnon
Link to comment
Lucky you Hartmut......
Nils
Current builds
Completed
Link to comment
Masts
The masts of a pinco are made from one treestem. One peace. Non problem to make this on the turninglathe.
The mastheads with the sheaveholes are quadrangle. This form can be sanded well on the millingmachine
drilling and milling the sheaveholes.
drilling in the holes for the fixingpoints of the cleats
Foremast
Mainmast
Regards Hartmut
At last finished:
HMS Agamemnon
Link to comment
Link to comment
Your work is very beautiful Hartmut .I love it. I will follow with interest. By the way my sister's name is Gianna...
Regards
Dimitris
Current Build: Amerigo Vespucci -Mantua- 1:100 scale
Completed Build logs: Bluenose II AL 1:75 scale
Gallery: Bluenose II AL 1:75 scale
Future Build: Royal Caroline -Panart- 1:47 scale
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
