I bent the stbd side piece and over did it a bit.  Easy to correct.  Just learning to make those little adjustments that only come with experience.  Chuck, the strake above the molding is broken up by the gun ports.  Do you bend a full-length piece to a fair run before you cut it in small segments or bend the pieces separately?  I'm not there yet, just asking.
Maury
Link to comment
Share on other sites
The next strake up needs some minor tapering and a notch for the gunport.  I used the heating iron to put a slight bend in the plank before gluing.
Maury
Link to comment
More planking.  I started using CA on the planking and things went much faster.  The next step is to make sure the tops of the frames are fair and match from side to side.  Tops of gun port verticals need to be sanded off.  Square tops of the frames get faired.  This will give me a place to measure the width of the next two planks up to the shear.
Maury
Edited by Maurys
Link to comment
I finished the planking above the wales on the starboard side.  They still need the tops faired and a bunch more sanding.
Maury
Link to comment
Port side upper planks installed and the outer aft frame thinned.  I used a Jewelers saw and chisels to thin them.  I was afraid to use a rotary tool at this stage.
Maury
Link to comment
The counter took some edge bending as well as the gentle bend of the stern and came out well.  Edge bending is still something I'm getting comfortable with...the inside of a bend seems to bend a bit sharply in the center rather than a gentle sweeping curve.  I even place two clamps in the middle of the plank to widen the curve.  Trial and error.  The transom edge bending is less severe and went on well.  I did the lower strake pieces first, then moved to the solid plank above the gun ports and then filled-in the rest.  Next up are the fashion pieces covering the edges of the counter and transom.  Question for Chuck...The planking over the square tuck is vertical on the plans and in your build log, but seems horizontal in the pictures with the instructions.  I seem to recall more discussion about the vertical planking and the surround on the build log at the time, but that does not appear now.
Maury
Link to comment
That looks very good.....
The square tuck planks are 100% vertical.  See how they follow the stern post.
Link to comment
Fashion pieces cut, shaped and glued in place.  Tops will be trimmed later.
Maury
Link to comment
Now that I have started Cheerful, your posts including the nice photos have helped me to answer some of questions which I have had so far. Nice work Maury!
Mike
Edited by Stuntflyer
Current build - Sloop Speedwell 1752 (POF)
Completed builds - 18 Century Longboat (POB) , HM Cutter Cheerful  1806 (POB), HMS Winchelsea 1764 (POB)
Link to comment
Third coat of paint on the counter.  One more to go should even everything out.
Maury
Link to comment
The wales have been installed on the starboard side.  The pieces were cut to size, tapered at the bow and cut to fit the shape of the fashion piece at the stern.  These went on much easier than the original planks.  A little sanding, then I'll put a coat of sanding sealer and start painting them.
Maury
Link to comment
Over the last few days, I've applied six well-thinned coats of black paint (Model Expo Hull Black) to the wales.  I don't have Chuck's skills at hand painting without going past the edge, so I taped it with Tamiya masking tape.  Very little bleed-thru and most of that scraped-off easily.
Maury
Link to comment
Laying out the planks below the wales.  I used tick strips every other bulkhead starting from deadflat and ran a batten at the mid points (10 planks down) from stem to where the square tuck joins the stern.  That seems the most critical alignment of the planks.  Since it was fair, I marked all the bulkheads with a dark line.  Same exercise on the other side.
Maury
Link to comment
Working on the first strakes.  The center and aft sections go on first, then the drop plank.  First pieces  are tapered to about 1/2 full width between bulkheads B & J then installed in segments.  Aft section takes a big twist as it gets to the square tuck.  Next are the drop planks.
Maury
Link to comment
There was a dip in the planking so I spiled the next strake to even it out.  You can make it out at the fourth bulkhead from the stem at the end of the drop plank.  There is a light pencil line on the strake where the problem was.
Maury
Link to comment
Hi Maury,
Very nice catch there. Everything is looking really nice.
Rusty
"So Long For Now" B)
Current Builds: HMS Winchelsea 1/48  Duchess of Kingston
Completed Build Logs: USF Confederacy , US Brig Syren , Triton Cross Section , Bomb Vessel Cross SectionCutter CheerfulQueen Anne Barge, Medway Longboat
Link to comment
Slow progress.  More planking.  I'm not happy with my progress with edge bending, so I'm back to spiling...and getting better at it.  After they are all in, I'll smooth them a bit (Particularly at the drop plank, which was thicker).  Five more strakes in the upper band.
Maury
Edited by Maurys
Link to comment
More planking over the last few weeks. One more strake on each side and I can go to work on the transom.
I made a jig that fits over the plywood spine so when she's upside down for planking, the fashion pieces wont get broken since they stick up a bunch.  It can be held in the vise or propped up on a block of scrap wood (as shown here on pic. #3).  My spiling is getting better.  Sure it uses a bit more wood, but careful planning gets several similar pieces cut from one strip with only modest waste.  I've also given up on soaking or steaming the planks.  Pieces this thin (.0475") need bending only with a very hot blow dryer and some gentle pressure.  No more shrinkage when dried and no more raised grain nor water staining.
Maury
Link to comment
Before moving to the bottom band of planking, it's time to work on the Square Tuck.  All of the ends of the planks so far are smoothed against the base for the tuck.  Lots of sanding to do on the planks, but that's for later.  Next comes the fitting of the various pieces that make up the tuck section.  The green tape is being left on to help protect the extensions of the fashion trim.
Maury
Edited by Maurys
Link to comment
The Square Tuck framing is done.  Next is the planking inside the frames.  I left the inner edges of the frames straight rather than the beautiful curve Chuck put on his.  Thanks for all the likes.
Maury
Edited by Maurys
Link to comment
Why did you leave those inner edges straight, Maury? You might wish to consider revisiting that, as it will add beauty to the lovely hull lines.
Link to comment
Thanks for the comments about the inner edges.  Chuck and Druxey are right.  The straight line of the inner frame pieces did not look right.  I added and shaped some pieces to follow the curve of the outer edge of the frames.  Now for the really small planking inside the frames.
Maury
Link to comment
That looks great Maury. I'm glad, and I bet you are too, that you bit the bullet and redid it. :)
Rusty
Link to comment
I'm sure grateful for all those critical eyes.
Maury
Link to comment
Square Tuck planking done.  Some sanding and maybe some putty to hide the gaps and it will look good.  Sure glad I rounded those frames.
Maury
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
