Rattlesnake by KenW - FINISHED - Model Shipways - Scale 1:64 - American Privateer
Looks pretty darned good, Ken.  I'm still waiting to do anything 100% to my own standards.  Have fun with the tree nails.
Augie
Current Build: US Frigate Confederacy - MS 1:64
Previous Builds :
US Brig Syren (MS) - 2013 (see Completed Ship Gallery)
Greek Tug Ulises (OcCre) - 2009 (see Completed Ship Gallery)
Victory Cross Section (Corel) - 1988
Essex (MS) 1/8"- 1976
Cutty Sark (Revell 1:96) - 1956
Link to comment
Share on other sites
Ken,
You are doing a bang up job on the ship. On the treenails, at 1:64 the treenails will be very small. I would figure roughly a 1" hole would be about 1/64" or .016 rounding. That would be the equivalent of about a 26 gauge wire. Since you are not painting this, you might think about using brass 26 gauge wire. Drill a small hole touch the wire to some thick CA and insert it in the hole. Later trim and sand. This is much easier than trying to tree nail with something that small and the brass will look smart against the wood color but not too bright to take away from the details you are adding.
Just a thought.
Bill
Chantilly, VA
Its not the size of the ship, but the bore of the cannon!
Current Build: Scratch Build Brig Eagle
Completed Build Log: USS Constitution - Mamoli
Completed Build Gallery: USS Constitution - Mamoli
Link to comment
Thanks Bill and Scott and the 'likes'.
I've been using Chuck's method as described in his Cheerful log for the tree nailing.  It looks pretty good.  I'll post the results soon.
Cheers.
Ken
Washington 1776 Galley
Pilot Boat Mary of Norfolk
Completed Builds:
Link to comment
I haven’t made an entry in quite a while.  A lot of distractions and work was slow.  I’m not all that satisfied with the results of the overall planking of the hull.  But the tree nails look good, if they don’t all line up properly.
I did paint (stain) the expanded black stripe, a half inch thick, as the plans show.  Looks O.K.
I also made up the hatches with their coamings.   I’m pleased with all the deck furniture I’ve made so far, including the new hatches.  I don’t understand why I can make small, detailed binnacles, capstans, bulge pumps, etc. that I’m happy with, but I can’t plank a hull.  I guess I just have to view a planked hull as a large piece of furniture.
Ken
Completed Builds:
Link to comment
That's a lot of treenails.  Looks very nice for a guy who 'can't plank a hull'.
Augie
Previous Builds :
Link to comment
Thanks Augie.  I used a #78 drill which is pretty small.
Now I’m ready to plot out the deck and start planking.  First I added a waterway and planked the inner bulwarks.  Then I got the plans, made a copy, cut the deck out and put it all on the deck.
Next I placed the hatches on the deck and added some scrap wood to insure that the hatches and deck planks have something to glue to.  I started by adding four 1/8 inch planks in the center of the deck.  Some carving was necessary, but I took my time (like I do when I’m making furniture).  I also made the bow sprint to ensure it fitted properly.
post-912-0-15398900-1443488134_thumb.jpg  post-912-0-74591300-1443488157_thumb.jpg
I want to plank the deck using the method described by Chuck Passaro in his Cheerful log.  He says that ships built at this time were planked with curved and tapered planks.  And, when I looked at the Rattlesnake plans, sure enough that is the way the deck planking is shown.  So I mapped out the planks and used an artist tape at the half way point to check if my plan looked “correct”.  Don’t know if it's “correct”, but I think it looks alright.
Ken
Completed Builds:
Link to comment
Thanks Scott.  I suspected as much.
Ken
Completed Builds:
Link to comment
Very nice job so far.  Your planking and treenails turned out great.  You used holly to plank the hull and redheart for the inner bulwarks.  What did you use to plank the outer bulwarks, counter and transom?   Are you going to use the cast metal stern carvings supplied in the kit, or carve your own?
Dave
Edited by DocBlake
Link to comment
Hey Dave - good questions.
The outer bulwarks and counter are boxwood; and the transom is swiss pear.  I may use walnut for the upper outer bulwarks.
The carvings are something I'm still pondering.  I may make an impression of the stern carvings from the cast metal and then make an impressions from that impression so that I can re-shape the carvings and perhaps improve them.  I can't see myself doing those intricate carvings myself.
Ken
Completed Builds:
Link to comment
The deck is planked.  I even managed to carve some scarf joints; two forward and two aft.  I don’t think I’m going to do tree nailing for the deck, but I do have to tree nail the upper outer hull.  Then I’ll be ready for deck furniture and the guns.  There are also 5 gun port covers that I must make.
Lots to do and so little time to do it.
Ken
Completed Builds:
Link to comment
Love the hooded scarph joints.  Nicely done.
Augie
Previous Builds :
Link to comment
Thanks Augie.  I never could spell.
Ken
Completed Builds:
Link to comment
I’ve made some progress.  The stern is improved with only the fancy metal decoration to be added.  The pencil lines are for tree nailing that I forgot I hadn’t done.  Also, six gun port doors are installed.  I used the Syren kits and each door can open and close.  However, I intend to rig all 20 guns, so the doors will always be open.  And finally, I made a manger board; even though my forecastle and quarter decks will not be exposed.  I will know the board is there.  (The bow sprint is not glued yet.)
Ken
Completed Builds:
Link to comment
Thanks Sam; and to all the 'likes'.
Ken
Completed Builds:
Link to comment
And now, we know it's there.  Well done.
Augie
Previous Builds :
Link to comment
Thanks Augie
Ken
Completed Builds:
Link to comment
This is really two entries combined into one.  First I constructed 12 gun carriages.  They were made from some sheets of red heart wood left over from the capstan kit which I sent to Chuck Passaro.  He made his gun carriage kits from the red heart, which I think look really good.  I don’t care what my son says, I painted the gun barrels and the trucks black.
Secondly, I mounted six of the guns on the fore of the gun deck.  These will be pretty much covered up by the forecastle, but I wanted to rig them anyway.  It’s good practice.  I decided that I didn’t want to use those ‘beautiful’ round coils for the ends of the tackles.  When I visited the HMS Victory, the tackle lines look like they were just kicked under the carriages.  On the USS Constitution, the tackle lines were tied around the blocks, which is what I tried to do here.  It’s not exact, but close.  I have since touched up the paint on the guns.
Ken
Completed Builds:
Link to comment
Hi Ken -
Nicely done!!!  all that cannon rigging practice from FAIR AMERICAN must be paying off now...with these smaller cannons.  Keep up the good work.
<<Gary>>
current build: SYREN
nearly done:  Fair American, Benjamin W. Latham
future builds:  Emma C. Berry
completed builds:  Rattlesnake, Newsboy, Sultana
Link to comment
Nice idea on the natural finish redheart!
Augie
Previous Builds :
Link to comment
Thanks Gary, Augie and Sam and the 'likes'.
The blocks and line at this scale feels a lot smaller that on the 1/4 scale Fair American.
And Fathers are always right.
Cheers.
Ken
Completed Builds:
Link to comment
I’ve gone as far as I want, for now, with the forecastle.  I installed the beams for the deck that were removed/broken from the forward kit supplied bulkheads.  All seems O.K. up front.
Now I must turn my attention to the stern.  From reading the blogs of DocBlake and jsgerson, I realize that there are many potential problems with the transom back here.  As far as I can tell, I do have some problems, but they aren’t the same ones that they had.  So the work begins.  Also I’ve decided I’m going to use dark walnut for the outer planking above the white molding rather than Swiss pear.  I just like the look better.
Ken
Completed Builds:
Link to comment
Hi Ken -- Beautiful work on this lovely ship.  I love the look of your stern with the expertly done planking.  Are the beams you set in for the forecastle also in redheart?  I used that wood for the capstan in my Fly, and had thought of using for the gun carriages as well, but found it so crumbly that I gave up and resorted to paint instead :o
Cheers,
Martin
Current Build:  HMS FLY 1776
Previous Builds:  Rattlesnake 1781
                        Prince de Neufchatel
Link to comment
Hey Martin.  I have looked in on your Fly build before.
The forecastle beams are done in redheart, and aren't yet glued in place.  The gun carriages are also redheart, but I had it easy since Chuck Passaro made me kits from some sheets I had.  The wood can be crumbly, but it does look good.
Cheers.
Ken
Completed Builds:
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
