JeremyB
  • Gender
  • Location
    Somerset
316 profile views
  1. Hi guys, Many thanks for your rapid responses. I will as you all suggest take some photos to show the problem as best as I can. I like the idea of putting in some sort of diagonal bracing or blocks to bring it back into a straight line. I will keep you posted.
  2. I have a part built kit by Corel - Flying Fish. I started it several years ago and put it down, as the hull planking seemed a massive challenge with too many different ideas (keel up, bulwarks down etc) that put me off, and I like to know exactly what to do before I start things. My problem is that now I have decided to just get stuck in and start planking, I find that the hull has developed a slight twist, resulting in the decks being out of horizontal alignment across their width by about 3mm. I can easily align the decks by gently twisting the hull to where it should be, but how can I do this permanently? Can I use steam on the plywood to help me get it back to where it should be, as well as some clamping while it cools, or is this a lost cause, needing me to un-glue all the ribs, remove the decking ply etc. Any help or advice would be much appreciated.
