24' exploration gaff-rigged ketch by vaddoc - FINISHED -Scale 1:12, a Tad Roberts design
The work progresses at a very slow pace now. At every step new challenges appear. Also, I try to plan as far down the built as possible to avoid finding my self in an impossible situation. I use a lot of epoxy at this stage which is a dangerous glue as it is impossible to undo in case of a mistake. Measure 10 times and cut one!
I did some work on the centerboard, the edges came out very nice.
It is time to think now about painting, as the centerboard will need to be installed before the floor boards. I will be following closely the american team so the top of the CB will be red, there will be a red strip on the sides of the boat and the planking will be white (or something like that). I used Acrylic paint in the past and found it very difficult to use due to visible brush strokes and extremely poor coverage. I found enamels much better. In any case, I got some acrylic paint from a DIY store, Valejo acrylic, artist acrylic paint and Humbrol enamel and tested it on plywood previously sealed using high quality brushes.
Enamel wins hands down, no brush marks, a single coat equals to 4 coats of acrylic, no nasty odour, at least not in my garage. Strangely, I did not find significant difference between the different acrylics.
The bottom panels are now solidly glued to the frames and transom so it was possible to finally glue to the stem which was much simpler than I expected. I have cut the panels much larger, to be trimmed afterwards.
The apron laminate is still incomplete, there is 1 mm to be added. The structure is so strong that instead of two layers of 0.5 mm I will just add a 1mm walnut strip. The next photos show the test fitting
There is about 1 mm gap as fitting snugly the bottom panels to the apron was beyond my skills. This will be filled however later on. The panels will also need fairing and this will be done before adding the remaining planking.
Next I sanded the panels to the stem surface, preparing for the lamination of the false stem
And I added the final layer to the apron
I suspect the structure now is very rigid. The jig is in the way so I cut it in half and removed one side to have more space to trim the bottom panel. There was absolutely no play in the hull.
The next panel (lower chine) will overlap the bottom panel so I can use it as guide to trim appropriately. This is done very carefully as removing to much wood will lead to a hole in the hull and much excitement.
I realised though that the other half of the jig was still in the way, so I removed it. The hull is rock solid. Could not resist some photos though!
The apron is now fully laminated and I have a suspicion that the gap is actually filled by the excess epoxy that squeezed out but I ll check this later. I have also trimmed one panel but only up to frame 1 as trimming up to the stem will be a more complex issue.
The last three photos show the outer clamp and the test fitting of planks No 2 and 4. I must say, they fit like a glove and rest effortlessly on the notches at every frame!
A rather pressing problem is what to use for fairing the panels. I tried some filling putty from a DIY store but it is not fit for purpose, it dries very quickly and is very hard to sand. Any suggestions?
Link to comment
Share on other sites
Hi Vaddoc
Great progress so far. I can't help but be reminded of the butterfly that emerges from the cocoon. The more you peel back the supporting framework, the more of your handiwork is revealed! It won't be long before you can remove the hull and hold it in your hands. Now, that would be a milestone to rejoice. Only then can you fully admire all your CAD work, measurements and dedication .
Can't wait to see the photos when that happens.
Cheers
Patrick
Edited by Omega1234
Link to comment
Link to comment
The boat is coming along slowly due to other commitments and also due to the complexity of the built. I finished trimming the sides of the bottom panels forward of frame 1, where the lapstrake should gradually fade reaching the stem. Then the lower chine panel was fitted, one side at the time.
The transom proves particularly challenging to address.
The fairing compound seen near the bow is to fill a large dimple which I think is the result of cutting the panels quite larger than needed to have plenty to trim, this probably did not allow the plywood to bend smoothly.
The lower chine panels also need trimming. The lower edge should not be touched in any of the boards and planks as it defines the shape of the boat.
Next the lower of the 4 planks was fitted. The next photos show the bevel at the bow.
Both sides done, again the transom area was difficult to tackle.
One thing's for sure, I will need to fair the hull until my fingers bleed.
The boat is now starting to show its size, It is really a large model but also the beam looks much larger than it does in the plans.
I think that I should laminate the false stem before adding the rest of the planks.
Link to comment
Hi Vaddoc
I'm enjoying your ship's log. She's a nice, clean build and the complexity of getting the chines lined up properly along the hull would've been no mean feat.
I take it that you're liaising with Tad Roberts about your progress. He must be pretty chuffed!
Cheers
Patrick
Edited by Omega1234
Link to comment
Thanks for the good words Patrick, actually I have not contacted him but you are right, he probably would like to know!
Link to comment
Chuffed is a good word.....impressed works too  :D  :)   Great job!
I tell people all the time that the main point in boatbuilding is stubborn perseverance and working your way through problems.  You've certainly done that Vaddoc and are to be congratulated.  The twist in the forward end of that lowest (bottom) strake is (IMO) the most difficult part of building this hull.  It gets easier from here.
Carry on and thanks for the heads up....
Link to comment
I don't really know what to say, I never expected such honours! Great to have you along in this journey Tad!
The pressure is really on now!
Link to comment
your progress looks great Vaddoc
Link to comment
Thanks Michael, I am following your Skipjack amazing project, thankfully no engine in this boat!
I decided to take a break from the stressful planking and laminate the false stem. I used again walnut which bents, glues and sands beautifully. It came out fine but maybe just not wide enough. It probably is just half a millimetre too narrow on each side but I d rather do it again than sand the planks, this is a decision for later. Even with all the planks fitted it will still be possible to laminate the stem.
The next job to be completed was to fit the next plank up, which was a mountain to climb and took 3 days! The plank would not sit properly and finally I realised it was 2 cm shorter than its pair! I had to do it again but still in order to sit properly the previous plank had to be bevelled and some of the notches slightly adjusted. Generous bevelling was needed at the stern and bow.
Finally I managed to get it into place and I am happy with the fit. I have no idea how the next planks will fit, hopefully they wont be far off.
The original plans call for riveting but it is very difficult to fit the planks just with rivets so I used a minute amount of epoxy to glue the plank to the frames. I experimented with 0.7 mm brass wire I had and it looks ideal to be used for rivets, using CA glue and the dremel with the grinding stones to grind the wire flush.
I couldn't resist a glimpse of the hull!
I need to get many spare drills and a collet for the dremel as there will be hundreds of holes to drill. I think I should finish planking and then do the rivets. Also I still have not decided what to use for fairing the hull, the options could be PVA glue with woodflour or some filling compound from the model shops. The putty from the DIY shops is really difficult to work with.
Link to comment
Link to comment
Coming along nicely.  I like the lap strake.
Bob
Current build:  SS_ Mariefred
Link to comment
Thanks Patrick and Bob, I now have huge respect for the traditional ship builders of old that were lofting on floors and putting these boats together with hand tools!
Tad was right, planking goes faster now or maybe I go further in my learning curve. Two more planks to go!
Just a few more pics
There are I think significant similarities to the photos of the american team at the same stages, if we overlook the abysmal difference in the quality of the work.
I hope the bow will come out like this!
Link to comment
Planking is finished!
Still couple of things left, to trim the end of the planks at the bow, add the false stem, the keel and the rivets, do a massive amount of fairing and possibly paint.
The transom looks ok, I think the important thing is the pair of planks at each chine to line up. Again a lot of fairing is needed.
Link to comment
Congratulations to my Admiral for bringing to the world a beautiful little girl!
One Butterfly will need to wait for the other I guess!
Link to comment
Yes double congratulation in order!
Michael
Link to comment
I somehow managed to find a bit of time to work on the boat. I am waiting for some timber to re-do the false stem and also some filling putty to fair the hull. It is time to concentrate on the keel.
 The strip shows the shape of the keel and of the deadwood
I decided to cut the centerboard slot, there will be more wood added but best to do it in two steps as pear wood is hard.
The job was done with the Dremel using a drill bit to remove the wood like a milling machine and finishing off with the hand files. I was surprised as it was a relatively easy job
Checking again the shape of the keel.
This is tricky due to the curve of the keel but also due to the fact that its width changes along its length. The best way of approaching this is to put it together in segments, which is how the full size boat would be built. A lot of laminating and sanding had to be done but it seems to come along fine.
I made a pattern of the keel near the Transom
Then I laminated some pear strips to make the deadwood
The deadwood was not wide enough so I added some more wood and also laminated another piece.
This is a nice solid piece of wood! The Dremel moto saw only just managed to cut it.
Fits reasonably well
The space is starting to fill up
I added the second piece, nothing is glued yet
I made a paper pattern of the shape of the keel to prepare the third piece
All three seem to fit OKish
Lots of sanding later it definitely looks better but long way to go
More wood needs to be added. There will also be another long plank added on top which need to be shaped
All segments so far, getting closer to the end
It only needs some more sanding so that the long plank fits flush but I think it is almost done. I will need to laminate and install the false stem before gluing everything together, and some serious fairing will need to be done first
Link to comment
Hi Vaddoc
Really nice! Seeing the amount of joinery and carpentry that you're doing with the deadwood and keel emphasises just how much work goes into a relatively 'simple' hull such as yours. Damn good job you're doing, if you ask me!
I bet you must be looking forward to releasing the hull from the building board and holding it in your hands. That'll be a proud moment, for sure.
All the best
Patrick
Edited by Omega1234
Link to comment
Thank you for the encouragement Patrick, it really motivates me to push forward!
You are right about the keel, it is really hard work, it took 2 days of hard work to reach this stage and even sanding these small pieces was physically tiring as the laminates are really hard.
Yes, both me and the Butterfly Explorer are looking forward to break free of the support and sail into the horizon!
Not too long now I think.
Link to comment
The work continues and new problems and challenges pop up all the time!
The fairing putty I got from the model shop is really good, much nicer to work with than the one from the DIY shop. I faired the bow and also trimmed the planks at the the stern and faired the transom.
I have already decided to rivet the boat and I think I should tackle this now. Besides, it would be a nice change from all the laminating and woodwork. I realised however that I did not mark the position of the frames during planking. I tried a simple solution
This did not work due to the curvature of the hull so a more complex tool had to be improvised which worked fine. The positions of all frames is now marked.
I next need to make a pattern so that all rivets all equally spaced. A short maple strip and a folded piece of paper was an easy solution.
It was easy now to mark the position of the rivets.
The thickness of the plywood is only 0.8 mm so the overlap is too small for the rivets to go through both panels so this line of rivets is not going to be too functional but it needs to be done to stay as close to the original design as possible. Interestingly, the american team added stringers at the lower chines, the next photo shows these as they reach the transom. Either way I think the floor boards will hide this lower river line.
I drilled the holes with the Dremel and a 0.7 mm good quality drill. I used brass wire for the rivets and CA glue and used masking tape to prevent the glue staining the wood.
There was a learning curve to go through but it worked ok. A few of the rivets have a lot of material to be trimmed on the inside of the hull. I used the grinding wheel on the Dremel to trim the rivets flush with the planks but it did not work out, the wire gets very hot, the glue melts and the rivet just slides in. Trimming with the needle file was much more efficient.
There will be 6 rivet lines per side with approximately 100 rivets each, so around 1200 rivets! That's a lot! I will not rivet past Station 0 as I will complete this job after the cant frames are installed.
I also redid the false stem and added the final plank to the keel. I took the precaution of blocking the centerboard slot to make sure the epoxy does not drip.
Next job to glue in and trim the false stem, do some more fairing and of course more rivets!
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
